1 Reply Latest reply on May 6, 2016 12:12 AM by Nanaky
    now no operation-"error! Check activation" every time I try to read anything
    Ole Possum
      was working fine. Now every time I attempt to open anything to read, I just get "Error! Check activation." Any way to fix this? Seems like such a great idea. ?  I would hate to have just uninstall ADE 4.5 and Overdrive and just forget about using it.  It was fine for a few months> Any help available?
        • 1. Re: now no operation-"error! Check activation" every time I try to read anything
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
