5 Replies Latest reply on Apr 22, 2016 2:59 AM by Peter Spier
    InDesign CS6 from Master Collection crashed permanently at "Dienstregistrierung wird gestartet..."
    az28420298
      Hy at all,
      we are using an updated InDesign CS6 on a windows 7 pro 64bit system. From yesterday to now we cannot start the program - it stops at the starting process and will be shut down. Windows didnt find a solution and quits ID CS6. Last time this happens (some month ago) we have to install the complete windows new, than it worked.  But this cannot be the solution for the problem. - deinstall and reinstall of the complete suite + adobecccleaner does not function. There also weren't Win 7 updates from yesterday to today and all other programs of the suite are running smooth - only ID will have problems and crashes. our IT did not find a solution last times and now, before we setup an complete fresh system, there should be another solution?
      Thanks for help!
        • 2. Re: InDesign CS6 from Master Collection crashed permanently at "Dienstregistrierung wird gestartet..."
          az28420298 Level 1
          Hello Peter,
          thank you for your fast answer. I searched your pinned discussions but did not found a good hint. ID does not start with admin rights also it does not start at a new account - both crashed. At safe mode it starts but shut down silently without any notification.
          At normal using it gives the following informations to the crash:
          Problemsignatur:
            Problemereignisname:    APPCRASH
            Anwendungsname:    InDesign.exe
            Anwendungsversion:    8.1.0.420
            Anwendungszeitstempel:    54aaae3e
            Fehlermodulname:    ntdll.dll
            Fehlermodulversion:    6.1.7601.23392
            Fehlermodulzeitstempel:    56eb302d
            Ausnahmecode:    c00000fd
            Ausnahmeoffset:    0002df76
            Betriebsystemversion:    6.1.7601.2.1.0.256.48
            Gebietsschema-ID:    1031
            Zusatzinformation 1:    3b3d
            Zusatzinformation 2:    3b3d0e81daed57f2259f7e14005a55e8
            Zusatzinformation 3:    e96f
            Zusatzinformation 4:    e96f87bd3b4243b52a1644e1cfc02ca7
          • 3. Re: InDesign CS6 from Master Collection crashed permanently at "Dienstregistrierung wird gestartet..."
            Is your default printer a local printer rather than network? If not, try changing to a local printer temporarily (you can use Microsoft Fax rather than a physical printer for this if necessary) and try launching again. ID sometimes wants to see a local printer on first launch.
            Beyond that, I'm not seeing anything useful in the crash data (no surprise there on Windows).
            • 4. Re: InDesign CS6 from Master Collection crashed permanently at "Dienstregistrierung wird gestartet..."
              az28420298 Level 1
              Hy Peter,
              we changed from the network printer to the Fax but this does not fix the problem. Also we reduced the number of installed fonts to the systemfonts - same here :-(
              From the system we get 3 new hints to files,
              WER2EAE.tmp.appcompat.txt
              WER405B.tmp.mdmp
              WER1737.tmp.WERInternalMetadata.xml
              which would help to find the problem - the mdmp file ist a little bit large (9 MB) - the other files have these information.
              <WERReportMetadata>
                  <OSVersionInformation>
                      <WindowsNTVersion>6.1</WindowsNTVersion>
                      <Build>7601 Service Pack 1</Build>
                      <Product>(0x30): Windows 7 Professional</Product>
                      <Edition>Professional</Edition>
                      <BuildString>7601.23392.amd64fre.win7sp1_ldr.160317-0600</BuildString>
                      <Revision>1130</Revision>
                      <Flavor>Multiprocessor Free</Flavor>
                      <Architecture>X64</Architecture>
                      <LCID>1031</LCID>
                  </OSVersionInformation>
                  <ProblemSignatures>
                      <EventType>APPCRASH</EventType>
                      <Parameter0>InDesign.exe</Parameter0>
                      <Parameter1>8.1.0.420</Parameter1>
                      <Parameter2>54aaae3e</Parameter2>
                      <Parameter3>CoolType.dll</Parameter3>
                      <Parameter4>5.10.70.21235</Parameter4>
                      <Parameter5>503facb6</Parameter5>
                      <Parameter6>c00000fd</Parameter6>
                      <Parameter7>00050e07</Parameter7>
                  </ProblemSignatures>
                  <DynamicSignatures>
                      <Parameter1>6.1.7601.2.1.0.256.48</Parameter1>
                      <Parameter2>1031</Parameter2>
                      <Parameter22>2bbe</Parameter22>
                      <Parameter23>2bbea8506d157ba982953ef4be6281aa</Parameter23>
                      <Parameter24>1713</Parameter24>
                      <Parameter25>171386a9a344ee40ca560395189df1c7</Parameter25>
                  </DynamicSignatures>
                  <SystemInformation>
                      <MID>B7EB538A-7890-4C53-8D37-15DD3A3DB20C</MID>
                      <BIOSVersion>KCH7710H.86A.0104.2012.1123.1027</BIOSVersion>
                  </SystemInformation>
              </WERReportMetadata>
              <?xml version="1.0" encoding="UTF-16"?>
              <DATABASE>
              <EXE NAME="InDesign.exe" FILTER="CMI_FILTER_PRIVACY">
                  <MATCHING_FILE NAME="ACE.dll" SIZE="1958576" CHECKSUM="0xDC1919E7" BIN_FILE_VERSION="2.19.18.19553" BIN_PRODUCT_VERSION="2.19.0.1" PRODUCT_VERSION="66.496476" FILE_DESCRIPTION="Adobe Color Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ACE 2012/02/13-21:49:01" FILE_VERSION="2.19.18.19553" ORIGINAL_FILENAME="ACE.dll" INTERNAL_NAME="ACE" LEGAL_COPYRIGHT="© 1999-2011 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1E4A46" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.19.18.19553" UPTO_BIN_PRODUCT_VERSION="2.19.0.1" LINK_DATE="02/14/2012 06:39:17" UPTO_LINK_DATE="02/14/2012 06:39:17" EXPORT_NAME="ACE.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="adbeape.dll" SIZE="31408" CHECKSUM="0xD3F46E83" BIN_FILE_VERSION="3.3.8.19346" BIN_PRODUCT_VERSION="3.3.8.19346" PRODUCT_VERSION="66.1025012" FILE_DESCRIPTION="Adobe APE(32 bit)" COMPANY_NAME="Adobe Systems, Incorporated " PRODUCT_NAME="Adobe APE 2012/01/25-10:04:55" FILE_VERSION="3.3.8.19346" ORIGINAL_FILENAME="adbeape.dll" INTERNAL_NAME="Adobe APE" LEGAL_COPYRIGHT="© 2006-2011 Adobe Systems Incorporated. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x179B2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.3.8.19346" UPTO_BIN_PRODUCT_VERSION="3.3.8.19346" LINK_DATE="01/25/2012 19:23:38" UPTO_LINK_DATE="01/25/2012 19:23:38" EXPORT_NAME="adbeape.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ADBE_AGMFL.dll" SIZE="1135280" CHECKSUM="0x69689707" BIN_FILE_VERSION="2.1.0.19553" BIN_PRODUCT_VERSION="2.1.0.1" PRODUCT_VERSION="66.496476" FILE_DESCRIPTION="SWFPort Interface Binder" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="SWFPort 2012/02/13-21:49:01" FILE_VERSION="2.1.0.19553" ORIGINAL_FILENAME="SWFPort.dll" INTERNAL_NAME="SWFPort" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x116CFF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.1.0.19553" UPTO_BIN_PRODUCT_VERSION="2.1.0.1" LINK_DATE="02/14/2012 07:09:43" UPTO_LINK_DATE="02/14/2012 07:09:43" EXPORT_NAME="ADBE_AGMFL.