0 Replies Latest reply on May 1, 2016 4:22 PM by rvl
    Dynamic Text fields not working - what's going on?
    rvl Level 1
      I'm working in Flash CS6.
      For some reason, dynamic text fields that used to work are now not working.  Fonts are correctly embedded as before.  Nothing else changed since I last successfully ran the file.
      As a test I opened a new Flash doc and created a new dynamic text field and assigned a value with actionscript.  It worked fine as expected.
      So then I pasted that text field and code into the problem Flash doc and it doesn't work!  No text is displayed.
      This is one of those Flash quirks that can drive someone nuts for hours so I'm hoping to avoid this if someone has an answer.
