7 Replies Latest reply on May 4, 2016 7:07 PM by #1Artist
    Does this look like a good laptop for editing Premiere Pro?
    #1Artist
      I've done a lot of searching and I like the custom configurations that are possible at XoticPC. An older model of a ROG laptop has a metal top and was preferred by reviewers of newer ROG models with plastic tops. XoticPC includes a newer CPU and because the starting price is low for an older model, I'm able to push RAM up to 32GB and get a Samsung 500GB SSD plus a 1T HD for less than a newer model with less speed. Also, since XoticPC is putting it together, I'm adding copper cooling. Any suggestions welcome. Here is the $1395 configuration:
      My Account
      xoticpc
      Toll Free: 1-877-289-9684
      facebooktwitterinstagramgoogleyoutube
      LAPTOPSDESKTOPSACCESSORIESSUPPORTCOMMUNITYCOMPANYCONTACT
      XOTIC PC Saved Configuration 8898
      ASUS GL551VW-DS71
      Thermal Cooling
      1 x Stock Thermal Compound $0.00
      The XOTIC PC Difference
      1 x XOTIC PC EPIC® Support - LIFETIME Phone/Email U.S. based technical support | Extreme QA testing by dedicated technicians | 24-72 Hour stress testing and benchmarking to ensure top performance and stability $0.00
      Display
      1 x 15.6" FHD (16:9) Anti-Glare Matte-Type Screen (1920x1080) $0.00
      Warranty
      1 x 1 Year ASUS North America OEM Warranty Support / 1 Year North America (N.A.) Accidental Coverage (Accidental Requires Registration)$0.00
      Operating System
      1 x Microsoft Windows 10 Home - 64-Bit - Default (Pre-installed - No Media) $0.00
      Promotions
      1 x STORAGE UPGRADE! External 1TB 7200RPM USB 3.0 SATA Hard Drive only $10 [Select Below] $0.00
      Display Options
      1 x ASUS Zero Bright Dot (ZBD) 30 Day Pixel Guarantee - (Included on ASUS Standard NON-Upgraded Displays) $0.00
      Processor
      1 x 6th Generation Intel® Skylake™ i7-6700HQ (2.6GHz - 3.5GHz, 6MB Intel® Smart Cache) Processor $0.00
      Graphics Video Card
      1 x NVIDIA® GeForce™ GTX 960M (4.0GB) GDDR5 PCI-Express DX12 (Maxwell) w/ Optimus™ Technology $0.00
      Ram
      1 x 32GB (2x16GB) DDR4 2133MHz Dual Channel Memory $185.00
      2.5" Bay 1
      1 x 500GB Samsung 850 Evo SSD (Read 540MB/s - Write 520MB/s (SSD2 - SATA III)) $159.00
      Optical Drive
      1 x ON SALE!! 1TB 7200RPM (SATA III 6GB/s) in ODD Bay $95.00
      Wireless / Bluetooth
      1 x Built-in Dual Band Wireless-AC 802.11 AC/A/B/G/N - Stock Wireless Card + Bluetooth 4.0 $0.00
        • 1. Re: Does this look like a good laptop for editing Premiere Pro?
          JFPhoton Level 3
          ...I am currently using an "older" Asus G750JW gaming laptop with lesser specs than yours with no problems. In fact, I am running TWO separate WQHD ( 2560 x 1440p ) IPS monitors at 60 fps each in addition to the native display.
          Only two things catch my eye. If you have two internal 2.5" SATA IIIdrive bays, you want to make the best use of that feature.
          The "EVO" drives have an inferior controller compared to the Samsung 850Pro series.....if you can upgrade to the 850 pro SSD for your boot drive, that would be ideal.....at least a 500 GB model...they are more durable. This drive should only have the OS, programs, and Windows page file on it. You MAY also place your "media cache" and "cache" files here. Testing done by Bill Gehrke has shown there is NO difference in performance when doing so AND those files are easily erased after a project is completed. ALL other files need to go on the second SSD.
          In the second bay, you want a very fast drive for your media, and all other files not on the boot drive. There is a large difference in performance using a fast SSD here, instead of a slow,spinning drive. Put a larger Samsung 850 pro there....at least a 1 TB  SSD.
          Be aware that even over just a USB 3 port, a Samsung external SSD like a T1, or, T3 model will perform at over 400 MB / sec read and write using the USAP protocol. I have a T1....it works GREAT !
          My laptop has the option to place the 2 internal SSDs into a RAID 0 array for maximum performance of about 1 GB/ sec read and write, but, I have not used it as I cannot figure a good way to back it up. If you did the RAID, ALL files just would go on it !
          In any case, that laptop is great.....only the drives are of a concern......32 GB memory is great, 4 GB video memory is great, the CPU is very good as it turbos nicely.
          • 2. Re: Does this look like a good laptop for editing Premiere Pro?
