1 Reply Latest reply on May 5, 2006 5:52 AM by Newsgroup_User
    Dynamic creation of class at runtime
    steveanson
      I need to be able to dynamically create an instance of a class that isn't known until runtime - actually based on the filename
      so in my fla:
      var className:String="Test"; /* code to get a class name derived from the filename */
      var obj = new [className]();
      trace(obj);
      the code above only works if i put the literal directly in [ ]
      like so:
      var obj = new ["Test"]();
      is there a way to do this???
      Any help much appreciated
      cheers Steve
        • 1. Re: Dynamic creation of class at runtime
          Level 7
          This might help you out:
          http://dynamicflash.com/2005/03/class-finder/
          "steveanson" <webforumsuser@macromedia.com> wrote in message
          news:e3fcnv$6c7$1@forums.macromedia.com...
          known
          > so in my fla:
          the
          > filename */
          > var obj = new ();
          > trace(obj);
          > like so:
          > var obj = new ();
          > cheers Steve
