2 Replies Latest reply on Apr 27, 2016 2:30 PM by kenm33329161
    Adding Qualifier and Unit to InDesign Dictionary.
    kenm33329161
      Is there a way I can get InDesign to recognise units (such as centimetre abbreviated to 'cm') together with the preceding qualifier, i.e. 3cm or 6cm, or 30mph?  It is frustrating that each time I write a different, for example, distance or speed, it is seemingly identified as a 'new word'. InDesign obviously recognizes a preceding qualifier (i.e. $34.78) but not a following qualifier. Engineers, and others, require the qualifier 'one with' the unit so simply adding 'cm' as a word and leaving a space is not an option. Many thanks. Ken
        • 1. Re: Adding Qualifier and Unit to InDesign Dictionary.
          Eugene Tyson Adobe Community Professional & MVP
          I'd say that it's because the $ is a symbol and 3cm where 3 and C and M are all individual characters.
          You could do a search for in GREP
          \d+?(cm|mm|mph)
          Change to
          Leave blank
          Change formatting
          Double click the empty box there - and navigate to Advanced Formatting and set it to No Language.
          Alternatively, if you're using Paragraph Styles
          Setup a new character style called No Language - and in the Advanced Formatting section set it to No Language
          In the Paragraph Style go to GREP and insert
          \d+?(cm|mm|mph)
          and choose the new No Language
          This sets the \d (digit) + (keep looking for digits) ? (stop looking at end of string) (cm|mm|mph) where the brackets indicate a group and the pipe | indicates OR
          Of course this also means that if it's 10.45cm or 10.456 cm it won't work - well it will find either .45cm and not .456 cm as there's a space.
          So you could do
          \d+?\.\d+?(cm|mm|mph)|\d+?(cm|mm|mph)
          Not sure how well that would work though - as I haven't tried it.
          • 2. Re: Adding Qualifier and Unit to InDesign Dictionary.
            kenm33329161 Level 1
            Eugene,
            Thank you very much for taking the time and trouble to respond to my query.
            I haven’t yet tested it out but am confident enough to guess you know what you are talking about – you certainly sound as though you do! – and have marked your answer as ‘Correct’.
            Once again, many thanks.
            With kind regards,
            Ken
            Perth, Western Australia
