0 Replies Latest reply on May 3, 2016 9:13 AM by polyphilus
    replacing 2 depending dropdown lists by combination of radio buttons/list box
    polyphilus
      In a first step, I placed two depending dropdown lists:
      „dropdown“ and „secondDropdown“ with the following script in the key stroke field of teh field „dropdown“
      var dropdown = {
                             "category1": [ ["-","None"], ["termA",11], ["termB",12], ["termc",13]],
                             "category2": [ ["-","None"], ["term_a",21], ["termb_",22], ["term_c",23]],
                             "category3": [ ["-","None"], ["term_i",31]],
                             "category4": [ ["-","None"], ["termX",41]]
      var oPaymentProductField = dropdown;
      function PaymentProduct()
         if(event.willCommit)
            var lst = oPaymentProductField[event.value];
            if( (lst != null) && (lst.length > 0) )
      this.getField("secondDropdown").setItems(lst);
            else
      this.getField("secondDropdown").clearItems();
      PaymentProduct();
      _______
      The customer prefers to replace the first dropdown list by a group of 4 radio bottons (field name “category”).
      The second dropdown list should be a list box (field “ListField”, only with single choice option)
      4 radio buttons (group name "category")
      export value 1
      export value 2
      export value 3
      export value 4
      For filling the List box, I wrote following script in the calculation field of another text field (I do not know where I can place this script in radio buttons or list boxes):
      var cat = this.getField("category").value;
      var list = this.getField("ListField");
      if (cat == "1") list.setItems( ["-","None"], ["termA",11], ["termB",12], ["termC",13]);
      else if (cat == "2") list.setItems([ ["-","None"], ["term_a",21], ["term_b",22], ["term_c", 23]]);
      else if (cat == "3") list.setItems([ ["-","None"], ["term_i",31]]);
      else if (cat == "4") list.setItems([ ["-","None"], ["term_X",41]]);
      else list.setItems([""]);
      Depending on selection oft he radio buttons, the list box is filled correctly. But I cannot retrieve the export value as I could when I used the two dropdown lists.
      I need to use this export value to give more information in other fields.
      How can I get the export value oft he list field?
