2 Replies Latest reply on May 9, 2016 6:54 AM by cbishop01
    Search Script Troubles !!
    cbishop01 Level 2
      Ok i thought i had this working but apparently i did not.  How can i get this to Search for only each object that's checked in the check box?  and Display a dialog box telling what all has been changed when certain check boxes are checked.  RunCH1, RunCH2, and RunCH3 are the names of the check boxes i have.  I thought i had the find/replace working yesterday but i must have not been paying attention. it will do the first set of changes and teh second but it will not do the 3rd change.  and no matter which one i have selected (or not selected) i get all 3 alert messages.  I only want the alert message for the selected change.  If you need the rest of teh code let me know and i'll paste it below.  Thanks in advance.
      // How do i make each CHECK BOX RunCH1/2/3 Only work when they are selected?  I cannot figure out how to make 2&3 Work.
              if(myResult == 1 && (RunCH1.value==true || RunCH2.value==true || RunCH3.value==true) ){
                  alert("Find and Replace Items Have been made.!")
                      Replace_TXT(" <CR> ", "^p");
                      Replace_TXT(" <CR>", "^p");
                      Replace_TXT("  ", " ");
                      Replace_TXT(" :", ":");
                      Replace_TXT(" .", ".");
                      Replace_TXT("^p^p", "^p");
                  if(myResult == 2 && (RunCH2.value==true ) );
                      Replace_TXT ("test", "asdfasdfasdfadsfasdfasdfasdfadfasdfasdf");
                          alert ("RunCH2 Changes Made")
                  if(myResult == 3 && (RunCH3.value==true) ){
                      Replace_TXT("and", "TEST");
                         alert ("RunCH3 Changes Made")
                  w.close(true);
          function Replace_TXT(input, output)
          app.findChangeTextOptions.caseSensitive = true;
          app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
          app.findTextPreferences.findWhat = input;
          app.changeTextPreferences.changeTo = output;
          app.activeDocument.changeText();
        • 1. Re: Search Script Troubles !!
          tpk1982 Level 4
          try this with your main script file what you posted in other thread.. i think your requirement is big.. the myResult==1 is used whether we pressed ok and 2 is for we pressed cancel.. hope you understood now
          if(myResult == 1 && (RunCH1.value==true)){
          if(myResult == 1 && (RunCH2.value==true ) ){
          if(myResult == 1 && (RunCH3.value==true) ){
          w.close(true);
          • 2. Re: Search Script Troubles !!
            cbishop01 Level 2
            You my friend are a miracle worker. Thanks again.
