12 Replies Latest reply on May 9, 2016 12:03 PM by cbishop01
    More Scripting Help needed please.
    cbishop01 Level 2
      Ok the below Script is what i would like to use for what i'm doing.  I have alot that i'm going to add to it over time so i'm hoping you can help with some of these Questions.  I have all the things i want to do marked with //.  We can just do one section at a time if you would like to make the scripting easier or all at one time it dont matter to me.  I'm very new to scripting so this could take me a while to do.
          var w =new Window ('dialog {text: "Running Changes", orientation: "column", alignChildren:["fill","fill"],   properties:   {closeButton:   false}}');
            w.main =w.add ('group {preferredSize: [600, 500], alignChildren: ["left","fill"]}');
            w.stubs  = w.main.add ('listbox', undefined, ['Changes Made', 'Check For Changes', 'Example']);
          w.stubs.preferredSize.width  = 150;  w.tabGroup  = w.main.add ('group {alignment: ["fill","fill"], orientation: "stack"}');
            w.tabs  =[];
          w.tabs[0]= w.tabGroup.add ('group');
          w.tabs[0].add('statictext {text: "Changed"}');
                     w.tabs  =[];
          w.tabs[0].add('statictext {text: "Select a change to make"}');
                   w.tabs[0].add ('panel');
                   w.tabs[0].add ('checkbox {text: "Run Running Change List1"}');// Activate the Find and replace Script
      //~              IF possible i would this script to be exicuted if the above check mark is selected. After pressing OK button
      //~              if this button is not selected i dont wnat this part of the script to activate.
                   //~     Replace(" <CR> ", "^p")
                          //~     Replace("  ", " ")
                          //~     Replace(" :", ":")
                          //~     Replace(" .", ".")
                          //~     Replace("^p^p", "^p")
                          //~     Replace(" <CR>", "^p")
                          //~         function Replace(input, output)
                          //~             app.selection[0];
                          //~             app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
                          //~             app.findTextPreferences.findWhat = input;
                          //~             app.changeTextPreferences.changeTo = output;
                          //~             app.activeDocument.changeText();
                   w.tabs[0].add ('checkbox {text: "Running Change list 2"}');
                   w.tabs[0].add ('panel {text: "Running CHange list 1", preferredSize: [-1, 160]}');
                   w.tabs[0].add ('panel {text: "Running CHnage list 2", preferredSize: [-1, 160]}');
                          // I would like a list inside this panel
                          //~  "B1.   Omni Align Front panel information to the O in omni"
                          //~  "B2.   ShopLine Align Front panel text with S in Shop and Identifier with L in line Flush Left text
                          //~  "B3.   Deltron Spacing around Art and logo
                          //~  "B4.   Matthews Art and Attribute statement update
                          //~  "B5.   One Shot Artwork (Some change to Just green bar Some Blue ETC...
                   w.tabs[0].add ('panel {text: "NON Changes to be made", preferredSize: [-1, 150]}');
                   w.tabs[0].add ('panel {text: "When placing or pasting content", preferredSize: [-1, 80]}');
          with(w.tabs[0])
          with(add ('group {alignment: "left"}'))
                         add ('button {text: "Reset al warning dialogs"}');
          w.tabs[1]= w.tabGroup.add ('group');
                   w.tabs[1].add ('statictext {text: "Interface"}');
                   w.tabs[1].add ('panel {preferredSize: [-1, -10]}');
                   w.tabs[1].add ('panel {text: "What Needs Changed", preferredSize: [-1, 300]}');
                   w.tabs[1].add ('panel {text: "Options", preferredSize: [-1, 100]}');
          w.tabs[2]= w.tabGroup.add ('group');
                   w.tabs[2].add ('statictext {text: "UI Scaling"}');
                   w.tabs[2].add ('panel');
                   w.tabs[2].add ('panel {text: "Example", preferredSize: [-1, 200]}');
                   // I would like to embed a Picture in the Example BOx
            w.buttons  = w.add ('group {alignment: "right"}');
          w.buttons.add  ('button {text: "OK"}');
          w.buttons.add  ('button {text: "Cancel"}');
          for(
          var i = 0;
           i < w.tabs.length;
           i++){
          w.tabs[i].orientation ='column';
          w.tabs[i].alignChildren ='fill';
          w.tabs[i].alignment =['fill','fill'];
          w.tabs[i].visible =false;
          w.stubs.onChange  = showTab;
          function
           showTab ()
          if(w.stubs.selection !==null){for(var i = w.tabs.length-1; i >= 0;
           i--)
                   w.tabs[w.stubs.selection.index].visible =true;
            w.onShow  =function()
          w.stubs.selection  = 1;
          showTab;
          w.show();
        • 1. Re: More Scripting Help needed please.
