• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
as3 code open microsoft outlook . is that possible
Contributor ,
Apr 26, 2016 Apr 26, 2016
i need simple as3 code that can open microsoft outlook. once i click the flash button it should navigate me to microsoft outlook .
note : i do not want to load microsoft out look in flash stage . rather once i click a button of .swf stage . then it will open microsoft out look of my windows 7
Any suggestion ?
thanks
TOPICS
ActionScript
Views
501
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Apr 27, 2016 Apr 27, 2016
import flash.filesystem.File;
import flash.desktop.NativeProcess;
import flash.desktop.NativeProcessStartupInfo;
var process:NativeProcess = new NativeProcess();
var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
var exe:File = new File();
exe.nativePath = "C:/Program Files/Microsoft Office/Office15/Outlook.exe";
nativeProcessStartupInfo.executable = exe;
var args:Vector.<String> = new Vector.<String>();
args.push('/sniff');
nativeProcessStartupInfo.arguments = args;
pr
Votes
Translate
Translate
LEGEND ,
Have you tried using a mailto link (URLRequest) such that the default browser opens?
I don't think there is any way you can target a specific application to open on someone's machine using AS3... that would be the equivalent of a nasty viral infestation if you could do that.
Votes
Translate
Translate
Report
Report
Enthusiast ,
As long as you're running on AIR you can open anything you like.
Votes
Translate
Translate
Report
Report
Enthusiast ,
process.addEventListener(NativeProcessExitEvent.EXIT, appClosed);
//start the process
process.start(nativeProcessStartupInfo);
function appClosed(e:NativeProcessExitEvent):void
  process.removeEventListener(NativeProcessExitEvent.EXIT, appClosed);
  trace("closed");
Here's a little code that will open Outlook on my machine. The args let you send command line switches, like /sniff which forces outlook to update meeting requests and such. You will need to publish to AIR and use the Extended Desktop profile.
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
sorry an error occured
The application cannot be installed due to a certificate problem.  The certificate does not match the installed application certificate, does not support application upgrades, or is invalid.  Please contact the application author.
Votes
Translate
Translate
Report
Report
