2 Replies Latest reply on May 1, 2006 9:12 AM by PepperKev
    Testing my swf files
    Scubacam2002
      I'm converting a video for a client to Flash for their website using After Effects. I need to test the file after exporting it and can't figure out how to do it. I have the Flash Plug In installed. I have never done this, (obviously). Your help would be appreciated. Testing SWF files
        • 1. Re: Testing my swf files
          Level 7
          Scubacam2002,
          What is the file -- SWF, FLV?
          > (obviously).
          Either embed the SWF (assuming SWF, here) in an HTML page, per the
          instructions below, or open your browser and drag the SWF into the browser
          window.
          http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_4150
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Testing my swf files
            PepperKev Level 1
            I'm not going to repeat or gainsay advice already given, just going to add a side notes: Flash objects exported from After Efffects tend to be very large. You'd be better off to export a .mov, import it into flash, and create from there. You'll have more flexibility with it too. I understand you might not know flash, but just something to think about! The after effects problem was one of the problems that pushed me towards learning Flash.
            Cheers!
