5 Replies Latest reply on Apr 27, 2016 3:12 AM by moccamaximum
    Javascript Error Occurred at line 96 of file: "utils.jsfl": out of memory
    leftybenno Level 1
      Hi Guys,
      I am a relative newbie to Animate and I'm using it to create lighting effects for an artwork for a client. I'm animating a dot to trace the path of some ellipses at high speed, hopping from one to another. I have gotten about 90 seconds into the animation (target length is 20 minutes!) and can no longer export due to this error:
      I have all the possible paths placed on a layer as primitive drawing objects and create the motion by placing an instance of a dot on a layer, creating a motion tween and pasting the primitive object onto that layer to create the motion path. There is a lot of easing going on to emulate the effect of gravity.
      I have the most up to date version of Animate installed. You can grab a copy of the project here if taking a look might yield some suggestions:
      Dropbox - P1500 Wellington St Busport West Portal Rev2.fla
      Any suggestions would be helpful - progress has halted and my client will be pretty annoyed at the delay
      Thanks in advance.
      Ben