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobeLinguistic.dll" SIZE="838264" CHECKSUM="0x7EAB7D13" BIN_FILE_VERSION="6.0.0.17304" BIN_PRODUCT_VERSION="6.0.32.1" PRODUCT_VERSION="6.0.0" FILE_DESCRIPTION="Linguistic Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe Linguisitc Library" FILE_VERSION="6.0.0.17304" ORIGINAL_FILENAME="AdobeLinguistic.dll" INTERNAL_NAME="Lilo" LEGAL_COPYRIGHT="Copyright 1999-2011 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD019A" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.17304" UPTO_BIN_PRODUCT_VERSION="6.0.32.1" LINK_DATE="03/05/2012 06:39:17" UPTO_LINK_DATE="03/05/2012 06:39:17" EXPORT_NAME="AdobeLinguistic.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobeOwl.dll" SIZE="1511128" CHECKSUM="0x8C202271" BIN_FILE_VERSION="4.0.96.0" BIN_PRODUCT_VERSION="4.0.96.0" PRODUCT_VERSION="4.0.96" FILE_DESCRIPTION="Adobe Owl(32 bit)" COMPANY_NAME="Adobe Systems, Incorporated " PRODUCT_NAME="Adobe Owl 2013/06/13-16:05:39" FILE_VERSION="4.0.96" ORIGINAL_FILENAME="AdobeOwl.dll" INTERNAL_NAME="Adobe Owl" LEGAL_COPYRIGHT="Copyright © 2006-2011 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x172A16" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.96.0" UPTO_BIN_PRODUCT_VERSION="4.0.96.0" LINK_DATE="06/13/2013 23:42:08" UPTO_LINK_DATE="06/13/2013 23:42:08" EXPORT_NAME="AdobeOwl.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobeOwlCanvas.dll" SIZE="264368" CHECKSUM="0x6870C595" BIN_FILE_VERSION="3.6.5.0" BIN_PRODUCT_VERSION="3.6.5.0" PRODUCT_VERSION="3.6.05" FILE_DESCRIPTION="Adobe Owl Canvas" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Owl Canvas" FILE_VERSION="3.6.05" ORIGINAL_FILENAME="AdobeOwlCanvas.dll" INTERNAL_NAME="Adobe Owl Canvas" LEGAL_COPYRIGHT="Copyright © 2007-2009 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x48401" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.6.5.0" UPTO_BIN_PRODUCT_VERSION="3.6.5.0" LINK_DATE="12/16/2011 01:11:25" UPTO_LINK_DATE="12/16/2011 01:11:25" EXPORT_NAME="AdobeOwlCanvas.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobePDFL.dll" SIZE="6723800" CHECKSUM="0x1E8F1412" BIN_FILE_VERSION="10.0.1.31374" BIN_PRODUCT_VERSION="10.0.1.31374" PRODUCT_VERSION="66.506926" FILE_DESCRIPTION="Adobe PDF Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="PDFL 2013/06/26-04:00:50" FILE_VERSION="10.0.1.31374" ORIGINAL_FILENAME="AdobePDFL.dll" INTERNAL_NAME="PDFL" LEGAL_COPYRIGHT="© 1987-2011 Adobe Systems Incorporated.
              All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x675CAE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.0.1.31374" UPTO_BIN_PRODUCT_VERSION="10.0.1.31374" LINK_DATE="06/26/2013 21:24:12" UPTO_LINK_DATE="06/26/2013 21:24:12" EXPORT_NAME="AdobePDFL.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobePIP.dll" SIZE="695472" CHECKSUM="0x6629A043" BIN_FILE_VERSION="6.0.0.1654" BIN_PRODUCT_VERSION="6.0.0.1654" PRODUCT_VERSION="6.0.0.1654" FILE_DESCRIPTION="Adobe Product Improvement Program" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Product Improvement Program" FILE_VERSION="6.0.0.1654" ORIGINAL_FILENAME="AdobePIP.dll" INTERNAL_NAME="AdobePIP" LEGAL_COPYRIGHT="Copyright 2008-10 Adobe Systems Incorporated. All rights reserved" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xADCEB" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.1654" UPTO_BIN_PRODUCT_VERSION="6.0.0.1654" LINK_DATE="03/12/2012 07:42:15" UPTO_LINK_DATE="03/12/2012 07:42:15" EXPORT_NAME="AdobePIP.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobePSL.dll" SIZE="18637016" CHECKSUM="0x297B804C" BIN_FILE_VERSION="13.0.0.28380" BIN_PRODUCT_VERSION="13.0.0.28380" PRODUCT_VERSION="66.870559_13.810430" FILE_DESCRIPTION="AdobePSL" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AdobePSL" FILE_VERSION="13.0.0.28380" ORIGINAL_FILENAME="AdobePSL.dll" INTERNAL_NAME="AdobePSL" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x11CCF85" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="13.0.0.28380" UPTO_BIN_PRODUCT_VERSION="13.0.0.28380" LINK_DATE="01/09/2013 23:34:32" UPTO_LINK_DATE="01/09/2013 23:34:32" EXPORT_NAME="AdobePSL.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobeXMP.dll" SIZE="296112" CHECKSUM="0x969F9C6C" BIN_FILE_VERSION="5.3.11.19494" BIN_PRODUCT_VERSION="5.3.11.0" PRODUCT_VERSION="66.145661" FILE_DESCRIPTION="Adobe XMP Core 5.3-c011 ( 32 bit )" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe XMP Core 2012/02/06-14:56:27" FILE_VERSION="5.3-c011 ( 32 bit ), 66.145661, 2012/02/06-14:56:27" ORIGINAL_FILENAME="AdobeXMP.dll" INTERNAL_NAME="AdobeXMPCore" LEGAL_COPYRIGHT="Copyright 2002-2009, Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x56764" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.3.11.19494" UPTO_BIN_PRODUCT_VERSION="5.3.11.0" LINK_DATE="02/06/2012 23:48:00" UPTO_LINK_DATE="02/06/2012 23:48:00" EXPORT_NAME="AdobeXMP.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobeXMPFiles.dll" SIZE="586928" CHECKSUM="0xFE27C504" BIN_FILE_VERSION="5.4.49.19494" BIN_PRODUCT_VERSION="5.4.49.0" PRODUCT_VERSION="66.145661" FILE_DESCRIPTION="Adobe XMP Files 5.4-f049 ( 32 bit )" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe XMP Files 2012/02/06-14:56:27" FILE_VERSION="5.4-f049 ( 32 bit ), 66.145661, 2012/02/06-14:56:27" ORIGINAL_FILENAME="AdobeXMPFiles.dll" INTERNAL_NAME="AdobeXMPFiles" LEGAL_COPYRIGHT="Copyright 2002-2009, Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x97CCE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.4.49.19494" UPTO_BIN_PRODUCT_VERSION="5.4.49.0" LINK_DATE="02/06/2012 23:48:21" UPTO_LINK_DATE="02/06/2012 23:48:21" EXPORT_NAME="AdobeXMPFiles.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AdobeXMPScript.dll" SIZE="107696" CHECKSUM="0xB5A9C3D7" BIN_FILE_VERSION="5.2.2.19494" BIN_PRODUCT_VERSION="5.2.2.0" PRODUCT_VERSION="66.145661" FILE_DESCRIPTION="Adobe XMP Script 5.2-s002 ( 32 bit )" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe XMP Script 2012/02/06-14:56:27" FILE_VERSION="5.2-s002 ( 32 bit ), 66.145661, 2012/02/06-14:56:27" ORIGINAL_FILENAME="AdobeXMPScript.dll" INTERNAL_NAME="AdobeXMPScript" LEGAL_COPYRIGHT="Copyright 2002-2009, Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2352C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.2.2.19494" UPTO_BIN_PRODUCT_VERSION="5.2.2.0" LINK_DATE="02/06/2012 23:48:24" UPTO_LINK_DATE="02/06/2012 23:48:24" EXPORT_NAME="AdobeXMPScript.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="adobe_caps.dll" SIZE="428904" CHECKSUM="0x9A2794ED" BIN_FILE_VERSION="6.0.83.0" BIN_PRODUCT_VERSION="6.0.83.0" PRODUCT_VERSION="6,0,83,0" FILE_DESCRIPTION="Adobe CAPS DLL" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe CAPS" FILE_VERSION="6,0,83,0" ORIGINAL_FILENAME="adobe_caps.dll" INTERNAL_NAME="adobe_caps.dll" LEGAL_COPYRIGHT="© 2005-2012 Adobe Systems Incorporated and its licensors. