1 Reply Latest reply on Jun 6, 2006 4:52 AM by Newsgroup_User
    A tricky one - trig / action script
    Tolk Level 1
      I'm using AS to try and draw a sector of a circle.
      say i start from co-ords (0,0)
      i lineTo(0,50)
      then i want to start a curve that will end up at (x,y) - depending on the angle of the sector
      then lineTo(0,0) to complete the sector
      This is probably more of a trig question than AS how can i calculate the points for the controlX and controlY properties of the curveTo function. I'm not sure how AS handles the control points and what relative distance they have to be from the anchor points to make the curve section of the sector appear as part of a complete circle rather than having a funny bulge in the circle. Ideally i want this to work for any angle of the sector, always starting from (0,0) with same radius (50) but with different starting point for curve . I can work out the anchor points for the curveTo but i can't figure out how to calculate the control points.
      Anyway i hope someone can help me!
        • 1. Re: A tricky one - trig / action script
          Level 7
          I'd draw the circle/arc using regular drawing techniques instead of trying
          to use control points. If you're resolution is fine enough you won't be able
          to tell anyway. Here's an arc function for ya:
          function drawArc(mc:MovieClip, x:Number, y:Number, radius:Number,
          angStart:Number, angEnd:Number):Void {
          var rs = angStart / 57.29578;
          var re = angEnd / 57.29578;
          mc.lineStyle(0, 0x000000);
          mc.moveTo(x, y);
          for (var t = rs; t < re; t += .01) {
          mc.lineTo(radius * Math.cos(t) + x, radius * Math.sin(t) + y);
          mc.lineTo(x, y);
          Dave -
          Adobe Community Expert
