6 Replies Latest reply on Apr 30, 2016 11:26 AM by Vamitul
    typefi element inside a table
    harishbisht789
      How to get the typefi element lying in a table?
        • 1. Re: typefi element inside a table
          harishbisht789 Level 1
          it is an anchored typefi element and i want to select the row of the table
          • 2. Re: typefi element inside a table
            I'd suggest you are doing a screen capture of the situation with hidden text showing, edges showing and post it as an inline image here.
            Use the forum's controls for this:
            Uwe
            • 3. Re: typefi element inside a table
              Uwe,
              This is my code:--
              (function(){
                // To test the script interactively, uncomment the following line
                // and select one of the story's text frames.
                //TYPEFI = {inddSpillFrame: app.selection[0]};
              var mSel = app.selection[0],
              mCheck = mSel instanceof Table || mSel instanceof Document;
              while (!mCheck) {
                        mSel = mSel.parent;
                var i;
                var found;
                var typefitextFLines;
                var objFrame;
                app.findGrepPreferences = null;
              app.findGrepPreferences.findWhat = '~a';
              found = app.documents[0].findGrep();
              //~   app.findGrepPreferences = null;
              //~   app.findGrepPreferences.findWhat = '~a';
              //~   found = TYPEFI.inddSpillFrame.parentStory.findGrep();
                for (i = found.length-1; i >= 0; i--){
                  if (found[i].pageItems[0].typefiSettings.element.name== "equ"){
                    found[i].leading = Leading.AUTO;
                    found[i].textFrames[0].textWrapPreferences.textWrapMode = TextWrapModes.JUMP_OBJECT_TEXT_WRAP;
              else  if (found[i].pageItems[0].typefiSettings.element.name== "T_equ"){
                  var mu= found[i].parent.parentRow;
                  alert();
              //~   // Paragraph:
              //~   found[i].paragraphs[0];
              //~   // Page:
              //~   found[i].parentTextFrames[0].parentPage;
              it is an anchored typefi element.This script is working fine on all other typefi elements which are not lying inside a table.
              But this doen't work on the typefi element lying on the table..
              I want to select that row on which that typefi element is lying, and then i want to increase that row height..
              • 4. Re: typefi element inside a table
                Karl Heinz Kremer Adobe Community Professional
                [ Moved to InDesign Scripting ]
                • 5. Re: typefi element inside a table
                  Thank you.
                  Hello harishbisht,
                  I would contact the developers at Typefi and ask for a solution there.
                  Uwe
                  • 6. Re: typefi element inside a table
                    Vamitul Level 4
                    Hi Harishbisht,
                    Assuming inddObject is a typefi float:
                    inddObject.typefiSettings.element.anchor would return a TypefiElementAnchor.
                    then
                    myAnchor.pageItem would return a GraphicLine that is the anchor's in-page representation, so the parent of that Graphic line is a character.
                    In one very long line:
                    var parent=inddObject.typefiSettings.element.anchor.pageItem.parent.parent;
                    if (parent.constructor.name=='Cell'){
                    alert('Anchor in cell')
                    Like Uwe said, these kinds of questions are better suited for the Typefi Support Portal.