            Bill Gehrke Most Valuable Participant
            Completely agree with JF.  Forget the hard drive and go all SSD.  Also get your self one of the Samsung new T3 drives if you need more/removable storage.  Double check with Xotic on the "1 x ON SALE!! 1TB 7200RPM (SATA III 6GB/s) in ODD Bay $95.00"  In many ODD bays the interface port is only SATA II and plugging in a fast SATA III device is of little or no value.  Just because the drive is a SATA III does not mean you would ever get that performance like using that device to hold a SATA III SSD.
            I have a Sony FDR-AX100 which records XAVC S 4K 100 Mb/s and it edits this and lower resolution media very smoothly.  Notice I did not say it works with the more demanding XAVC pro media.
            • 3. Re: Does this look like a good laptop for editing Premiere Pro?
              #1Artist Level 1
              Thanks so much for the tips. It looks like Gigabyte has more to offer. I
              really like the tip on the new Samsugn T3
              On Thu, Apr 28, 2016 at 6:11 PM, Bill Gehrke <forums_noreply@adobe.com>
              • 4. Re: Does this look like a good laptop for editing Premiere Pro?
                #1Artist Level 1
                I have used the helpful information above regarding Samsung 950 Pro M.2 NVMe PCIe SSD speed. I have configured two more options below. The ASUS UX501V2-DS71 option would be used with the recommended Samsung T3 1TB USB 3.1 External SSD for an additional $378.
                1.
                ASUS UX501VW-DS71T Touch
                Thermal Cooling
                Promotions
                1 x FREE! – FEDEX Ground SHIPPING [U.S. Lower 48 ONLY / Restrictions Apply] $0.00
                Display
                1 x 15.6" 4K QFHD IPS (16:9) Glare-Type Glossy Touch Screen (3840x2160) $0.00
                Warranty
                1 x 1 Year ASUS North America OEM Warranty Support / 1 Year North America (N.A.) Accidental Coverage (Accidental Requires Registration) $0.00
                Operating System
                Display Options
                Processor
                Graphics Video Card
                1 x NVIDIA® GeForce™ GTX 960M (2.0GB) GDDR5 PCI-Express DX12 (Maxwell) w/ Optimus™ Technology $0.00
                Ram
                1 x 16GB (2x8GB) DDR4 2133MHz Dual Channel Memory Default $0.00
                M.2 SATA / PCIe / NVMe SSD Drive Slot 1
                1 x 512GB Samsung 950 Pro M.2 NVMe PCIe SSD (Read 2500MB/s - Write 1500MB/s 110K IOPS) $199.00
                or 2.
                GIGABYTE P35Wv5-SL2
                Thermal Cooling
                Display
                Warranty
                1 x 2 Year GIGABYTE Warranty $0.00
                Operating System
                Promotions
                1 x FREE! - Rise of the Tomb Raider when you buy a GeForce GTX 960, 970, 980, and 980 Ti (excluding Titan X) or GTX 970M, 980M and 980 Notebooks $0.00
                Processor
                Graphics Video Card
                1 x NVIDIA® GeForce™ GTX 970M (6.0GB) GDDR5 PCI-Express DX11 (Maxwell) w/ Optimus™ Technology $0.00
                XOTICFX Backlit Keyboard
                1 x Standard White Backlit Keyboard $0.00
                Ram
                1 x 32GB (2x16GB) DDR4 2133MHz Dual Channel Memory $145.00
                M.2 SATA / PCIe / NVMe SSD Drive Slot 2
                1 x 512GB Samsung 950 Pro M.2 NVMe PCIe SSD (Read 2500MB/s - Write 1500MB/s 110K IOPS) $399.00
                1 x 512GB Samsung 950 Pro M.2 NVMe PCIe SSD (Read 2500MB/s - Write 1500MB/s 110K IOPS) $349.00
                2.5" Bay 1
                1 x 2TB 5400RPM Samsung Spinpoint M9T (SATA - 6GB/s) $69.00
                Raid
                1 x RAID-0 (Stripe) Combines for performance $0.00
                Optical Drive
                1 x Slim - 8x Super Multi DVDRW/CDRW Combo Drive (Dual Layer w/ Software) - Default $0.00
                Optical Drive Options
                1 x Optical Bay Hard Drive Caddy (Caddy Only) Used For Installing Your Own Hard Drive (Optical Drive Bay remains as selected) $0.00
                Option 1 is more affordable and it only has one  512GB Samsung 950 Pro M.2 NVMe PCIe SSD but it will be connected to the new 1T T3 external drive. Option 1 would cost $2,025. Option two would be $2,533. The ASUS has had some complaints regarding the flimsy, reflective screen( although it is 4K) and it will be limited to 16GB RAM. The Gigabyte P35 includes 32GB RAM plus 6GB Video whereas the ASUS has 2GB for video. All suggestions appreciated. I am so much more informed from your help.
                • 5. Re: Does this look like a good laptop for editing Premiere Pro?