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6AB78" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.83.0" UPTO_BIN_PRODUCT_VERSION="6.0.83.0" LINK_DATE="03/06/2012 19:17:27" UPTO_LINK_DATE="03/06/2012 19:17:27" EXPORT_NAME="adobe_caps.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AFL.dll" SIZE="139408" CHECKSUM="0x3E845EF1" BIN_FILE_VERSION="1.0.0.0" BIN_PRODUCT_VERSION="1.0.0.0" PRODUCT_VERSION="1.0" FILE_DESCRIPTION="Adobe File Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" AFL" FILE_VERSION="1.0.0" ORIGINAL_FILENAME="AFL.dll" INTERNAL_NAME="AFL" LEGAL_COPYRIGHT="Copyright 2000-2006 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x22C64" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.0" UPTO_BIN_PRODUCT_VERSION="1.0.0.0" LINK_DATE="12/02/2011 07:57:25" UPTO_LINK_DATE="12/02/2011 07:57:25" EXPORT_NAME="AFL.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="aflamingo.dll" SIZE="2211504" CHECKSUM="0x981E832E" BIN_FILE_VERSION="2.3.102.19287" BIN_PRODUCT_VERSION="2.3.0.1" PRODUCT_VERSION="66.485582" FILE_DESCRIPTION="Adobe Flamingo" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AFlamingo 2012/01/20-14:36:51" FILE_VERSION="2.3.102.19287" ORIGINAL_FILENAME="AFlamingo.dll" INTERNAL_NAME="AFlamingo" LEGAL_COPYRIGHT="© 2009-2011 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2288A7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.3.102.19287" UPTO_BIN_PRODUCT_VERSION="2.3.0.1" LINK_DATE="01/20/2012 23:16:27" UPTO_LINK_DATE="01/20/2012 23:16:27" EXPORT_NAME="aflamingo.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AGM.dll" SIZE="5851864" CHECKSUM="0x3BA2D108" BIN_FILE_VERSION="4.26.24.34097" BIN_PRODUCT_VERSION="4.26.0.1" PRODUCT_VERSION="66.561503" FILE_DESCRIPTION="Adobe Graphics Manager" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AGM 2015/01/28-22:14:56" FILE_VERSION="4.26.24.34097" ORIGINAL_FILENAME="AGM.dll" INTERNAL_NAME="AGM" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x59E695" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.26.24.34097" UPTO_BIN_PRODUCT_VERSION="4.26.0.1" LINK_DATE="01/28/2015 19:19:51" UPTO_LINK_DATE="01/28/2015 19:19:51" EXPORT_NAME="AGM.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ahclient.dll" SIZE="242864" CHECKSUM="0xAA65CA56" BIN_FILE_VERSION="1.7.0.56" BIN_PRODUCT_VERSION="1.7.0.56" PRODUCT_VERSION="1,7,0,56" FILE_DESCRIPTION="Adobe Help Client Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" AdobeHelp Dynamic Link Library" FILE_VERSION="1,7,0,56" ORIGINAL_FILENAME="ahclient.dll" INTERNAL_NAME="AdobeHelp" LEGAL_COPYRIGHT="Copyright (C) 2008 Adobe Systems Inc." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3DF38" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="1.7.0.56" UPTO_BIN_PRODUCT_VERSION="1.7.0.56" LINK_DATE="01/31/2012 13:07:06" UPTO_LINK_DATE="01/31/2012 13:07:06" EXPORT_NAME="ahclient.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="aldfs32CJK.dll" SIZE="50352" CHECKSUM="0x9081EEE8" MODULE_TYPE="WIN32" PE_CHECKSUM="0xE51B" LINKER_VERSION="0x0" LINK_DATE="02/07/2012 19:38:05" UPTO_LINK_DATE="02/07/2012 19:38:05" EXPORT_NAME="ALDFS32CJK.dll" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="aldvm32CJK.dll" SIZE="46256" CHECKSUM="0xB326A690" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1252C" LINKER_VERSION="0x0" LINK_DATE="02/07/2012 19:37:51" UPTO_LINK_DATE="02/07/2012 19:37:51" EXPORT_NAME="ALDVM32CJK.dll" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="amtlib.dll" SIZE="1793672" CHECKSUM="0x25FDBDA8" BIN_FILE_VERSION="6.0.0.75" BIN_PRODUCT_VERSION="6.0.0.75" PRODUCT_VERSION="6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)" FILE_DESCRIPTION="AMT Licensing" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="AMTLib" FILE_VERSION="6.0.0.75" ORIGINAL_FILENAME="amtlib.dll" INTERNAL_NAME="amtlib" LEGAL_COPYRIGHT="Copyright 2006-2011 Adobe Systems Incorporated. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C0DE8" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.75" UPTO_BIN_PRODUCT_VERSION="6.0.0.75" LINK_DATE="01/16/2012 11:26:42" UPTO_LINK_DATE="01/16/2012 11:26:42" EXPORT_NAME="amtlib.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ARE.dll" SIZE="328880" CHECKSUM="0x24D5D19B" BIN_FILE_VERSION="1.5.2.19553" BIN_PRODUCT_VERSION="1.5.0.1" PRODUCT_VERSION="66.496476" FILE_DESCRIPTION="Adobe Raster Express" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ARE 2012/02/13-21:49:01" FILE_VERSION="1.5.02.19553" ORIGINAL_FILENAME="ARE.dll" INTERNAL_NAME="ARE" LEGAL_COPYRIGHT="© 2000-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5DB5D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.2.19553" UPTO_BIN_PRODUCT_VERSION="1.5.0.1" LINK_DATE="02/14/2012 06:40:45" UPTO_LINK_DATE="02/14/2012 06:40:45" EXPORT_NAME="ARE.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="arh.exe" SIZE="79744" CHECKSUM="0xD753E519" BIN_FILE_VERSION="2.7.1.19610" BIN_PRODUCT_VERSION="2.7.1.19610" PRODUCT_VERSION="2.7.1" FILE_DESCRIPTION="Adobe AIR Redistribution Helper" COMPANY_NAME="Adobe Systems Inc." PRODUCT_NAME="Adobe AIR " FILE_VERSION="2.7.1.19610" ORIGINAL_FILENAME="arh.exe" INTERNAL_NAME="arh.exe" LEGAL_COPYRIGHT="Copyright 2011, Adobe Systems Inc." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x176A9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.7.1.19610" UPTO_BIN_PRODUCT_VERSION="2.7.1.19610" LINK_DATE="08/05/2011 17:40:46" UPTO_LINK_DATE="08/05/2011 17:40:46" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ASLSupport.dll" SIZE="67216" CHECKSUM="0x40C1799E" MODULE_TYPE="WIN32" PE_CHECKSUM="0x18FC4" LINKER_VERSION="0x0" LINK_DATE="03/28/2012 07:51:12" UPTO_LINK_DATE="03/28/2012 07:51:12" EXPORT_NAME="ASLSupport.dll" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ATR.dll" SIZE="517776" CHECKSUM="0xF5B62F9" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="400.013.100 " FILE_DESCRIPTION="Adobe Trapping Component" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="ATR" FILE_VERSION="400.013.100 " ORIGINAL_FILENAME="ATR.dll" INTERNAL_NAME="ATR" LEGAL_COPYRIGHT="Copyright © Adobe Systems 2001" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8A596" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="09/09/2011 11:52:28" UPTO_LINK_DATE="09/09/2011 11:52:28" EXPORT_NAME="ATR.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AXE16SharedExpat.dll" SIZE="171184" CHECKSUM="0xCF201E3D" BIN_FILE_VERSION="3.7.101.18636" BIN_PRODUCT_VERSION="3.7.0.1" PRODUCT_VERSION="66.26830" FILE_DESCRIPTION="AXE Shared EXPAT (UTF-16 native)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXE16SharedExpat 2011/12/16-15:10:49" FILE_VERSION="3.7.101.18636" ORIGINAL_FILENAME="AXE16SharedExpat.dll" INTERNAL_NAME="AXE16SharedExpat" LEGAL_COPYRIGHT="© 2003-2010 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D2E3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.7.101.18636" UPTO_BIN_PRODUCT_VERSION="3.7.0.1" LINK_DATE="12/17/2011 01:12:39" UPTO_LINK_DATE="12/17/2011 01:12:39" EXPORT_NAME="AXE16SharedExpat.