6 Replies Latest reply on Apr 28, 2016 5:27 AM by karthiks94217840
    Multi script coding insert to dialog box
    karthiks94217840 Level 2
      Dear Friends,
      I was trying to script for "Multi script coding add to single script". I need to use dialog box. Since, i have done dialog box coding (See below my coding).
      But, i don't now how to add multi script coding in the dialog box inside?
      My Requirement: I want select any one script button. I need to run that select script code only. Otherwise, other script code no needed to run.
      Example:
      1. I will pick 1 script "01_Overrodes" just i want to run this script only.
      2. I will pick 2 script "02_FindText" just i want to run this script only.
      3. I will pick 3 script "03_Alert_Basic Replace" just i want to run this script only.
      var
        w=new Window("dialog", "Action List"),
        radio=w.add("panel", undefined, "Choose Action"),
        option1=radio.add("radiobutton", undefined, "01_Overrodes"),
        option2=radio.add("radiobutton", undefined, "02_FindText"),
        option3=radio.add("radiobutton", undefined, "03_Alert_Basic Replace"),
        option4=radio.add("radiobutton", undefined, "04_Tracking, Kerning and Nonbreak");
        option5=radio.add("radiobutton", undefined, "05_Colour Remove");
        option6=radio.add("radiobutton", undefined, "06_Foilo order");
        w.add ("button", undefined, "OK")
        option1.value = true;
          radio.alignChildren="left";
          radio.margins = [10,10,50,10];
      //where is i add my coding
      if (w.show() == 1){
           if (option1.value) alert("Action One!");
           if (option2.value) alert("Action Two!");
        if (option3.value) alert("Action Three!");
        if (option4.value) alert("Action Four!");
        if (option5.value) alert("Action Four!");
        if (option6.value) alert("Action Four!");
      else {
          exit();
      var
      Please Help and suggest me friends.
      Advance Thanks
        • 1. Re: Multi script coding insert to dialog box
          b91823603 Level 3
          Hi karthi,
          try like this,
               if (option1.value){
                      var scpt = "D:\source1.jsx";
                      app.doScript(scpt, ScriptLanguage.javascript);
               if (option2.value) {
                   var scpt = "D:\source2.jsx";
               if (option3.value) {
                   var scpt = "D:\source3.jsx";
              if (option4.value) {
                   var scpt = "D:\source4.jsx";
              if (option5.value) {
                   var scpt = "D:\source5.jsx";
              if (option6.value) {
                   var scpt = "D:\source6.jsx";
          • 2. Re: Multi script coding insert to dialog box
            tpk1982 Level 4
            the simple way is using function... just call the function in the place of alert
            otherwise we can use #include scriptname.jsx;
            • 3. Re: Multi script coding insert to dialog box
              Hi B & TPk
              I have work out your both coding. But, not working friend.
              @B: I am insert your code. That script "option1.value" only is working. otherwise, not working for other script coding.
                     Marge code is below. Please tell where is i am mistake? suggest B.
              var
              if (option1.value){
                          var scpt = "/Users/stype/Desktop/0/01_Overrodes.jsx";
                       var scpt = "/Users/stype/Desktop/0/02_FindText.jsx";
                       var scpt = "/Users/stype/Desktop/0/03_Alert_Basic Format.jsx";
                       var scpt = "/Users/stype/Desktop/0/04_Tracking, Kerning and Nonbreak.jsx";
                       var scpt = "/Users/stype/Desktop/0/05_Colour Remove.jsx";
                       var scpt = "/Users/stype/Desktop/0/06_Foilo order.jsx";
              if (w.show() == 1){
              else {
                  exit();
              @Tpk: I was try to your suggestion also, this also not working. Please see below code.
              var
              if (w.show() == 1){
                   if (option1.value) function(){"Action One!" + "/Users/stype/Desktop/0/01_Overrodes.jsx"+ app.doScript(ScriptLanguage.javascript)};
                   if (option2.value) function(){"Action Two!" + "/Users/stype/Desktop/0/02_FindText.jsx"+ app.doScript(ScriptLanguage.javascript)};
                if (option3.value) function(){"Action Three!" + "/Users/stype/Desktop/0/03_Alert_Basic Format.jsx"+ app.doScript(ScriptLanguage.javascript)};
                if (option4.value) function(){"Action Four!" + "/Users/stype/Desktop/0/04_Tracking, Kerning and Nonbreak.jsx"+ app.doScript(ScriptLanguage.javascript)};
                if (option5.value) function(){"Action Four!" + "/Users/stype/Desktop/0/05_Colour Remove.jsx" + app.doScript(ScriptLanguage.javascript)};
                if (option6.value) function(){"Action Four!" + "/Users/stype/Desktop/0/06_Foilo order.jsx" + app.doScript(ScriptLanguage.javascript)};
              else {
                  exit();
              Please suggest this type of coding method.
              Advance thanks
              • 4. Re: Multi script coding insert to dialog box
                tpk1982 Level 4
                if (option1.value) {
                    Action_One();
                function Action_One(){
                    //paste you coding here. not the script path
                • 5. Re: Multi script coding insert to dialog box
                  b91823603 Level 3
                  Hi karthi,
                  You can use like this also,
                  var
                  if (w.show() == 1){
                    if (option1.value){app.doScript(File(Folder.desktop+"/0/01_Overrodes.jsx"),ScriptLanguage.ja vascript)};
                    if (option2.value){app.doScript(File(Folder.desktop+"/0/02_FindText.jsx"),ScriptLanguage.jav ascript)};
                    if (option3.value){app.doScript(File(Folder.desktop+"/0/03_Alert_Basic Format.jsx"),ScriptLanguage.javascript)};
                    if (option4.value){app.doScript(File(Folder.desktop+"/0/04_Tracking, Kerning and Nonbreak.jsx"),ScriptLanguage.javascript)};
                    if (option5.value){app.doScript(File(Folder.desktop+"/0/05_Colour Remove.jsx"),ScriptLanguage.javascript)};
                    if (option6.value){app.doScript(File(Folder.desktop+"/0/06_Foilo order.jsx"),ScriptLanguage.javascript)};
                  else {
                      exit();
                  • 6. Re: Multi script coding insert to dialog box
                    Hi B & Tpk.
                    @B: Very very thanks you so mach B. I am very happy.
                    @TPK: Very very thanks you so mach for your approached tpk.
                    Thanks Friends.
