2 Replies Latest reply on Jan 6, 2009 11:50 PM by orca2007
    Remoting Java Externalizable long
    orca2007
      Hi there.
      I have the following problem:
      I like to use Remoting with my own externalize implementation between a java and a as3 class.
      Everthing works fine except the transmission of a member of type long in the jave class.
      The only combination which works without runtime erros is:
      Write: Java: writeLong AS3: writeDouble
      Read: Java: readLong AS3: reabDouble
      But the values i get for the member are not correct on both sides.
      Java long value: 2 AS3 Number value: 1.9762625833649862e-323
        • 1. Re: Remoting Java Externalizable long
          Zee Yang Level 1
          can you post the code of how you serialized between java and as3?
          • 2. Re: Remoting Java Externalizable long
            orca2007 Level 1
            Java:
            public void readExternal(ObjectInput in) throws IOException, ClassNotFoundException
            id = (String)in.readObject();
            name = (String)in.readObject();
            description = (String)in.readObject();
            price = in.readLong();
            public void writeExternal(ObjectOutput out) throws IOException
            out.writeObject(id);
            out.writeObject(name);
            out.writeObject(description);
            out.writeLong(price);
            AS3:
            public function readExternal(input:IDataInput):void
            id = input.readObject() as String;
            name = input.readObject() as String;
            description = input.readObject() as String;
            price = input.readDouble();
            public function writeExternal(output:IDataOutput):void
            output.writeObject(id);
            output.writeObject(name);
            output.writeObject(description);
            output.writeDouble(price);