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AXE8SharedExpat.dll" SIZE="169648" CHECKSUM="0xD42238D5" BIN_FILE_VERSION="3.7.101.18636" BIN_PRODUCT_VERSION="3.7.0.1" PRODUCT_VERSION="66.26830" FILE_DESCRIPTION="AXE Shared EXPAT (UTF-8 native)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXE8SharedExpat 2011/12/16-15:10:49" FILE_VERSION="3.7.101.18636" ORIGINAL_FILENAME="AXE8SharedExpat.dll" INTERNAL_NAME="AXE8SharedExpat" LEGAL_COPYRIGHT="© 2003-2010 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2CF9D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.7.101.18636" UPTO_BIN_PRODUCT_VERSION="3.7.0.1" LINK_DATE="12/17/2011 01:12:16" UPTO_LINK_DATE="12/17/2011 01:12:16" EXPORT_NAME="AXE8SharedExpat.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AXEDOMCore.dll" SIZE="665776" CHECKSUM="0xF465E9A6" BIN_FILE_VERSION="3.7.101.18636" BIN_PRODUCT_VERSION="3.7.0.1" PRODUCT_VERSION="66.26830" FILE_DESCRIPTION="Adobe XML Engine: DOM Core" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXEDOMCore 2011/12/16-15:10:49" FILE_VERSION="3.7.101.18636" ORIGINAL_FILENAME="AXEDOMCore.dll" INTERNAL_NAME="AXEDOMCore" LEGAL_COPYRIGHT="© 2001-2010 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAA230" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.7.101.18636" UPTO_BIN_PRODUCT_VERSION="3.7.0.1" LINK_DATE="12/17/2011 01:10:08" UPTO_LINK_DATE="12/17/2011 01:10:08" EXPORT_NAME="AXEDOMCore.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="AXSLE.dll" SIZE="597680" CHECKSUM="0x77D76050" BIN_FILE_VERSION="3.7.101.18636" BIN_PRODUCT_VERSION="3.7.0.1" PRODUCT_VERSION="66.26830" FILE_DESCRIPTION="Adobe XSLT Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="AXSLE 2011/12/16-15:10:49" FILE_VERSION="3.7.101.18636" ORIGINAL_FILENAME="AXSLE.dll" INTERNAL_NAME="AXSLE" LEGAL_COPYRIGHT="© 2002-2010 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x98499" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.7.101.18636" UPTO_BIN_PRODUCT_VERSION="3.7.0.1" LINK_DATE="12/17/2011 01:11:50" UPTO_LINK_DATE="12/17/2011 01:11:50" EXPORT_NAME="AXSLE.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="BIB.dll" SIZE="304304" CHECKSUM="0x2BEBCA74" BIN_FILE_VERSION="1.2.2.19553" BIN_PRODUCT_VERSION="1.2.0.1" PRODUCT_VERSION="66.496476" FILE_DESCRIPTION="Bravo Interface Binder" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="BIB 2012/02/13-21:49:01" FILE_VERSION="1.2.02.19553" ORIGINAL_FILENAME="BIB.dll" INTERNAL_NAME="BIB" LEGAL_COPYRIGHT="© 1995-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5034C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.2.2.19553" UPTO_BIN_PRODUCT_VERSION="1.2.0.1" LINK_DATE="02/14/2012 06:36:12" UPTO_LINK_DATE="02/14/2012 06:36:12" EXPORT_NAME="BIB.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="BIBUtils.dll" SIZE="247984" CHECKSUM="0x140F65BA" BIN_FILE_VERSION="1.1.1.1" BIN_PRODUCT_VERSION="1.1.0.1" PRODUCT_VERSION="66.496476" FILE_DESCRIPTION="Bravo Interface Binder Utilities" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="BIBUtils 2012/02/13-21:49:01" FILE_VERSION="1.1.01.19553" ORIGINAL_FILENAME="BIBUtils.dll" INTERNAL_NAME="BIBUtils" LEGAL_COPYRIGHT="© 1993-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x40B4C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.1.1.1" UPTO_BIN_PRODUCT_VERSION="1.1.0.1" LINK_DATE="02/14/2012 06:38:40" UPTO_LINK_DATE="02/14/2012 06:38:40" EXPORT_NAME="BIBUtils.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="boost_date_time.dll" SIZE="72848" CHECKSUM="0x1ACAA15D" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_date_time.dll" INTERNAL_NAME="boost_date_time" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x21115" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="05/31/2011 13:37:26" UPTO_LINK_DATE="05/31/2011 13:37:26" EXPORT_NAME="boost_date_time.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="boost_filesystem.dll" SIZE="171664" CHECKSUM="0xAEC5CC63" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_filesystem.dll" INTERNAL_NAME="boost_filesystem" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x36DE9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="05/31/2011 13:08:20" UPTO_LINK_DATE="05/31/2011 13:08:20" EXPORT_NAME="boost_filesystem.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="boost_regex.dll" SIZE="1106064" CHECKSUM="0xA8DF6B55" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_regex.dll" INTERNAL_NAME="boost_regex" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x116B63" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="06/03/2011 11:21:31" UPTO_LINK_DATE="06/03/2011 11:21:31" EXPORT_NAME="boost_regex.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="boost_signals.dll" SIZE="73872" CHECKSUM="0xA3ADFFBE" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_signals.dll" INTERNAL_NAME="boost_signals" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x16818" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="05/31/2011 13:37:30" UPTO_LINK_DATE="05/31/2011 13:37:30" EXPORT_NAME="boost_signals.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="boost_system.dll" SIZE="23696" CHECKSUM="0x3E729C2B" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_system.dll" INTERNAL_NAME="boost_system" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6354" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="05/31/2011 13:37:37" UPTO_LINK_DATE="05/31/2011 13:37:37" EXPORT_NAME="boost_system.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="boost_threads.dll" SIZE="65168" CHECKSUM="0x17A96EAB" BIN_FILE_VERSION="5.0.0.0" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="5.0.0.0" ORIGINAL_FILENAME="boost_threads.dll" INTERNAL_NAME="boost_threads" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1F0E5" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.0" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="05/31/2011 13:37:36" UPTO_LINK_DATE="05/31/2011 13:37:36" EXPORT_NAME="boost_threads.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="CoolType.dll" SIZE="3008728" CHECKSUM="0x83D593DB" BIN_FILE_VERSION="5.10.70.21235" BIN_PRODUCT_VERSION="5.10.0.1" PRODUCT_VERSION="66.516632" FILE_DESCRIPTION="CoolType Typography Engine" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="CoolType 2012/08/30-10:05:39" FILE_VERSION="5.10.70.21235" ORIGINAL_FILENAME="CoolType.dll" INTERNAL_NAME="CoolType" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2EB5DF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.10.70.21235" UPTO_BIN_PRODUCT_VERSION="5.10.0.1" LINK_DATE="08/30/2012 18:11:02" UPTO_LINK_DATE="08/30/2012 18:11:02" EXPORT_NAME="CoolType.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Database.dll" SIZE="316632" CHECKSUM="0x7B3B4EA5" BIN_FILE_VERSION="8.1.0.420" BIN_PRODUCT_VERSION="8.1.0.0" PRODUCT_VERSION="8.1" FILE_DESCRIPTION="Database Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="Database.dll" INTERNAL_NAME="Database" LEGAL_COPYRIGHT="Copyright 2000-2015 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5A0F4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.1.0.420" UPTO_BIN_PRODUCT_VERSION="8.1.0.0" LINK_DATE="01/05/2015 15:29:39" UPTO_LINK_DATE="01/05/2015 15:29:39" EXPORT_NAME="Database.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="dvaadameve.dll" SIZE="4429488" CHECKSUM="0x6BF7B5F3" BIN_FILE_VERSION="6.0.0.0" BIN_PRODUCT_VERSION="6.0.0.0" PRODUCT_VERSION="6.