2 Replies Latest reply on May 3, 2006 11:59 PM by Gods_Lonely_Man
    flash component scrolling
    Gods_Lonely_Man Level 1
      on the stage i got a Tree flash component and it filled with more items then you can see. So there is a scrollbar which works just fine. But i want to make it scroll when you use the mousewheel .
      I downloaded the wheelmouse extra and it works just fine with a normal (non-flash) textfield. But with flash component it does nothing at all. So i put a button on stage and added the following script:
      quote:
      on mouseUp me
      sprite("tree").scrollByLine(1)
      end
      which gives me a error:
      quote:
      Handerler nog found in object
      #scrollByLine
      When i change the flash component with a normal textfield it works just fine. What is the right command/handler to do this with a flash component?
