1 Reply Latest reply on Apr 24, 2006 3:13 PM by Alain-MMTS
    Slide Cropping in Breeze Presenter
    DanGrooms
      After creating a presentation in PPT, material on the right and bottom of the slides are cropped when published in Breeze. They look fine when vieing with PPT viewer. Any thoughts. Is ther a specific page format/size that you need to start with in PPT
        • 1. Re: Slide Cropping in Breeze Presenter
          Alain-MMTS
          One possible reason this can happen is if your desktop display DPI setting is set to Large Size.
          To set them back to normal, please follow the steps below and see if this resolves the problem:
          1. Right click on the desktop and select Properties.
          2. Select 'Settings>Advanced'
          3. On the General tab (might vary depending on video card) select DPI setting 'Normal Size'.
          4. Restart machine and republish the presentation.
          Hope this helps.
