1 Reply Latest reply on Apr 26, 2016 3:24 AM by Nanaky
    I can't authorise my computer. Problem since changing my hard drive?
    markb86415700
      February 2015 my hard drive and mother board failed. Apple replaced the mother board and I paid for a new solid state hard drive.
      Since then, my Digital Reader has not functioned.
      I now urgently need to download an ebook for work purposes and I'm not able to do so.
      Same problem a year ago but I never pursued the problem to a conclusion. Now I must.
      WHY CAN'T I AUTHORISE MY COMPUTER WITH A NEW HARD DRIVE?
      This is Adobe's solution to solving problems? A forum? Unbelievable.
      I can no longer read my ebooks. When trying to authorise my computer I continually get this message:
      An Error Has Been Detected
      Activation Server error - code E_AUTH_NOT_READY
      Digital Editions encounter an error on the activation server.
      I've purchased a new ebook today and it won't open.
      I get the same message as above when I try to authorise my computer?
        • 1. Re: I can't authorise my computer. Problem since changing my hard drive?
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
