6 Replies Latest reply on May 7, 2016 7:09 PM by JefferyBag O' Donuts
    Trying to find out what version of Adobe Premier is compatible with my computer
      Hello everyone, I'm in the process of transitioning over to Adobe Video Editing Software. I've used Final Cut Pro for the past (12) years and I'm finally jumping ship. I was wondering if I could have some guidance as to what Adobe Editing Version would work best with my Machine. I have a Power Mac Pro (Mid) 2010. Listed below are my specs. Comparing what my machine is comprised of and bouncing these specs off my mine is like trying to read hieroglyphics, at least for me. Thank you all for your help and I'm really excited to begin using this software and interacting online with what I'm sure are to be some very technically savvy technicians and artists. Thank you!
      Processing
      8-core (standard configuration) Two 2.4GHz Quad-Core Intel Xeon E5620 “Westmere” processors
      12MB of fully shared L3 cache per processor
      Turbo Boost dynamic performance up to 2.66GHz Hyper-Threading technology for up to 16 virtual cores
      Quad-core
      (standard configuration) One 2.8GHz Quad-Core Intel Xeon W3530 “Nehalem” processor
      8MB of fully shared L3 cache per processor
      Turbo Boost dynamic performance up to 3.06GHz
      Hyper-Threading technology for up to 8 virtual cores
      Advanced Intel microarchitecture
      Integrated memory controller
      128-bit SSE4 SIMD engine
      64-bit data paths and registers
      Optimized for energy efficiency
      Connections for Audio
      Four FireWire 800 ports (two on front panel, two on back panel)
      Five USB 2.0 ports (two on front panel, three on back panel)
      Two USB 2.0 ports on included keyboard
      Front-panel headphone minijack and internal speaker
      Optical digital audio input and output TOSLINK ports
      Analog stereo line-level input and output minijacks
      Multichannel audio through Mini DisplayPort
      Graphics and displays
      Double-wide, 16-lane PCI Express 2.0 graphics slot with one of the following graphics cards installed:
      ATI Radeon HD 5770 with 1GB of GDDR5 memory, PCI Express 2.0, two Mini DisplayPort outputs, and one dual-link DVI port
      ATI Radeon HD 5870 with 1GB of GDDR5 memory, PCI Express 2.0, two Mini DisplayPort outputs, and one dual-link DVI port
      Option to install two ATI Radeon HD 5770 cards
      Support for up to six displays
      Support for digital resolutions up to 2560 by 1600 pixels
      Support for analog resolutions up to 2048 by 1536 pixels
      Video adapters available for:
      Additional DVI output using Mini DisplayPort to DVI Adapter (optional)
      Additional dual-link DVI output using Mini DisplayPort to Dual-Link DVI Adapter (optional)
      VGA output using Mini DisplayPort to VGA Adapter or DVI to VGA Display Adapter (optional)
      Memory
      Dual-processor systems
      2.4GHz system: 1066MHz DDR3 ECC SDRAM
      2.66GHz and 2.93GHz systems: 1333MHz DDR3 ECC SDRAM
      Eight memory slots (four per processor) supporting up to 64GB of main memory using 1GB, 2GB, 4GB, or 8GB DIMMs
      Single-processor systems
      2.8GHz and 3.2GHz systems: 1066MHz DDR3 ECC SDRAM
      3.33GHz system: 1333MHz DDR3 ECC SDRAM
      Four memory slots supporting up to 32GB of main memory using 1GB, 2GB, 4GB, or 8GB DIMMs
