Okay, So I have had this problem where i get this error when I try to download any application (e.g. Adobe Lightroom CC (2015)):
05/02/16 21:19:57:793 | [WARN] | | OOBE | DE | | | | 11116 | DW050: The following payload errors were found during install:
05/02/16 21:19:57:793 | [WARN] | | OOBE | DE | | | | 11116 | DW050: - Adobe Lightroom: Install failed
05/02/16 21:19:57:798 | [INFO] | | OOBE | DE | | | | 11116 | Call PostSession Custom Hook
05/02/16 21:19:57:798 | [INFO] | | OOBE | DE | | | | 11116 | :: END TIMER :: [Total Timer] took 180512 milliseconds (180.512 seconds) DTR = 10.7915 KBPS (0.0105386 MBPS)
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | -------------------------------------- Summary --------------------------------------
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | - 0 fatal error(s), 1 error(s)
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | Win OS version: 10.0.0.0 64 bit Type: 1
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | ----------- Payload: Adobe Lightroom 6.0.0.0 {8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D} -----------
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | ERROR: DF024: Unable to move file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D}\_195_0dc8a5269af8c279bb94d45486d88942" to "C:\Program Files\Adobe\Adobe Lightroom\Helpers\DynamicLinkMediaServer\dynamiclinkmediaserver\1.0\AudioRenderer.dll" Error 32 The process cannot access the file because it is being used by another process.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.(Seq 188)
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | Please search the above error string(s) to find when the error occurred.
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | These errors resulted in installer Exit Code mentioned below.
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | -------------------------------------------------------------------------------------
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | Exit Code: 7 - Unable to complete Silent workflow.
05/02/16 21:19:58:850 | [INFO] | | OOBE | DE | | | | 11116 | Successfully dumped analytics data at: C:\Users\Colt\AppData\Local\Temp\{CAB4269B-4D18-4B92-90E3-A36340820CBC}\{341827FC-7D8D-4314-8B08-26B31BBD4739}
05/02/16 21:19:58:850 | [INFO] | | OOBE | DE | | | | 11116 | Please see specific errors for troubleshooting. For example, ERROR: DF024 ...
05/02/16 21:19:58:852 | [INFO] | | OOBE | DE | | | | 11116 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
I have tried pretty much anything that's said to do and nothing has worked. Please Help.
Hi ColtMcG,
After looking at the logs
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | ERROR: DF024: Unable to move file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D}\_195_0dc8a5269af8 c279bb94d45486d88942" to "C:\Program Files\Adobe\Adobe Lightroom\Helpers\DynamicLinkMediaServer\dynamiclinkmediaserver\1.0\AudioRenderer.dll" Error 32 The process cannot access the file because it is being used by another process.. Try setting
Hi ColtMcG,
05/02/16 21:19:58:810 | [INFO] | | OOBE | DE | | | | 11116 | ERROR: DF024: Unable to move file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{8048A5DF-8A70-5BE1-954B-E0FDE1BD0D0D}\_195_0dc8a5269af8 c279bb94d45486d88942" to "C:\Program Files\Adobe\Adobe Lightroom\Helpers\DynamicLinkMediaServer\dynamiclinkmediaserver\1.0\AudioRenderer.dll" Error 32 The process cannot access the file because it is being used by another process.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it
We would request you to restart the machine --> close all the following process --> clear the content of %temp% folder and re-initiate the installation.
If that doesn't work, please check: Errors "Exit Code 6" and "Exit Code 7" installing Adobe Creative Cloud, CS6, CS5.5, Premiere Element... and share the results.
