2 Replies Latest reply on May 2, 2006 7:02 AM by Newsgroup_User
    Punch a Bitmap?
    Zealouse
      Can you Punch a Bitmap? I have a bitmap of a button and can not punch the text?
      I know I can punch a Vector but how do you punch a bitmap?
        • 1. Re: Punch a Bitmap?
          Level 7
          Zealouse,
          Learn about masking.
          You can create a vector path over your bitmap, select both the path and
          the bitmap then go to Modify > Mask > Group as Mask.
          In FW8 tthere is a new feature that allows you to convert a marquee to a
          path as well. This tutorial talks about removing a bitmap background and
          should help you.
          http://www.pixelyzed.com/pixelforge/removebackgrounds/
          alex
          • 2. Re: Punch a Bitmap?
            Level 7
            You can, but you need to do two things first.
            1. Use the button as a pattern fill of a like sized vector object. If it
            is a rectangle, be sure you ungroup it before adding the button as pattern.
            2. Convert the text to paths, ungroup it, and then join it (Modify >
            Combine paths > Join) before punching it through the vector object.
            Linda Rathgeber ACE ::: PVII
            http://www.projectseven.com
            Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
            CSS Newsgroup: news://forums.projectseven.com/css/
            Adobe Community Expert - Fireworks
            Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