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="6.0.0.0" ORIGINAL_FILENAME="dvaadameve.dll" INTERNAL_NAME="dvaadameve" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4493F1" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.0" UPTO_BIN_PRODUCT_VERSION="6.0.0.0" LINK_DATE="12/16/2011 01:10:20" UPTO_LINK_DATE="12/16/2011 01:10:20" EXPORT_NAME="dvaadameve.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="dvacore.dll" SIZE="2160816" CHECKSUM="0x30C341C9" BIN_FILE_VERSION="6.0.0.0" BIN_PRODUCT_VERSION="6.0.0.0" PRODUCT_VERSION="6.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="6.0.0.0" ORIGINAL_FILENAME="dvacore.dll" INTERNAL_NAME="dvacore" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2136B0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.0" UPTO_BIN_PRODUCT_VERSION="6.0.0.0" LINK_DATE="12/16/2011 01:09:27" UPTO_LINK_DATE="12/16/2011 01:09:27" EXPORT_NAME="dvacore.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="dvaui.dll" SIZE="5725872" CHECKSUM="0xFDC9C49F" BIN_FILE_VERSION="6.0.0.0" BIN_PRODUCT_VERSION="6.0.0.0" PRODUCT_VERSION="6.0.0" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="DVA Product" FILE_VERSION="6.0.0.0" ORIGINAL_FILENAME="dvaui.dll" INTERNAL_NAME="dvaui" LEGAL_COPYRIGHT="Copyright (c) Adobe Systems, Inc.  All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5775EE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.0" UPTO_BIN_PRODUCT_VERSION="6.0.0.0" LINK_DATE="12/16/2011 01:09:47" UPTO_LINK_DATE="12/16/2011 01:09:47" EXPORT_NAME="dvaui.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ExtendScript.dll" SIZE="661168" CHECKSUM="0x96458D29" BIN_FILE_VERSION="4.2.12.18602" BIN_PRODUCT_VERSION="4.2.12.18602" PRODUCT_VERSION="66.490082" FILE_DESCRIPTION="Adobe ExtendScript scripting engine (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ExtendScript 2011/12/14-15:08:46" FILE_VERSION="4.2.12.18602" ORIGINAL_FILENAME="AdobeExtendScript.dll" INTERNAL_NAME="AdobeExtendScript" LEGAL_COPYRIGHT="© 1998-2011 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA3B32" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.2.12.18602" UPTO_BIN_PRODUCT_VERSION="4.2.12.18602" LINK_DATE="12/15/2011 02:03:01" UPTO_LINK_DATE="12/15/2011 02:03:01" EXPORT_NAME="ExtendScript.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ExtendScriptPackaging.dll" SIZE="256656" CHECKSUM="0x44A57625" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3F28A" LINKER_VERSION="0x0" LINK_DATE="10/11/2011 05:19:25" UPTO_LINK_DATE="10/11/2011 05:19:25" EXPORT_NAME="ExtendScriptPackaging.dll" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="FileInfo.dll" SIZE="1978032" CHECKSUM="0xC86D6913" BIN_FILE_VERSION="5.3.3.19230" BIN_PRODUCT_VERSION="5.3.3.19230" PRODUCT_VERSION="66.145433" FILE_DESCRIPTION="Adobe XMP FileInfo 5.3.0.0-ia003 ( 32 bit )" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe XMP FileInfo 2012/01/17-15:11:19" FILE_VERSION="5.3.0.0-ia003 ( 32 bit ), 66.145433, 2012/01/17-15:11:19" ORIGINAL_FILENAME="FileInfo.dll" INTERNAL_NAME="AdobeXMPFileInfo" LEGAL_COPYRIGHT="Copyright 2002-2011, Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1EF29C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.3.3.19230" UPTO_BIN_PRODUCT_VERSION="5.3.3.19230" LINK_DATE="01/18/2012 00:09:55" UPTO_LINK_DATE="01/18/2012 00:09:55" EXPORT_NAME="FileInfo.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="icucnv40.dll" SIZE="731768" CHECKSUM="0xAEDD371C" BIN_FILE_VERSION="4.0.0.0" BIN_PRODUCT_VERSION="4.0.0.0" PRODUCT_VERSION=" Build gtlib_3.0.16615" FILE_DESCRIPTION="IBM ICU Common DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2011/11/15-16:30:22" FILE_VERSION="4, 0, 0, 1012" ORIGINAL_FILENAME="icuuc40.dll" LEGAL_COPYRIGHT=" Copyright (C) 2008, International Business Machines Corporation and others. All Rights Reserved. " VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xBCBB4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.0" UPTO_BIN_PRODUCT_VERSION="4.0.0.0" LINK_DATE="11/15/2011 12:10:14" UPTO_LINK_DATE="11/15/2011 12:10:14" EXPORT_NAME="icucnv40.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="icudt40.dll" SIZE="13922424" CHECKSUM="0x48F887A3" BIN_FILE_VERSION="4.0.0.0" BIN_PRODUCT_VERSION="4.0.0.0" PRODUCT_VERSION=" Build gtlib_3.0.16615" FILE_DESCRIPTION="ICU Data DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2011/11/15-16:30:22" FILE_VERSION="4, 0, 0, 1012" ORIGINAL_FILENAME="icudt40.dll" LEGAL_COPYRIGHT=" Copyright (C) 2008, International Business Machines Corporation and others. All Rights Reserved. " VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD4A5D4" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.0" UPTO_BIN_PRODUCT_VERSION="4.0.0.0" LINK_DATE="11/15/2011 12:13:36" UPTO_LINK_DATE="11/15/2011 12:13:36" EXPORT_NAME="icudt40.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="icuin40.dll" SIZE="1015928" CHECKSUM="0xC100CA5F" BIN_FILE_VERSION="4.0.0.0" BIN_PRODUCT_VERSION="4.0.0.0" PRODUCT_VERSION=" Build gtlib_3.0.16615" FILE_DESCRIPTION="IBM ICU I18N DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2011/11/15-16:30:22" FILE_VERSION="4, 0, 0, 1012" ORIGINAL_FILENAME="icuin40.dll" LEGAL_COPYRIGHT=" Copyright (C) 2008, International Business Machines Corporation and others. All Rights Reserved. " VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFA34B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.0" UPTO_BIN_PRODUCT_VERSION="4.0.0.0" LINK_DATE="11/15/2011 12:11:16" UPTO_LINK_DATE="11/15/2011 12:11:16" EXPORT_NAME="icuin40.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="icuuc40.dll" SIZE="945272" CHECKSUM="0x45E19E1D" BIN_FILE_VERSION="4.0.0.0" BIN_PRODUCT_VERSION="4.0.0.0" PRODUCT_VERSION=" Build gtlib_3.0.16615" FILE_DESCRIPTION="IBM ICU Common DLL" COMPANY_NAME="IBM Corporation and others" PRODUCT_NAME="International Components for Unicode 2011/11/15-16:30:22" FILE_VERSION="4, 0, 0, 1012" ORIGINAL_FILENAME="icuuc40.dll" LEGAL_COPYRIGHT=" Copyright (C) 2008, International Business Machines Corporation and others. All Rights Reserved. " VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF1B34" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.0.0" UPTO_BIN_PRODUCT_VERSION="4.0.0.0" LINK_DATE="11/15/2011 12:10:19" UPTO_LINK_DATE="11/15/2011 12:10:19" EXPORT_NAME="icuuc40.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="InDesign.exe" SIZE="4103896" CHECKSUM="0x9D337439" BIN_FILE_VERSION="8.1.0.420" BIN_PRODUCT_VERSION="8.1.0.0" PRODUCT_VERSION="8.1" FILE_DESCRIPTION="Adobe InDesign CS6" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign CS6" FILE_VERSION="8.1" ORIGINAL_FILENAME="InDesign.exe" INTERNAL_NAME="InDesign" LEGAL_COPYRIGHT="Copyright 2000-2015 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3ECF82" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.1.0.420" UPTO_BIN_PRODUCT_VERSION="8.1.0.0" LINK_DATE="01/05/2015 15:31:10" UPTO_LINK_DATE="01/05/2015 15:31:10" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="JP2KLib.dll" SIZE="661168" CHECKSUM="0x46BE0F3E" BIN_FILE_VERSION="2.0.0.18562" BIN_PRODUCT_VERSION="2.0.0.18562" PRODUCT_VERSION="66.236923" FILE_DESCRIPTION="Adobe JPEG2000 Core Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="JP2KLib 2011/12/12-16:12:37" FILE_VERSION="2.0.0.18562" ORIGINAL_FILENAME="JP2KLib.dll" INTERNAL_NAME="JP2KLib" LEGAL_COPYRIGHT="© 2009 Adobe Systems Incorporated.
