4 Replies Latest reply on Apr 29, 2016 3:21 AM by Mattmcquiff
    Script help Works as javascript but not photoshop
    Mattmcquiff Level 1
      I'm trying to get these 2 scripts to work together.
      this runs in Photoshop fine.
      #target photoshop
      if (app.documents.length > 0) {
          var myDocument = activeDocument;
          var fileNameNoExtension = myDocument.name;
        fileNameNoExtension = fileNameNoExtension.split( "." );
        if ( fileNameNoExtension.length > 1 ) {
             fileNameNoExtension.length--;
          fileNameNoExtension = fileNameNoExtension.join(".");
          var BrandID = fileNameNoExtension.substr(0,4);
          var ItemType = fileNameNoExtension.substr(4,2);
          alert(ItemType)
      The alert is just for a test run, A file named EM10NW021231.jpg returns the "ItemType" as "NW"
      This part of the script runs as javascript
      var itemTable = [
      {itemType: "RI", BorderIncrease:"180"},
      {itemType: "NW", BorderIncrease:"115"},
      {itemType: "CL", BorderIncrease:"115"},
      {itemType: "BW", BorderIncrease:"120"},
      {itemType: "SC", BorderIncrease:"120"},
      {itemType: "ER", BorderIncrease:"150"},
      {itemType: "WW", BorderIncrease:"140"},
      {itemType: "WA", BorderIncrease:"140"},
      {itemType: "HR", BorderIncrease:"140"},
      {itemType: "JM", BorderIncrease:"100"},
      {itemType: "NA", BorderIncrease:"100"}
      var BorderIncrease = itemTable.filter(function ( obj ) {
          return obj.itemType === "BW"; //BW is to be replaced with ItemType
      })[0];
      alert(BorderIncrease.BorderIncrease);
      How can I link these together where line 16 is to replace the "BW" with the ItemType from the first script?
      Many Thanks
      Matt
        • 1. Re: Script help Works as javascript but not photoshop
          Chuck Uebele Adobe Community Professional & MVP
          Have you tried the $.evalFile() command? Is there a reason you don't want to combine the scripts into one, and make life easier?
          • 2. Re: Script help Works as javascript but not photoshop
            Mattmcquiff Level 1
            Hi I am trying to combine the 2 scripts. but I get errors  with this line
            1. var BorderIncrease = itemTable.filter(function ( obj ) {
            2.     return obj.itemType === "BW"; //BW is to be replaced with ItemType
            I am very inexperienced with script, but what does $.evalFile() command mean/do?
            • 3. Re: Script help Works as javascript but not photoshop
              SuperMerlin Level 5
              Please try this.
              #target photoshop
                  alert(ItemType)
              var itemTable = [
              var BI = BorderIncrease(itemTable, ItemType );
              alert(BI);
              function BorderIncrease(Arr, Item){
              for(var z in Arr){
              if(Arr[z].itemType === Item){
                 return Arr[z].BorderIncrease;
              return 0;
