10 Replies Latest reply on Apr 25, 2016 5:56 AM by LouieWarren
    Context validation error for tag cfset.
    LouieWarren Level 1
      I have a ColdFusion 10, front end on a Windows 2008 R2 (VMWare) machine interfacing with an Oracle 11g database.  I recently had an issue (https://forums.adobe.com/thread/2121425http://)  that was solved by changing this.datasource to application.datasource.   Shortly after, I was tracking  down some other issues, specifically one where a CFMAIL tag was not loading output of a query.  I toyed with it, even trying to brute force the TO address in there, and just caused other problems.  Since I am working with a copy on my Test server, I decided to start over.  I copied the two files that I had been working on from the copy on my Development machine that has not been touched since it was promoted to Test, expecting to see the CFMAIL error again.   Instead I see:
      When I go to tline 76 in the module listed, that line is completely blank.   I am baffled as to what needs to be done to get back to the original error.
        • 1. Re: Context validation error for tag cfset.
          WolfShade Level 4
          If you're using Dreamweaver, use CTRL-F on that document and do a RegEx search for
          <[\s\/]cfset>
          HTH,
          ^_^
          • 2. Re: Context validation error for tag cfset.
            BKBK Adobe Community Professional & MVP
            Hi LouieWarren,
            It doesn't exactly have to be line 76 in your text editor. It might be the line before or after that. The error might even come from an included page.
            Check every <cfset> from lines 70 to 80, say. The error message suggests at least one of them has an end tag. Perhaps something like this
            <cfset someVar = "some value" />
            • 3. Re: Context validation error for tag cfset.
              WolfShade Level 4
              Hi, BKBK,
              Isn't <cfset someVar = "some value" /> a valid format for the cfset tag?  I've been using the trailing slash for years, and never had a problem with it.
              V/r,
              ^_^
              • 4. Re: Context validation error for tag cfset.
                Hi WolfShade,
                You're probably right. The offending code is more likely to be
                <cfset someVar = "some value"></cfset>
                • 5. Re: Context validation error for tag cfset.
                  LouieWarren Level 1
                  Here's line 70 - 81 of the module identified:
                  70
                  71  if(document.form1.Priority.value=="")
                  72  {alert("Please select the Priority")
                  73  document.form1.Priority.focus()
                  74  document.form1.problem.select()
                  75  return false}
                  76
                  77  if(document.form1.problemarea.value=="")
                  78  {alert("Please select a Problem Area")
                  79  document.form1.problemarea.focus()
                  80  document.form1.problem.select()
                  81  return false}
                  • 6. Re: Context validation error for tag cfset.
                    LouieWarren Level 1
                    I'm using Expression Web 4 because my customer didn't want to spend the money for DreamWeaver.   I will do the matching of <cfset> tags and post whatever I find.
                    • 7. Re: Context validation error for tag cfset.
                      WolfShade Level 4
                      I'm not familiar with Expression Web, but not shelling out for DW is (IMHO) reasonable since DW really doesn't support CF tags, anymore.  With the advent of HTML5, Adobe wanted DW to be more of a front-end IDE than a back-end.
                      Does Expression Web have the ability to search for source code using regular expressions?
                      V/r,
                      ^_^
                      • 8. Re: Context validation error for tag cfset.
                        LouieWarren Level 1
                        OK, I'm an idiot.  I posted the code fragment of the page that referring.cfm file.  When I checked the actual .cfm file causing the error, I found 12 <cfset  something=something> in that code but not a </cfset> in the bunch.  I added the /> to each of the 12 and now I am back to my original error:  I have not touched this file except the datasource issue I had earlier.  The Production version has the non-terminated <cfset> assignments and works just fine.
                        CurrentPage = MyAppt/App_New/secure/helpdesk/newchangerequest.cfm
                        Call from = https://App_New//secure/helpdesk/add_changerequest.cfm
                        MESSAGE = Attribute validation error for CFMAIL.
                        LOCATION = Code location is not available
                        TAGNAME = CFMAIL
                        ERROR = Error
                        WARNING = Info
                        DETAIL = The value of the TO attribute is invalid. The length of the string, 0 character(s), must be greater than or equal to 1 character(s).
                        ATTRIBUTE = TO
                        KNOWNCOLUMN = -1
                        KNOWNLINE = -1
                        COLUMN = -1
                        KNOWNTEXT = <unknown>
                        FEATURENAME = CFMAIL
                        LINE = -1
                        CATEGORY = Tag
                        SEVERITY = Error
                        REMEDY = Try The Following:
                        After looking at this, I am assuming it can't extract the e-mail address from the user database.  I have it in the database on development that I dumped and sent to the gov't DBA for import.   I will have him run the query to see if the value is valid and then report back.
                        In the event it isn't screwed data...  is there a possible way I can brute force it and hardwire the code to just make all the TO addresses my e-mail address?  I'm supposed to get all mail anyway.  Just curious.  This is taking time they don't want to let me have.
                        Thank you all so much for your help on all of this.   You have definitely helped this old man out.
                        • 9. Re: Context validation error for tag cfset.
                          I am confused. Are you asking a new question? Is your original issue resolved? If it is, then please mark the answer that helped you or share your solution with us. Answers help.
                          If you wish to discuss a new issue, then please start a new thread.
                          • 10. Re: Context validation error for tag cfset.
                            LouieWarren Level 1
                            I apologize.   I get so caught up in troubleshooting, I forget protocol.  I did mention my initial error was a CFMAIL error, so I assumed this was fine.  I am currently ruling out whether or not the data is bad in the database before I submit another thread.
                            The problem:
                            12 instances of <cfset someVar = "some value" > with no end tag.
                            The solution
                            Changed all 12 instances to <cfset someVar = "some value" />
                            Problem solved.  Thank you.