              All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA20FF" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.18562" UPTO_BIN_PRODUCT_VERSION="2.0.0.18562" LINK_DATE="12/13/2011 01:46:32" UPTO_LINK_DATE="12/13/2011 01:46:32" EXPORT_NAME="JP2KLib.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="libmmd.dll" SIZE="2893456" CHECKSUM="0xA45BD296" BIN_FILE_VERSION="10.0.10.2" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="10.0" FILE_DESCRIPTION="Math Library for Intel(r) Compilers (thread-safe)" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler" FILE_VERSION="10.0.10.2" ORIGINAL_FILENAME="libmmd.dll" INTERNAL_NAME="libmmd.dll" LEGAL_COPYRIGHT="Copyright (c) 1985-2006 Intel Corporation" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x0" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2CEC0C" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="10.0.10.2" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="08/10/2007 02:59:17" UPTO_LINK_DATE="08/10/2007 02:59:17" EXPORT_NAME="libmmd.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="LogSession.dll" SIZE="321712" CHECKSUM="0x3FE503A0" BIN_FILE_VERSION="2.1.2.1640" BIN_PRODUCT_VERSION="2.1.2.1640" PRODUCT_VERSION="2.1.2.1640" FILE_DESCRIPTION="LogSession" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="LogSession" FILE_VERSION="2.1.2.1640" ORIGINAL_FILENAME="LogSession.dll" INTERNAL_NAME="LogSession" LEGAL_COPYRIGHT="Copyright 2008 - 10 Adobe Systems Incorporated. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x5D6DA" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.1.2.1640" UPTO_BIN_PRODUCT_VERSION="2.1.2.1640" LINK_DATE="01/05/2012 23:59:49" UPTO_LINK_DATE="01/05/2012 23:59:49" EXPORT_NAME="LogSession.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="LogTransport2.exe" SIZE="332464" CHECKSUM="0x4C9FF9D3" BIN_FILE_VERSION="2.1.2.1640" BIN_PRODUCT_VERSION="2.1.2.1640" PRODUCT_VERSION="2.1.2.1640" FILE_DESCRIPTION="LogTransport Application" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME=" LogTransport Application" FILE_VERSION="2.1.2.1640" ORIGINAL_FILENAME="LogTransport2.exe" INTERNAL_NAME="LogTransport2" LEGAL_COPYRIGHT="Copyright 2008 - 10 Adobe Systems Incorporated. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x55F66" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.1.2.1640" UPTO_BIN_PRODUCT_VERSION="2.1.2.1640" LINK_DATE="01/05/2012 23:59:06" UPTO_LINK_DATE="01/05/2012 23:59:06" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="MPS.dll" SIZE="4550360" CHECKSUM="0xD3D1ED71" BIN_FILE_VERSION="5.8.0.32324" BIN_PRODUCT_VERSION="5.8.0.32324" PRODUCT_VERSION="66.551034" FILE_DESCRIPTION="Modular Parsing System" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="MPS 2014/01/06-22:03:18" FILE_VERSION="5.8.0.32324" ORIGINAL_FILENAME="MPS.dll" INTERNAL_NAME="MPS" LEGAL_COPYRIGHT="© 1996-2009 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x4587D6" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.8.0.32324" UPTO_BIN_PRODUCT_VERSION="5.8.0.32324" LINK_DATE="01/07/2014 08:15:56" UPTO_LINK_DATE="01/07/2014 08:15:56" EXPORT_NAME="MPS.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ObjectModel.dll" SIZE="371416" CHECKSUM="0x46970F9C" BIN_FILE_VERSION="8.1.0.420" BIN_PRODUCT_VERSION="8.1.0.0" PRODUCT_VERSION="8.1" FILE_DESCRIPTION="ObjectModel Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="ObjectModel.rpln" INTERNAL_NAME="ObjectModel" LEGAL_COPYRIGHT="Copyright 2000-2015 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x67DDE" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.1.0.420" UPTO_BIN_PRODUCT_VERSION="8.1.0.0" LINK_DATE="01/05/2015 15:30:54" UPTO_LINK_DATE="01/05/2015 15:30:54" EXPORT_NAME="ObjectModel.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PathTypeLib.dll" SIZE="42128" CHECKSUM="0x825E83B0" BIN_FILE_VERSION="8.0.0.370" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0" FILE_DESCRIPTION="PathTypeLib Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="PathTypeLib.dll" INTERNAL_NAME="PathTypeLib" LEGAL_COPYRIGHT="Copyright 2000-2012 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xEA7B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.370" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/28/2012 07:54:24" UPTO_LINK_DATE="03/28/2012 07:54:24" EXPORT_NAME="PathTypeLib.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PDFPort.dll" SIZE="1101528" CHECKSUM="0xFA2F66C3" BIN_FILE_VERSION="2.1.0.29596" BIN_PRODUCT_VERSION="2.1.0.1" PRODUCT_VERSION="66.529615" FILE_DESCRIPTION="PDFPort Interface Binder" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="PDFPort 2013/02/13-10:58:57" FILE_VERSION="2.1.0.29596" ORIGINAL_FILENAME="PDFPort.dll" INTERNAL_NAME="PDFPort" LEGAL_COPYRIGHT="© 1984-2009 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x10DD3D" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.1.0.29596" UPTO_BIN_PRODUCT_VERSION="2.1.0.1" LINK_DATE="02/13/2013 20:44:43" UPTO_LINK_DATE="02/13/2013 20:44:43" EXPORT_NAME="PDFPort.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PDFSettings.dll" SIZE="213648" CHECKSUM="0x89C9EDA6" BIN_FILE_VERSION="1.4.0.1" BIN_PRODUCT_VERSION="1.4.0.1" PRODUCT_VERSION="1.04" FILE_DESCRIPTION="Adobe PDF Settings Manager" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe PDFSettings" FILE_VERSION="1.04.0" ORIGINAL_FILENAME="pdfsettings.dll" INTERNAL_NAME="PDFSettings" LEGAL_COPYRIGHT="© 2004-2008 Adobe Systems Incorporated" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3C220" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.4.0.1" UPTO_BIN_PRODUCT_VERSION="1.4.0.1" LINK_DATE="09/09/2011 12:16:47" UPTO_LINK_DATE="09/09/2011 12:16:47" EXPORT_NAME="pdfsettings.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Plugin.dll" SIZE="47280" CHECKSUM="0xD7FFCCC4" BIN_FILE_VERSION="13.0.0.19655" BIN_PRODUCT_VERSION="13.0.0.19655" PRODUCT_VERSION="CS6" FILE_DESCRIPTION="Photoshop Plugin Utilities" COMPANY_NAME="Adobe Systems, Incorporated" PRODUCT_NAME="Adobe Photoshop CS6" FILE_VERSION="13.0 (13.0 x19655 (66.814192_13.810430))" ORIGINAL_FILENAME="Plugin.dll" INTERNAL_NAME="Plugin" LEGAL_COPYRIGHT="Copyright 2012 Adobe Systems Inc." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD824" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="13.0.0.19655" UPTO_BIN_PRODUCT_VERSION="13.0.0.19655" LINK_DATE="02/22/2012 13:07:55" UPTO_LINK_DATE="02/22/2012 13:07:55" EXPORT_NAME="PLUGIN.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PlugPlug.dll" SIZE="1059480" CHECKSUM="0xCCB308A5" BIN_FILE_VERSION="3.0.0.383" BIN_PRODUCT_VERSION="3.0.0.383" PRODUCT_VERSION="3.0.0.383" FILE_DESCRIPTION="PlugPlug Standard Dll (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe(R) CSXS PlugPlug Standard Dll (32 bit)" FILE_VERSION="3.0.0.383" ORIGINAL_FILENAME="PlugPlug Standard Dll (32 bit)" INTERNAL_NAME="PlugPlug" LEGAL_COPYRIGHT="(C) 2010 Adobe Systems, Inc. