25 Replies Latest reply on May 5, 2016 11:51 AM by ipolans
    Want to extract document metadata and doc info via a script
    ipolans
      I'm not a Javascript nor Java programmer so I might be missing one or more steps.
      Looking at the Javascript info I have I see the following code:
      var r = new Report();
      r.writeText(this.metadata);
      r.open("myMetadataReportFile");
      save("/c/myreport.pdf"));
      The code doesn't seem to be working when run from the console. If I execute "this.metadata" I get the information that I expect. This suggests that the problem is with report creation and or saving the document.
      I haven't yet figured out how to get information out of the Doc Info dictionary.  This is another need.
      NOTE: In both cases (XMP and DocInfo) we're adding CUSTOM metadata.
      Ideally I'd like to save both sets of information XMP and DocInfo as XML . This way we can run a comparison between the two.
      Finally whatever code I end-up with needs to be able to run in the Action Wizard over about 10,000 files. If the input file is "file.pdf" the output should be "file.xml"
      Thanks.
      Ira
