5 Replies Latest reply on May 9, 2016 12:00 AM by Nanaky
    Page Numbers
    grantd68784696 Level 1
      downloaded books from overdrive to my PC (windows 7). When opened in overdrive the page #'s appear on the right hand side of the page, sometimes over the last few letters of a sentence. Can  this be fixed to have  #'s at the bottom of the page ?
        • 1. Re: Page Numbers
          Nanaky Level 5
          Do you have the probem in which Progam? Do used which os?
          • 2. Re: Page Numbers
            I am using windows 7 and an older version of ADE. Since my initial post I located and installed ADE 4.5.1 which has create a new challenge. When I try to download books from a library I get the message: “ Check Activation “  with no error code attached.    The Adobe chat line suggested I de authorize Digital additions. However when I attempt this I am asked for a email address and password. (the only password  I have is to access my Adobe account). When I use this password the system says it is incorrect. I tried changing to a new password however this was met with the same response. Any suggestions as to how one should proceed
            grant
            • 3. Re: Page Numbers
              Nanaky Level 5
              Windows:
                  Close all applications.
                  Choose Start > Run.
                  In the Open text box, type regedit and then press Enter. The Registry Editor opens.
                  In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
                  Select the Adept key.
                  Choose File > Export.
                  In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
                  Right-click the Adept key and choose Delete.
                  In the Confirm Key Delete dialog, click OK.
                  Close the Registry Editor.
                  Open Adobe Digital Editions and reauthorize.
              Macintosh:
                  quit Adobe Digital Editions.
                  Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
                  If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
              • 4. Re: Page Numbers
                Good Evening
                Thanks for the advice . this resolved the problem
                Grant
                • 5. Re: Page Numbers
                  Nanaky Level 5
                  You are welcome.
