2 Replies Latest reply on Apr 23, 2016 12:41 PM by Ann Bens
    Image Size | Re-size to a Smaller Size | Why?
    BruceTR
      Premiere Elements 14.
      I'm creating a movie that contains .jpg images, and .mp4 and .mov clips. The movie will be exported in 1920 x 1080 progressive.
      My images are 3456 x 2304 and 4272 x 2848, both are 72 dpi.
      I've watched a tutorial in which the author recommended re-sizing images to 2000 x 1333. I've read advice in this forum that recommends re-sizing images to a maximum 2500 x 1875.
      I'm curious... what is the reason for re-sizing images?
      Also, if an image needs to be adjusted (color, lighting, etc.), should the image be adjusted before, or after, it's re-sized?
      Thanks for your insights.
        • 1. Re: Image Size | Re-size to a Smaller Size | Why?
          Video resolutions are either standard 720x480 pixels or high-resolution 1920x1080 pixels. There is no value to adding a huge photo to a video project -- the program will need to down-rez it to video resolution.
          We've found that the closer the photo is the video's resolution, the more efficiently the program will handle it -- and the better your photos will look in your videos.
          And, since we also want to allow a little extra resolution so you can do some panning and zooming, we usually recommend 1000x750 pixels for photos used in a standard resolution video or DVD and somewhere between 2000x1500 and 2500x1875 for high-resolution or BluRay projects.
          But not only does the program get less efficient the larger your photos are, the program actually has a maximum load size. If you try to load too large a photo into the program, the program will reject it outright.
          As a rule, the closer to the video's resolution and more "done" the photo's cleanup before you add it to your video project, the better it will look in your movie.
          • 2. Re: Image Size | Re-size to a Smaller Size | Why?
            DPI means nothing in video. Only thing that counts is the height and width in pixels.
            If you want to do some panning and zooming 2x the framesize is sufficient.
