7 Replies Latest reply on May 4, 2006 1:16 PM by ColoradoSteve
    Loading JPG into a specific layer
    ColoradoSteve
      I'm a Flash beginner, so I apologize if this question is silly...
      I created a movie clip with several layers. Some of the layers have images that I dragged onto the stage from my library of symbols.
      My top layer "Actions" contains all my ActionScript code. in this layer I am creating an empty movie clip using the createEmptyMovieClip() method and then attempting to load a JPG using the loadMovie() method. I want the JPG to appear "behind" other images in the movie clip (i.e a lower layer). I'm assuming that I should accomplish this by passing a certain depth in the createEmptyMovieClip() method.
      However, no matter what value I seem to pass to createEmptyMovieClip(), the JPG appears "in front" of all other layers. otherwise it's working fine.
      Although there is a lot of doco about the methods, i can find very little description about how "depth" works. My understanding is that a higher depth value means the movie clip will be created on a higher layer (more "in front"), but I can't seem to use this value to affect where the image ends up when loaded.
      Any assistance would be greatly appreciated. I have developed a work around, but I'd really liked to understand how this is supposed to work.
      Thanks so much!
      Steve
        • 1. Re: Loading JPG into a specific layer
          nice multimedia
          the easiest method I know of is to place a .jpg in a movie and publish it as a .swf then the loadmovie command will work.
          • 2. Re: Loading JPG into a specific layer
            nice multimedia Level 1
            one more thing ...if you make the movie that the .jpg is placed the same size as the movie it is loading into, then you can place the .jpg where you want it to appear and it will register that position when loaded.
            • 3. Re: Loading JPG into a specific layer
              TimSymons Level 1
              Your dynamically created movieclips will appear ontop of eveything on the stage unless you use a specific negative depth. I can't rmemeber the number off the top of my head but it exists. A little more subtle way to do this is to place an empty movieclip on a layer that is below all the elements you want your image to be behind. Then just load your JPG into that movieclip instaed of creating an empty clip dynamically.
              Tim
              • 4. Re: Loading JPG into a specific layer
                Level 7
                > work.
                Both the loadMovie() function and the MovieClip.loadMovie() method load
                JPGs just fine. Since the release of Flash 8, it's even possible to
                load GIFs and PNGs, too.
                As it turns out, there is no ActionScript equivalent to layers. There
                are depths, which *roughly* correlate to layers -- depths pertain to a given
                timeline, but it doesn't get deeper than that.
                Anything you load or create dynamically will appear above assets you
                drag to the Stage by hand. You could arrange your manual content into one
                movie clip and load your JPG into another, then invoke
                MovieClip.swapDepths() to swap their depths.
                Yeah ... it really does seem like layers *should* correspond to depths,
                but it just doesn't work that way. I *believe* that layers are located at a
                reserved depth (possibly negative numbers).
                David
                stiller (at) quip (dot) net
                Dev essays: http://www.quip.net/blog/
                "Luck is the residue of good design."
                • 5. Re: Loading JPG into a specific layer
                  shyaway Level 1
                  the mc you placed on stage actually have negative value for depth in thousands.
                  try the getDepth and see for yourself.
                  there's a depth manager class that allow you to manage.
                  however, a quick and easy way to manage the depth with using another class...
                  in your layer, put an empty movie clip in there, you have to create an empty one like mcBlank
                  then name the instance jpg_mc
                  place is in the layer you want,
                  and at run time, you can use loadMovie("mypic.jpg",jpg_mc);
                  • 6. Re: Loading JPG into a specific layer
                    ColoradoSteve Level 1
                    Thanks for the advice nice multimedia. However, I don't think that creating an SWF for each JPG that I want to load will be feasible since I have many of them and will be changing them frequently via an XML control file. I'm doing this so that I can change the images loaded without having to go into Flash and re-publish, so having to generate an SWF file everytime I have a new image would probably defeat that purpose. Thanks again though for the quick response!
                    • 7. Re: Loading JPG into a specific layer
                      Shyaway, David and Tim,
                      Thanks a ton guys! Especially David for taking the time to explain some of the nuts and bolts.
                      Although I don't totally understand what a depth is now (I'll read up on it though), I understand that this doesn't simply correspond to the layer on the timeline like I originally thought.
                      It seems that the best way to handle this will be to "manually" add a movie clip and then load it there.
                      Thanks again
