2 Replies Latest reply on May 3, 2016 1:50 PM by tarekahf
    New Root appears for data when rendering form
    tarekahf Level 2
      We are using the sample code below to render the form.
      Just recently, we noticed that when the form is rendered and the XML is exported using Adobe Acrobat, we see a new root showing on top of the previous root node. For example, of the data structure looks as follows:
      <root>
        <customer_name>John</customer_name>
      </root>
      it will become like the following:
      <xfa:data>
        <root>
        </root>
      </xfa:data>
      Sample code used:
          PDFFormRenderSpec pdfFormRenderSpec = new PDFFormRenderSpec(
          true, //boolean cacheEnabled
          null,//PDFVersion
          true,//boolean taggedPDF
          false,//boolean linearizedPDF
          null,//String seedPDF
          AcrobatVersion.Acrobat_9,
          null,//String xCIURI
          sCharSet,//String charset
          RenderAtClient.Yes,//key to dynamic forms!
          sLocale,// locale
          false, //standAlone
          FormModel.both,
          false//setXML
                  //Specify URI values that are required to render a form
                  URLSpec uriValues = new URLSpec();
                  uriValues.setContentRootURI("repository:///");
                  //Invoke the renderPDFForm method and write the
                  //results to a client web browser
                  FormsResult formOut = formsClient.renderPDFForm(
                              formName,               //formQuery
                              oInputData,             //inDataDoc
                              pdfFormRenderSpec,      //PDFFormRenderSpec
                              uriValues,                //urlSpec
                              null            //attachments
                  //Create a Document object that stores form data
                  myData = formOut.getOutputContent();
                  myData.passivate();
                  myData = readerExtensionsApply(sRECert, myFactory, myData);
      Appreciate your help to resolve this problem.
      Tarek