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1061F3" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.0.383" UPTO_BIN_PRODUCT_VERSION="3.0.0.383" LINK_DATE="02/01/2012 18:41:01" UPTO_LINK_DATE="02/01/2012 18:41:01" EXPORT_NAME="PlugPlug.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PMFileReader.dll" SIZE="123056" CHECKSUM="0x5E1182B1" BIN_FILE_VERSION="5.6.0.19506" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="66.240342" FILE_DESCRIPTION="PageMaker Import from Sangam" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe India PageMaker Import via Sangam 2012/02/07-10:51:05" FILE_VERSION="5.6.0.19506" ORIGINAL_FILENAME="PMFileReader.dll" INTERNAL_NAME="PMFileReader" LEGAL_COPYRIGHT="© 2000-2009 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40000" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x28E04" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.6.0.19506" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/07/2012 19:38:29" UPTO_LINK_DATE="02/07/2012 19:38:29" EXPORT_NAME="PMFileReader.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PMReaderApp.exe" SIZE="182960" CHECKSUM="0x4DD917F7" BIN_FILE_VERSION="5.6.0.19506" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="66.240342" FILE_DESCRIPTION="PageMaker Import from Sangam" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe India PageMaker Import via Sangam 2012/02/07-10:51:05" FILE_VERSION="5.6.0.19506" ORIGINAL_FILENAME="PMReaderApp.exe" INTERNAL_NAME="PMReaderApp" LEGAL_COPYRIGHT="© 2000-2009 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40000" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2DFE9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.6.0.19506" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/07/2012 19:38:38" UPTO_LINK_DATE="02/07/2012 19:38:38" EXPORT_NAME="PMReaderApp.exe" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="PMRuntime.dll" SIZE="63704" CHECKSUM="0x8ACB2FDA" BIN_FILE_VERSION="5.0.0.191" BIN_PRODUCT_VERSION="5.0.0.0" PRODUCT_VERSION="5.0" FILE_DESCRIPTION="pmruntime Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="pmruntime.dll" INTERNAL_NAME="pmruntime" LEGAL_COPYRIGHT="Copyright 2000-2007 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1E932" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.191" UPTO_BIN_PRODUCT_VERSION="5.0.0.0" LINK_DATE="01/05/2015 15:26:41" UPTO_LINK_DATE="01/05/2015 15:26:41" EXPORT_NAME="PMRuntime.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Public.dll" SIZE="6319832" CHECKSUM="0x9BE61B66" BIN_FILE_VERSION="8.1.0.420" BIN_PRODUCT_VERSION="8.1.0.0" PRODUCT_VERSION="8.1" FILE_DESCRIPTION="Public Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="Public.dll" INTERNAL_NAME="Public" LEGAL_COPYRIGHT="Copyright 2000-2015 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6077C0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.1.0.420" UPTO_BIN_PRODUCT_VERSION="8.1.0.0" LINK_DATE="01/05/2015 15:29:14" UPTO_LINK_DATE="01/05/2015 15:29:14" EXPORT_NAME="Public.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Sangam.dll" SIZE="651440" CHECKSUM="0x4E70369F" BIN_FILE_VERSION="5.6.0.19506" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="66.240342" FILE_DESCRIPTION="Sangam Core Code" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe India Sangam Core Code 2012/02/07-10:51:05" FILE_VERSION="5.6.0.19506" ORIGINAL_FILENAME="Sangam.dll" INTERNAL_NAME="Sangam" LEGAL_COPYRIGHT="© 2000-2009 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40000" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9F25B" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.6.0.19506" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/07/2012 19:39:34" UPTO_LINK_DATE="02/07/2012 19:39:34" EXPORT_NAME="Sangam.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="SangamML.dll" SIZE="395952" CHECKSUM="0xF58B0658" BIN_FILE_VERSION="5.6.0.19506" BIN_PRODUCT_VERSION="0.0.0.0" PRODUCT_VERSION="66.240342" FILE_DESCRIPTION="SangamML Import from Sangam" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe India SangamML Import from Sangam 2012/02/07-10:51:05" FILE_VERSION="5.6.0.19506" ORIGINAL_FILENAME="SangamML.dll" INTERNAL_NAME="SangamML Reader" LEGAL_COPYRIGHT="© 2000-2009 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40000" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x6F6C0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.6.0.19506" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="02/07/2012 19:41:15" UPTO_LINK_DATE="02/07/2012 19:41:15" EXPORT_NAME="SangamML.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="ScCore.dll" SIZE="587408" CHECKSUM="0x7EC3678C" BIN_FILE_VERSION="4.2.12.18602" BIN_PRODUCT_VERSION="4.2.12.18602" PRODUCT_VERSION="66.490082" FILE_DESCRIPTION="Scripting Components Core (32 bit)" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="ScCore 2011/12/14-15:08:46" FILE_VERSION="4.2.12.18602" ORIGINAL_FILENAME="AdobeScCore.dll" INTERNAL_NAME="AdobeScCore" LEGAL_COPYRIGHT="© 1998-2011 Adobe Systems Incorporated. All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x9CD46" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.2.12.18602" UPTO_BIN_PRODUCT_VERSION="4.2.12.18602" LINK_DATE="12/15/2011 02:02:51" UPTO_LINK_DATE="12/15/2011 02:02:51" EXPORT_NAME="ScCore.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="SDKLib.sdk.dll" SIZE="84624" CHECKSUM="0xC4C247BE" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1BDBD" LINKER_VERSION="0x0" LINK_DATE="03/28/2012 07:58:12" UPTO_LINK_DATE="03/28/2012 07:58:12" EXPORT_NAME="SDKLib.sdk.dll" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="SVGExport.dll" SIZE="1327760" CHECKSUM="0x65AC1488" BIN_FILE_VERSION="6.0.0.0" BIN_PRODUCT_VERSION="6.0.0.0" PRODUCT_VERSION="6, 0, 0, 0" FILE_DESCRIPTION="SVGExport 6.0" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="SVGExport" FILE_VERSION="6, 0, 0, 0" ORIGINAL_FILENAME="SVGExport.DLL" INTERNAL_NAME="SVGExport" LEGAL_COPYRIGHT="Copyright © 1998-2007" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x147384" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.0" UPTO_BIN_PRODUCT_VERSION="6.0.0.0" LINK_DATE="11/18/2010 07:41:07" UPTO_LINK_DATE="11/18/2010 07:41:07" EXPORT_NAME="svgexport.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="tbb.dll" SIZE="138384" CHECKSUM="0x673CAADD" BIN_FILE_VERSION="3.0.2010.406" BIN_PRODUCT_VERSION="3.0.2010.406" PRODUCT_VERSION="3, 0, 2010, 0406" FILE_DESCRIPTION="Threading Building Blocks library" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel(R) Threading Building Blocks for Windows" FILE_VERSION="3, 0, 2010, 0406" ORIGINAL_FILENAME="tbb.dll" LEGAL_COPYRIGHT="Copyright 2005-2010 Intel Corporation.  All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x25E30" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.2010.406" UPTO_BIN_PRODUCT_VERSION="3.0.2010.406" LINK_DATE="04/06/2010 10:51:42" UPTO_LINK_DATE="04/06/2010 10:51:42" EXPORT_NAME="tbb.