3 Replies Latest reply on May 9, 2016 11:21 PM by karthiks94217840
    Select, Cut, Paste Table Script
    micheller81371267 Level 1
      Hello, any body who can help create a script that can select a table from a text frame, cut and paste on a paste board. I worked with XML that flows to my InDesign template. The tables comes in with the text frame. A cut and paste process consumes my time especially having 100+ tables in the document.
      Thank you!
      Michelle
        • 1. Re: Select, Cut, Paste Table Script
          tpk1982 Level 4
          this will useful to cut all tables and paste in the same page (not pasteboard)
          var myTable = app.activeDocument.stories.everyItem().tables.everyItem().getElements();
          for(var i=0; i<myTable.length; i++)
              myTable[i].select()
              app.cut()
              app.paste()
          Karthi
          • 2. Re: Select, Cut, Paste Table Script
            karthiks94217840 Level 2
            Hi
            XML work flow? try this
            var myDocument = app.activeDocument;
            var root = myDocument.xmlElements[0];
            var myXMLidElement = root.evaluateXPathExpression("//footnote");  //("//table");
            alert(myXMLidElement.length);
            for (var i = 0; i < myXMLidElement.length; i++)
              myDocument.select(myXMLidElement[i]);
              var myTextframe = myXMLidElement[i].placeIntoInlineFrame(["26.5p","5p"]);
              myTextframe.fit(FitOptions.FRAME_TO_CONTENT);
            myTextframe.anchoredObjectSettings.anchoredPosition = AnchorPosition.ANCHORED;
            myTextframe.anchoredObjectSettings.anchorPoint = AnchorPoint.BOTTOM_LEFT_ANCHOR;
            myTextframe.anchoredObjectSettings.horizontalAlignment = HorizontalAlignment.LEFT_ALIGN;
            myTextframe.anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
            myTextframe.anchoredObjectSettings.anchorXoffset = "30p";
            //~ myTextframe.anchoredObjectSettings.anchorYoffset = "36p";
            myTextframe.textWrapPreferences.textWrapMode = TextWrapModes.BOUNDING_BOX_TEXT_WRAP;
            myTextframe.textWrapPreferences.textWrapOffset = new Array (".5p", 0, ".5p", 0)
            alert("Done")
            • 3. Re: Select, Cut, Paste Table Script
              Hi
              Don't use above coding.
              Try this one
              var myXMLidElement = root.evaluateXPathExpression("//table");
              alert("Done")
