2 Replies Latest reply on May 8, 2016 8:31 AM by gkaiseril
    Multiple if statements
    Nsmjc Level 1
      I am using this javascrpit which works well
      if (this.getField("CheckBox2").isBoxChecked(0)=="1")
      {event.value=this.getField("ofTrainingDays").value*10.00;} else event.value = 0;
      if (event.value==0)
      1. event.value="";
      I need to add a statement to the start of it to check the status of check box 3.   So if checkbox 3 is checked then the rest of the formula will be ignored and the "ofTrainingDays" will have a value of 0.
      if (this.getField("CheckBox3").isBoxChecked(0)=="1")
      {event.value=this.getField("ofTrainingDays").value0;} else
      if (event.value==0)
      1. event.value="";
      However this does not work correctly any Ideas
        • 1. Re: Multiple if statements
          JR_Boulay Adobe Community Professional
          Hi.
          In this case there is no need to get the value of a checkbox, it's checked or not.
          Try this :
          if (this.getField("CheckBox3").isBoxChecked(0)) {
              event.value = this.getField("ofTrainingDays").value;
          else if (this.getField("CheckBox2").isBoxChecked(0)) {
              event.value = this.getField("ofTrainingDays").value * 10;
          else {
               event.value = "";
          • 2. Re: Multiple if statements
            Since the field will either have the calculated value or a null string as a result, one can default the field value to a null string and then only set the field's value if the boxed is checked. I prefer to use the value of the check box in case the form is changed to have 2 check boxes for this item. An unslelected check box will have a value of "Off" so any value not equal to "Off" means the box has been checked.
            event.value = "";
            if (this.getField("CheckBox3").value  != "Off")  {