          tpk1982 Level 4
          try this.. see the line 58.. do that and run the script
          var myResult;
                w.tabs  =[];
                         w.tabs  =[];
              var RunCH1= w.tabs[0].add ('checkbox {text: "Run Running Change List1"}');// Activate the Find and replace Script
                       var RunCH2= w.tabs[0].add ('checkbox {text: "Running Change list 2"}');
                       var Pan1=w.tabs[0].add ('panel {text: "Running Change list 1", preferredSize: [-1, 160],orientation: "column",alignChildren: ["left","fill"]}');
                       w.tabs[0].add ('panel {text: "Running Change list 2", preferredSize: [-1, 160]}');
                      Pan1.add('statictext {text: "B1.   Omni Align Front panel information to the O in omni"}');
                      Pan1.add('statictext {text: "B2.   ShopLine Align Front panel text with S in Shop and Identifier with L in line Flush Left text"}');
                      Pan1.add('statictext {text: "B3.   Deltron Spacing around Art and logo"}');
                      Pan1.add('statictext {text: "B4.   Matthews Art and Attribute statement update"}');
                      Pan1.add('statictext {text: "B5.   One Shot Artwork (Some change to Just green bar Some Blue ETC..."}');
              with(w.tabs[0])
                  flower=w.tabs[2].add ("image", undefined, File ("~/\Desktop/\xxx.jpg"));//place you image in desktop and put the image name in the place of "xxx"
              for(
              var i = 0;
               i < w.tabs.length;
               i++){
              function
               showTab ()
               i--)
              showTab;
           myResult = w.show();
              if(myResult == 1 && (RunCH1.value==true || RunCH2.value==true) ){
              alert("in")
              Replace_TXT(" <CR> ", "^p");
              Replace_TXT("  ", " ");
              Replace_TXT(" :", ":");
              Replace_TXT(" .", ".");
              Replace_TXT("^p^p", "^p");
              Replace_TXT(" <CR>", "^p");
              w.close (true);
          function Replace_TXT(input, output)
          //app.selection[0];
          • 2. Re: More Scripting Help needed please.
            cbishop01 Level 2
            First thing You are Awesome!  And this is starting to act just like i want it to now.  I have a few other things I am trying to do with this script.  If i cannot figure them out i will be back on here for your help.  Thank you so much for all your doing.  Your saving me a ton of frustration.  This is getting close to being exactly what i'm needing.
            • 3. Re: More Scripting Help needed please.
              tpk1982 Level 4
              Glad to help you
              • 4. Re: More Scripting Help needed please.
                cbishop01 Level 2
                I have a few more questions that i cannot figure out.  Also how do you get your code to display with the numbered lines on this site?
