19 Replies Latest reply on May 4, 2016 6:11 AM by Katieqwerty9
    Colour values changing!
    Katieqwerty9
      I was sent an image as an RGB jpg file that I wanted to use in a print. I opened it up in Photoshop and converted it to CMYK and saved. Then I needed to make all the pure white in it magenta (for our printer to be able to print it in white). So I select the pure white using magic wand and 'select similar' option. I make a new solid colour layer typing in C=0 M=100 Y=0 K=0. I then select both layers and apple E to merge. I then save this file as a high quality jpg.
      To get it in the design I want I place it as an image in a compound path in InDesign. Here is the problem - I use the colour picker to check that the magenta is magenta, and it is not - it has 0.3% yellow in it.
      Could someone tell me where I have gone wrong or where the setting is that I need to change... ?
      Thank you so much in advance.
        • 1. Re: Colour values changing!
          Jeffrey_Smith Most Valuable Participant
          It sounds like what you are doing is preparing a file that will print on a digital press: 4 color process inks along with a spot opaque white ink. If this is the case, the preparation of the white ink requires that it is specified a spot color, named "WHITE" and the color makeup of the spot ink is 100% magenta. Most importantly is that the color is made a spot ink. The color recipe (100M 1Y) will not have any bearing on printing the white ink.
          • 2. Re: Colour values changing!
            I'm guessing Jeffery is right, but the yellow percentage would be coming from compression artifacts when you save as JPEG. Save out as a lossless format like .PSD. You'll need to do that for a spot channel anyway–JPEG doesn't support extra channels
            • 3. Re: Colour values changing!
              Katieqwerty9 Level 1
              Thanks for your help. Correct Jeffrey, I am preparing artwork to print on a mimaki UV printer. The printer is set up right and we have other art work that I have no trouble with- whatever is 100% M prints spot white.
              I'm not sure whether I am preparing my artwork correctly for this project and am still a bit confused.
              Rob, I need to place the image into Indesign- should I try to place a PSD instead?
              So do you think the problem is occurring when I save the jpg- it's not recording the colour values correctly? Or might it be that I have converted it to cmyk in the wrong way in photoshop? Or is it about the way I'm placing the image in indesign? Or exporting to pdf from indesign?
              As you can probably tell I am still a learning artworker.
              I've tried a test print and it is printing out in bright pink!
              Thanks again for your help
              • 4. Re: Colour values changing!
                jason t Level 1
                When you make a jpg it adds com compression to the image which results in ‘extra’ or ‘different’ colors in areas.  To preserve the pixels without alteration you need a ‘lossless’ (no compression) format.  Whether this is jpg, tiff, png without compression or the PSD itself.
                I would probably place the PSD (thought I think someone said this could have bad consequences for vectorized text/art).
                For coating applications we usually assign a ‘spot’ color as mentioned.  You would select your area, move to channels, create new spot channel and fill it with 100% magenta.
                edit: I kept thinking about this imagining how it would work - this will only give you a big pink image as well.  surely your printer is looking for another 'channel' or color
                For this, I would select the solid white as you had done, then navigate to the magenta channel and fill those pixels with solid black – the channels are basically your CMYK plates so you’re telling it whatever was white in the composite will now be 100% solid in the magenta channel.
                • 5. Re: Colour values changing!
                  John Mensinger Adobe Community Professional & MVP
                  You should not be using JPEG for print. When you save as JPEG, compression is applied; artifacts are born; pixels change. When saving in Photoshop for placement in an InDesign Print layout, there is no reason to save in any format other than PSD.
                  • 6. Re: Colour values changing!
                    But the color you have setup in InDesign is a spot color swatch right? Like this where the Color Type is Spot and not Process:
                    The JPEG format can't be saved with a spot color channel, so you must be using process magenta in the Photoshop file and so it would print pink.
                    If you need a spot color from Photoshop it has to be set up as a Spot Channel like this—the name of the channel will have to match the name of the spot color you are using over in ID:
                    • 7. Re: Colour values changing!
                      Thank you for this.
                      I have tried setting the artwork up like this and creating a 'spot' not 'process' colour in ID. The only thing is that now when I export to pdf to print from ID, the white is appearing white and not magenta. I have checked on our other ID documents that we print in white- and the magenta we use is a process colour- our printer is set up to read process 100% magenta as spot white as far as I can tell...?
                      The other artwork that we print white is done purely in ID which is why I think, I have had no problems with it before.
                      I have placed the PSD file (with a merged 100%M colour fill) in ID ... there is slight progress in that now when I use the eye dropper tool- it is saying that the magenta is 100% magenta. When I export to pdf I am going on the compression settings and under 'colour images'> 'compression' choosing 'none'. It is still printing pink not white.
                      Do you have any other ideas?
                      Thank you !
                      • 8. Re: Colour values changing!
                        Danny Whitehead. Level 4
                        In that case, how would you print actual magenta? Have you tried printing it (or if possible, previewing it in the RIP, to avoid wastage) as advised, with a spot colour called 'WHITE', that is specified as 100% magenta?
                        It's common practice to make special colours (die cutting, varnishes etc) look magenta, but really, it can have any appearance on-screen. It's the name of the spot colour that triggers the RIP to process it as intended.
                        • 9. Re: Colour values changing!
                          Oh I see. I will test it with the spot colour setting. So our printer should automatically recognise 'WHITE' and print it white..? This makes sense.
                          • 10. Re: Colour values changing!
                            Could you select an object in InDesign that is outputting correctly, open it's fill swatch an screen capture it for us?
                            • 11. Re: Colour values changing!
                              I wouldn't like to make presumptions about specific equipment I've no experience with, but yes, I'd predict that to be the case.
                              • 12. Re: Colour values changing!
                                so this is how I usually print in white....
                                • 13. Re: Colour values changing!
                                  This is what I'm trying to print in white- I'm trying to place a psd pattern (that I want white in) - in a compound path Screen Shot 2016-05-04 at 13.45.09.png
                                  • 14. Re: Colour values changing!
                                    What if you want to print magenta?
                                    • 15. Re: Colour values changing!
                                      .... i think we just don't print in magenta...!
                                      • 16. Re: Colour values changing!
                                        but we have different colour profiles- so I could print in magenta if I drop the artwork to a different profile- one that doesn't print in white and has a different pass rate ...
                                        • 17. Re: Colour values changing!
                                          I'd expect that you'd be better off going back to the original pattern (before you coloured the white with magenta). Place that in the compound path, copy the path, paste in place, delete the image from the copy, colour it with a spot colour called 'WHITE' and set it to overprint. But of course, your equipment might work (or be configured to work) differently than I'd expect.
                                          • 18. Re: Colour values changing!
                                            Ah. By 'profiles', do you mean hot folders that make the RIP apply different settings to jobs? Do you have any training on the RIP side, or have anyone there you could ask about this? Because I suspect the solution lies on that side of things.
                                            • 19. Re: Colour values changing!
                                              Yes. We have hot folders that apply different conditions for different products we print on. I just drop the pdfs into the right folders.
                                              I just don't know why the magenta in the placed image is not being recognised...?
                                              OK, I will try to talk to someone RIP side. I just wanted to make sure it wasn't my fault in the way I am preparing things in Adobe.