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="tbbmalloc.dll" SIZE="41616" CHECKSUM="0xC0EFCC79" BIN_FILE_VERSION="3.0.2010.406" BIN_PRODUCT_VERSION="3.0.2010.406" PRODUCT_VERSION="3, 0, 2010, 0406" FILE_DESCRIPTION="Scalable Allocator library" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel(R) Threading Building Blocks for Windows" FILE_VERSION="3, 0, 2010, 0406" ORIGINAL_FILENAME="tbbmalloc.dll" LEGAL_COPYRIGHT="Copyright 2005-2010 Intel Corporation.  All Rights Reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x14497" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="3.0.2010.406" UPTO_BIN_PRODUCT_VERSION="3.0.2010.406" LINK_DATE="04/06/2010 10:52:52" UPTO_LINK_DATE="04/06/2010 10:52:52" EXPORT_NAME="tbbmalloc.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="TextPanelLib.dll" SIZE="221328" CHECKSUM="0xE317A6A" BIN_FILE_VERSION="8.0.0.370" BIN_PRODUCT_VERSION="8.0.0.0" PRODUCT_VERSION="8.0" FILE_DESCRIPTION="TextPanelLib Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="TextPanelLib.dll" INTERNAL_NAME="TextPanelLib" LEGAL_COPYRIGHT="Copyright 2000-2012 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3CB85" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.370" UPTO_BIN_PRODUCT_VERSION="8.0.0.0" LINK_DATE="03/28/2012 07:54:11" UPTO_LINK_DATE="03/28/2012 07:54:11" EXPORT_NAME="TextPanelLib.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="unihan.dll" SIZE="70776" CHECKSUM="0x109A966" MODULE_TYPE="WIN32" PE_CHECKSUM="0x15C17" LINKER_VERSION="0x0" LINK_DATE="05/06/2011 06:25:06" UPTO_LINK_DATE="05/06/2011 06:25:06" EXPORT_NAME="unihan.dll" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="updaternotifications.dll" SIZE="475576" CHECKSUM="0x382412A4" BIN_FILE_VERSION="6.0.0.24" BIN_PRODUCT_VERSION="6.0.0.24" PRODUCT_VERSION="6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)" FILE_DESCRIPTION="Adobe Updater Notifications Library" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe Updater Notifications Library" FILE_VERSION="6\,0\,0\,24" ORIGINAL_FILENAME="Updaternotifications.dll" INTERNAL_NAME="UpdaterNotifications.dll" LEGAL_COPYRIGHT="Copyright 2009 - 2011 Adobe Systems Incorporated. All rights reserved." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x778C7" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.0.24" UPTO_BIN_PRODUCT_VERSION="6.0.0.24" LINK_DATE="09/25/2011 06:03:54" UPTO_LINK_DATE="09/25/2011 06:03:54" EXPORT_NAME="updaternotifications.dll" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="WidgetBin.dll" SIZE="1800408" CHECKSUM="0xAEC43361" BIN_FILE_VERSION="8.1.0.420" BIN_PRODUCT_VERSION="8.1.0.0" PRODUCT_VERSION="8.1" FILE_DESCRIPTION="WidgetBin Plug-in" COMPANY_NAME="Adobe Systems Incorporated" PRODUCT_NAME="Adobe InDesign" FILE_VERSION="1.0" ORIGINAL_FILENAME="WidgetBin.dll" INTERNAL_NAME="WidgetBin" LEGAL_COPYRIGHT="Copyright 2000-2015 Adobe Systems Incorporated." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1C4778" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.1.0.420" UPTO_BIN_PRODUCT_VERSION="8.1.0.0" LINK_DATE="01/05/2015 15:30:06" UPTO_LINK_DATE="01/05/2015 15:30:06" EXPORT_NAME="WidgetBin.dll" VER_LANGUAGE="Sprachneutral [0x0]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="WRServices.dll" SIZE="1255640" CHECKSUM="0xFC4D172C" BIN_FILE_VERSION="5.2.0.1" BIN_PRODUCT_VERSION="5.2.0.1" PRODUCT_VERSION="Build 0.19574" FILE_DESCRIPTION="WRServices Engine" COMPANY_NAME="WinSoft S.A." PRODUCT_NAME="WRServices Fri Aug 16 2013 00:00:00" FILE_VERSION="5.2.0.1000" ORIGINAL_FILENAME="WRServices.dll" INTERNAL_NAME="WRServices" LEGAL_COPYRIGHT="(c) 1993 - 2012 WinSoft S.A., (c) 2007 Adobe Systems, Inc." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x13B672" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.2.0.1" UPTO_BIN_PRODUCT_VERSION="5.2.0.1" LINK_DATE="08/16/2013 14:07:14" UPTO_LINK_DATE="08/16/2013 14:07:14" EXPORT_NAME="WRServices.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x800]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Utilities\adb.exe" SIZE="815104" CHECKSUM="0xA9025388" MODULE_TYPE="WIN32" PE_CHECKSUM="0xD3594" LINKER_VERSION="0x10000" LINK_DATE="02/13/2013 15:34:09" UPTO_LINK_DATE="02/13/2013 15:34:09" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Utilities\AdbWinApi.dll" SIZE="96256" CHECKSUM="0xD2E44B28" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="2.0.0.0" PRODUCT_VERSION="2.0.0.0" FILE_DESCRIPTION="Android ADB API" COMPANY_NAME="Google, inc" PRODUCT_NAME="Android SDK" FILE_VERSION="2.0.0.0" ORIGINAL_FILENAME="AdbWinApi.dll" INTERNAL_NAME="AdbWinApi.dll" LEGAL_COPYRIGHT="Copyright (C) 2006 The Android Open Source Project" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x275C3" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="2.0.0.0" LINK_DATE="08/10/2009 20:37:22" UPTO_LINK_DATE="08/10/2009 20:37:22" EXPORT_NAME="AdbWinApi.DLL" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
                  <MATCHING_FILE NAME="Utilities\AdbWinUsbApi.dll" SIZE="60928" CHECKSUM="0x13BBF13E" BIN_FILE_VERSION="2.0.0.0" BIN_PRODUCT_VERSION="2.0.0.0" PRODUCT_VERSION="2.0.0.0" FILE_DESCRIPTION="Android ADB API (WinUsb)" COMPANY_NAME="Google, inc" PRODUCT_NAME="Android SDK" FILE_VERSION="2.0.0.0" ORIGINAL_FILENAME="AdbWinUsbApi.dll" INTERNAL_NAME="AdbWinUsbApi.dll" LEGAL_COPYRIGHT="Copyright (C) 2006 The Android Open Source Project" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x18330" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="2.0.0.0" UPTO_BIN_PRODUCT_VERSION="2.0.0.0" LINK_DATE="08/10/2009 20:37:31" UPTO_LINK_DATE="08/10/2009 20:37:31" EXPORT_NAME="AdbWinUsbApi.DLL" VER_LANGUAGE="Englisch (USA) [0x409]" EXE_WRAPPER="0x0" />
              </EXE>
              <EXE NAME="CoolType.dll" FILTER="CMI_FILTER_THISFILEONLY">
              </EXE>
              <EXE NAME="kernel32.dll" FILTER="CMI_FILTER_THISFILEONLY">
                  <MATCHING_FILE NAME="kernel32.dll" SIZE="1114112" CHECKSUM="0xB25986C" BIN_FILE_VERSION="6.1.7601.23392" BIN_PRODUCT_VERSION="6.1.7601.23392" PRODUCT_VERSION="6.1.7601.18015" FILE_DESCRIPTION="Client-DLL für Windows NT-Basis-API" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Betriebssystem Microsoft® Windows®" FILE_VERSION="6.1.7601.18015 (win7sp1_gdr.121129-1432)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. Alle Rechte vorbehalten." VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x115209" LINKER_VERSION="0x60001" UPTO_BIN_FILE_VERSION="6.1.7601.23392" UPTO_BIN_PRODUCT_VERSION="6.1.7601.23392" LINK_DATE="03/17/2016 22:33:52" UPTO_LINK_DATE="03/17/2016 22:33:52" EXPORT_NAME="KERNEL32.dll" VER_LANGUAGE="Deutsch (Deutschland) [0x407]" EXE_WRAPPER="0x0" />
              </EXE>
              </DATABASE>
              Thank you.
              • 5. Re: InDesign CS6 from Master Collection crashed permanently at "Dienstregistrierung wird gestartet..."
                I'm afraid none of that helps me, either.
                I think the next thing I would try is uninstalling, running the cleaner tool (CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3) and reinstalling the creative suite.