                var myResult;
                   w.main =w.add ('group {preferredSize: [600, 600], alignChildren: ["left","fill"]}');
                    w.stubs.preferredSize.width  = 120;  w.tabGroup  = w.main.add ('group {alignment: ["Fill","Fill"], orientation: "stack"}');
                        w.tabs  =[];
                            w.tabs[0].add('statictext {text: ""}');
                        w.tabs  =[];
                // I cannot figure out how to make RunCH2 and 3 to Work. Example bleow '
                RunCH2
                  alert("RCH2 DONE")
                            Replace_TXT(" and ", "dddd");
                RunCH3
                  alert("RCH3 DONE")
                            Replace_TXT(" The ", " blah blah");
                    var RunCH1= w.tabs[0].add ('checkbox {text: "Find and Replace"}');
                    var RunCH2= w.tabs[0].add ('checkbox {text: "GHS Running Changes"}');
                    var RunCH3= w.tabs[0].add ('checkbox {text: "Non-GHS Running Changes"}');
                             var Pan1=w.tabs[0].add ('panel {text: "Find and Replace", preferredSize: [-1, 200],orientation: "column",alignChildren: ["left","Center"]}');
                                Pan1.add('statictext {text: "Double Space   -   Single Space"}');
                                Pan1.add('statictext {text: "Space :    -   :"}');
                                Pan1.add('statictext {text: "Space .    -   ."}');
                                Pan1.add('statictext {text: "<CR>   -   Return"}');
                                Pan1.add('statictext {text: "Double Return  -   Return"}');
                             var Pan1=w.tabs[0].add ('panel {text: "GHS Running Changes", preferredSize: [-1, 150],orientation: "column",alignChildren: ["left","Center`"]}');
                                Pan1.add('statictext {text: "B1.   Enter Here1"}');
                                Pan1.add('statictext {text: "B2.   Enter Here2"}');
                                Pan1.add('statictext {text: "B3.   Enter Here3"}');
                                Pan1.add('statictext {text: "B4.   Enter Here4"}');
                            var Pan1=w.tabs[0].add ('panel {text: "Non-GHS Running Changes", preferredSize: [-1, 150],orientation: "column",alignChildren: ["left","Center`"]}');
                                Pan1.add('statictext {text: "B1.   Enter Here5"}');
                                Pan1.add('statictext {text: "B2.   Enter Here6"}');
                                Pan1.add('statictext {text: "B3.   Enter Here7"}');
                                Pan1.add('statictext {text: "B4.   Enter Here8"}');
                             var Pan1=w.tabs[0].add ('panel {text: "Contact Infromation", preferredSize: [-1, 62],orientation: "column",alignChildren: ["left","Center`"]}');
                // How would I add a email address here where my co-workers could Click it email about Whatever?  This is not as big of a deal so if this is alot of trouble to do i will skip it.
                                Pan1.add('statictext {text: "*email Address here*"}');
                    with(w.tabs[0])
                                   add ('button {text: "Reset all warning dialogs"}');
                        w.tabs[1].add ('statictext {text: "Changes that WILL need checked"}');
                        var Pan1=w.tabs[1].add ('panel {text: "GHS", preferredSize: [-1, 250],orientation: "column",alignChildren: ["left","Center`"]}');
                                Pan1.add('statictext {text: "B1.   Here"}');
                                Pan1.add('statictext {text: "B2.   Here"}');
                                Pan1.add('statictext {text: "B3.   Here"}');
                                Pan1.add('statictext {text: "B4.   Here"}');
                                Pan1.add('statictext {text: "B5.   Here"}');
                                Pan1.add('statictext {text: "G1.   Here"}');
                                Pan1.add('statictext {text: "G2.   Here"}');
                        w.tabs[1].add ('panel {text: "Non-GHS", preferredSize: [-1, 100]}');
                        w.tabs[2].add ('statictext {text: "Example Of running Changes"}');
                        w.tabs[2].add ('statictext {text: "", preferredSize: [-1, 20]}');
                  // How can i make PreV1 activate the below Radio buttons?  Maybe gray out the Buttons when not the Check box is not checked.
                        var PreV1= w.tabs[2].add ('checkbox {text: "To Preview Changes"}');
                        var Pan1=w.tabs[2].add ('panel {text: "", preferredSize: [-1, 200],orientation: "column",alignChildren: ["left","top"]}');
                  // Is there a way to make each radio button display a Different Pictrue?
                                Pan1.add('radioButton {text: "B1.   Enter Here1"}');
                                Pan1.add('radioButton {text: "B2.   Enter Here2"}');
                                Pan1.add('radioButton {text: "B3.   Enter Here3"}');
                                Pan1.add('radioButton {text: "B4.   Enter Here4"}');
                                Pan1.add('radioButton {text: "B1.   Enter Here5"}');
                                Pan1.add('radioButton {text: "B2.   Enter Here6"}');
                                Pan1.add('radioButton {text: "B3.   Enter Here7"}');
                                Pan1.add('radioButton {text: "B4.   Enter Here8"}');
                           Image.prototype.onDraw =function()
                            if(!this.image )return;
                            var WH =this.size,wh   =this.image.size,k   = Math.min(WH[0]/wh[0], WH[1]/wh[1]), xy;
                              wh   =[k*wh[0],k*wh[1]];
                              xy   =[(WH[0]-wh[0])/2, (WH[1]-wh[1])/2 ];
                            this.graphics.drawImage(this.image,xy[0],xy[1],wh[0],wh[1]);
                               WH   = wh = xy =null;
                           flower.size =[300,300];
                    for(
                    var i = 0;
                     i < w.tabs.length;
                     i++){
                    function
                     showTab ()
                     i--)
                    showTab;
                // How do i make each CHECK BOX RunCH1/2/3 Only work when they are selected?  I cannot figure out how to make 2&3 Work.
