0 Replies Latest reply on May 4, 2016 2:06 PM by johnsoncodehk
    jsfl Command Share
    johnsoncodehk
      These are some tools I create at one year ago, I use Flash version is CS 5.5, I don't know these whether to use the new version, but if you are using older versions Flash, these will be able to help you.
      GitHub - johnsoncodehk/flash-command
      - Select Unused Item
      Built-in option is not selected correctly Unused Item, this is the right counter, and faster version.
      - Relist Library
      Reclassification library and arrange parent-child hierarchy based on mc.
      - Publish All Open fla
      When the need to publish a lot of fla, you can open all fla and use the command.
      - Save and Publish
      When the file size is very large, you may not need to wait for the end to save before publish.
      - Publish New fla
      Publish all last modification date in 600 seconds (modifiable) within the file. The program specified folder looking Project_URI.txt all fla files. If the new swf to fla, not re-publish.
      Code is not pretty, if someone would use my dresser.