                  "1 x RAID-0 (Stripe) Combines for performance $0.00" I sure hope you were not RAIDing those two 950 PRO's  Individually they are as much performance as you could want.
                  I sure do like the two Samsung 950 Pro M.2 SSD's plus a standard 2.5" slot which has the 2TB 5400 rpm drive which is not usable for editing but if you use it for on-line archiving would be OK.  If you needed to cut some money you could drop the OS/Applications 950 SSD to 256 GB.
                  • 6. Re: Does this look like a good laptop for editing Premiere Pro?
                    #1Artist Level 1
                    Here is third option from ProStar:
                    P35Xv5-SL4K2 $2,299.00$2,299.00
                    Screen15.6" 3840x2160 4K Samsung IPS (16:9) LED Backlit Glare Type Display
                    Special OfferNo 2016 Sales begin now!
                    Special Offer 2No 2016 Sales begin now!
                    Special Offer 3No 2016 Sales begin now!
                    ProcessorIntel Core i7-6700HQ 2.6 Ghz, Processor (Max Turbo Frequency 3.5GHz), 6MB Smart Cache
                    Thermal CompoundGigabyte OEM Thermal Compound CPU+GPU
                    Main Memory32GB DDR4 2133MHz - 2 x 16GB1$119.00$119.00
                    Graphic CardsNVIDIA GeForce GTX 980M w/8GB GDDR5
                    mSATA SSD Drive256GB SAMSUNG 950 Pro NVMe M.2 PCI-Express Gen 3x4 SSD1$129.00$129.00
                    mSATA SSD 2nd Drive256GB SAMSUNG 950 Pro NVMe M.2 PCI-Express Gen 3x4 SSD1$129.00$129.00
                    Hard Drive1,000GB Samsung 850 EVO Series Solid State Drive (Up to Sequential Read 540MB/s - Turbo Write 520MB/s Serial-ATA III)1$369.00$369.00
                    Optical Drive6x Max. Blu-Ray Writer/Reader / 8x Max. DVD±R/2.4X Max. +DL Super-Multi Drive
                    External Optical DriveN/A
                    Operating SystemWindows 10 Home 64-bit Pre-load (No Media)
                    Microsoft OfficeNo Microsoft Office
                    BatteryLi-Polymer Battery Pack
                    Integrated Wireless LanGigabyte Wireless Lan 802.11 A/C + Bluetooth (v4.0) Combo
                    Integrated BluetoothPlease Check Option in Integrated Wireless Lan Section
                    Keyboard BacklitFull Color Programmable Backlight
                    LCD ProtectionNone
                    Warranty ServiceGigabyte 2 Year Global Warranty (Registration Required)
                    Priority Service on AssemblyNo, ready to ship in 5 business days
                    Standard Accessories
                    • Built-In HD Web Camera
                    • Built-In Gigabit Ethernet LAN
                    • Built-In SD Memory Card Reader
                    • Additional caddy-Swappable Storage for ODD/HDD/SSD/empty bay
                    • 3 USB 3.0 Ports (Type-A)
                    • 1 USB 3.1 Ports (Type-c)
                    • 1 HDMI Output
                    • 1 D-Sub Port
                    • 1 Mini-Display Port
                    • 1 Audio Jacks for Headphone-Out and Microphone-In
                    • 1.5W Speakers x2, Dolby Digital Plus Home Theater
                    • 1 100/240V Autoswitch AC Power Adapter
                    • 1 Year Gigabyte Battery Pack and AC Adapter Warranty
                    Additional AccessoriesTheramltake Massive23 LX USB Cooling Fan Tray (XB-1010-US)1$49.00$49.00
                    Sub Total:$3,094.00
                      Shipping Method: UPS Ground Service
                    UPS 3 Day Select [$59.00]
                    UPS 2nd Day Air [$85.00]
                    UPS Next Day Air [$115.00]
                    US Postal Service [$80.00]
                    Ground Shipping to Canada [$55.00]
                    Priority Shipping to Canada (1-2 days) [$109.00]
                    International Order (quote)
                    It comes out to $3,001 with cash discount. Whatever that means? This is 4K and I think two 256GB Pro Pci will be enough to feed the 1T Samsung SSD.
                    • 7. Re: Does this look like a good laptop for editing Premiere Pro?
                      #1Artist Level 1
                      Bill, thanks for the link to ADK. I'm more of an audio person than video and they do both.
                      The reason I started this search was because my older Dell laptop was full of errors and programs were stopping for no reason. I suspect that a hacker was into my network. I reinstalled win 10 and removed all programs. Following a tutorial, I assigned a new ip address. This thing is running fine now. I have learned so much about M.2 PCIe storage and will follow the development of this fast storage in more and more laptops. HP is adding it to a new laptop coming out this month. Since I no longer have a laptop problem, I'll keep watching. I think I will eventually build a HTPC desktop with video and audio editing hardware included. I've built a few audio recording computers in the past. It really is very simple.