                    if(myResult == 1 && (RunCH1.value==true || RunCH2.value2==true || RunCH3.value3==true) ){
                        alert("Changes have been made!")
                       w.close (true);
                    if(myResult == 2 && (RunCH2.value==true)
                        alert("RunCH2 DONE")
                      w.close (true);
                     if(myResult == 3 && (RunCH3.value==true)
                        alert("RunCH3 DONE")
                            w.close (true);
                //app.selection[0];
                • 5. Re: More Scripting Help needed please.
                  cbishop01 Level 2
                  Ok i kinda have the Check box search going.  Let me know what i'm doing wrong.  If i select the "RunCH1" CHeck box it will replace all those values.  If i Select just the RunCH2 Check box it does RunCH1 and RunCH2.  and if i select just the RunCH3 box it RunCH1 and RunCH3 work.  and if i select them all they all work to gether.  Here's the code i used.  I am assuming its because all 3 are in that first line of code.  BUt if i delete the CH2 and 3 from the first line nothing happens when i click the check box for them.
                      if(myResult == 1 && (RunCH1.value==true || RunCH2.value==true || RunCH3.value==true) ){
                          if(myResult == 1 && (RunCH2.value==true) ){
                              Replace_TXT("test", "asdfasdfasdfadsfasdfasdfasdfadfasdfasdf");
                          if(myResult == 1 && (RunCH3.value==true) ){
                              Replace_TXT("and", "TEST");
                          w.close(true);
                  //app.selection[0];
                  • 6. Re: More Scripting Help needed please.
                    cbishop01 Level 2
                    There was another potential problem.  How can i make this search for case sensitive characters?  For instance If i do the below code
                            w.close(true);
                    ("and", "TEST"); and Changes all instances.  and And AND ANd etc.. how can i make this case sensitive.  I would only need RUNCH 2 and 3 to be case sensitive.  I'm going to mess with this more this weekend but i have no clue where to go from here on this part.
                    • 7. Re: More Scripting Help needed please.
                      tpk1982 Level 4
                      answer:
                      press advance editor available on right corner of your reply..select your code..apply as the below diagram
                      • 8. Re: More Scripting Help needed please.
                        tpk1982 Level 4
                        for case sensitive you have to add app.findChangeTextOptions.caseSensitive = true; in your find and replace function like below
                        • 9. Re: More Scripting Help needed please.
                          cbishop01 Level 2
                          I'm glad your here i was putting that case sensitive code everywhere in this code except where you shown above thanks you again for everything your helping with.  This code is almost perfect just a few more tweeks and all will be good.
                          • 10. Re: More Scripting Help needed please.
                            cbishop01 Level 2
                            My questions are on Lines 01, 06, 31, and 68.  I have asked some of these before but this is a cleaner. looking copy
                                               WH   = wh = xy =null;
                                    for(
                                    var i = 0;
                                     i < w.tabs.length;
                                     i++){
                                    function
                                     showTab ()
                                     i--)
                                    showTab;
                            • 11. Re: More Scripting Help needed please.
                              cbishop01 Level 2
                              I updated my above question some of the answers i got answered from other posts.  now i just basically need to know how to do the
                              #6 and #1.  #1 is more of a flashy thing so if its too difficult dont worry about it. thanks again.
                              • 12. Re: More Scripting Help needed please.
                                cbishop01 Level 2
                                am i on the right path?  I turned off the lower radio buttons to give me more room to play with.
                                  radioButton = Pan1.add ('radioButton {text: "Pic1"}')
                                                Image.prototype.onDraw =function(){
                                                   WH   = wh = xy =null;}
                                                   flower=w.tabs[0].add ("image", undefined, File ("/Volumes/PPG/z-z MISC STUFF/INDESIGN SCRIPTS/Running CHanges/mop-bucket.jpg"));
