4 Replies Latest reply on May 3, 2006 11:29 AM by Newsgroup_User
    preserving framerate of an imported movieclip
    Level 7
      if I have an animation movieclip imported into another movieclip with a
      different framerate, how do I force the imported clip to play at its
      original framerate?
        • 1. Re: preserving framerate of an imported movieclip
          Peter Lorent Level 2
          As in - a swf imported into another swf - or are you importing a movieclip from one project into another which is running at a different framerate?
          • 2. Re: preserving framerate of an imported movieclip
            Level 7
            for the moment I am importing a MC from one FLA to another
            But I am also intersted tolearn about the second case you mentioned -
            importing SWF into FLA
            "LuigiL" <webforumsuser@macromedia.com> wrote in message
            news:e3a4ft$9mm$1@forums.macromedia.com...
            movieclip
            • 3. Re: preserving framerate of an imported movieclip
              Come to think of it, is there any difference...
              The framerate you set for the 'motherfla' will be the framerate for all mc's, imported sfw's included. So, you must use a function to set the framerate for a particular mc. And kglad kindly posted the following code to achieve that.
              //to use, specify the movieclip, frame rate and frames to play - forward or backward, doesn't matter:
              yourMC.playF(1,yourMC._totalframe,33);
              MovieClip.prototype.playF = function(m, n, fps) {
              if (!var3141592) {
              var3141592 = 0;
              playA = new Array();
              this.m = m;
              this.n = n;
              this.fps = fps;
              this.gotoAndStop(this.m);
              playA[var3141592] = setInterval(playF2, 1000/this.fps, this, var3141592);
              var3141592++;
              function playF2(mc, ind) {
              if (mc.m<mc.n) {
              mc.nextFrame();
              } else {
              mc.prevFrame();
              if (mc._currentFrame == mc.n) {
              clearInterval(playA[ind]);
              updateAfterEvent();
              • 4. Re: preserving framerate of an imported movieclip
                Level 7
                "LuigiL" <webforumsuser@macromedia.com> wrote in message news:e3af4v$n7m$1@forums.macromedia.com...
                Good code but it doesn't affect the frame rate, it just shows some frames at odd times using a timer and updateAfterEvent. The
                actual frame rate isn't changed.
                tralfaz
