• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Update ANE with AIR 22 is not working anymore
Explorer ,
Apr 27, 2016 Apr 27, 2016
I have a simple ANE which shares File.
It was built with AIR 19.0 and Xcode 6.1.
I want to update to AIR 22, but you have updated the iOS SDK, I have installed XCode 7.3, base SDK is iOS 9.3 and iOS Deployment target is iOS 9.0.
I have a platform.xml like this.
<sdkVersion>9.0.0</sdkVersion>
    <linkerOptions>
        <option>-framework AudioToolbox</option>
        <option>-framework AVFoundation</option>
        <option>-framework CFNetwork</option>
        <option>-framework CoreFoundation</option>
        <option>-framework CoreGraphics</option>
        <option>-framework CoreLocation</option>
        <option>-framework CoreMedia</option>
        <option>-framework CoreVideo</option>
        <option>-framework Foundation</option>
        <option>-framework MobileCoreServices</option>
        <option>-framework OpenGLES</option>
        <option>-framework QuartzCore</option>
        <option>-framework Security</option>
        <option>-framework SystemConfiguration</option>
        <option>-framework UIKit</option>
        <option>-framework ImageIO</option>
        <option>-framework CoreTelephony</option>
    </linkerOptions>
My code to share a file is, in objective-C, where the variable URL is a NSURL, the path of a local file
@try {
            UIViewController * controler = [[[[UIApplication sharedApplication] windows] objectAtIndex:0] rootViewController];
            UIActivityViewController *activityVC = [[UIActivityViewController alloc] initWithActivityItems:@[URL] applicationActivities:nil];
            //activityVC.excludedActivityTypes = @[UIActivityTypePrint, UIActivityTypeCopyToPasteboard, UIActivityTypeAssignToContact, UIActivityTypeSaveToCameraRoll]; //or whichever you don't need
            UIPopoverController *popup = [[UIPopoverController alloc] initWithContentViewController:activityVC];
            [popup presentPopoverFromRect:CGRectMake(0,0,0,0) inView:controler.view permittedArrowDirections:UIPopoverArrowDirectionAny animated:YES];
        @catch (NSException *exception) {
            DISPATCH_STATUS_EVENT(context,"DEBUG_TRACE", (const uint8_t*) [exception.reason UTF8String]);
I have this error at execution: *** -[__NSPlaceholderArray initWithObjects:count:]: attempt to insert nil object from objects[0]
UIPopoverController is deprecated now, I triied to update my code, following this http://www.goxuni.com/672368-adding-a-share-button-to-an-objective-c-ios-app/
And the result is:
@try {
            NSArray *activityItems = @[URL];
            UIActivityViewController *activityViewControntroller = [[UIActivityViewController alloc] initWithActivityItems:activityItems applicationActivities:nil];
            activityViewControntroller.excludedActivityTypes = @[];
            activityViewControntroller.modalPresentationStyle = UIModalPresentationFullScreen;
            if (UI_USER_INTERFACE_IDIOM() == UIUserInterfaceIdiomPad)
                activityViewControntroller.popoverPresentationController.sourceView = controler.view;
                activityViewControntroller.popoverPresentationController.sourceRect = CGRectMake(controler.view.bounds.size.width/2, controler.view.bounds.size.height/4, 0, 0);
            [controler.self presentViewController:activityViewControntroller animated:true completion:nil];
The error is the same: *** -[__NSPlaceholderArray initWithObjects:count:]: attempt to insert nil object from objects[0]
I really don't understand why this was working before, and now with new AIR SDK, new Xcode and new iOS SDK, it's not working.
TOPICS
Air beta
Views
651
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , May 12, 2016 May 12, 2016
Votes
Translate
Translate
Explorer ,
LATEST
Votes
Translate
Translate
Report
Report
