0 Replies Latest reply on May 10, 2016 12:19 AM by someyagoel
    Customized combobox does not populate data at first click after flex migration from 3.2 to 4.6
    someyagoel
      I am facing this issue after flex migration. The customized combobox does not show any data at first click but show data after first click.
      Below are the screenshots of the problem.
      <mx:GridItem width = "100%">
                       <controls:CustomizedSearchableComboBox width = "100%"
                           height="24"
                           styleName="unitDetails"
                           id="area"
                           labelField="areaName"
                          close="onFilterAreaClose(event)"
                          dataProvider="{areas}" />
      </mx:GridItem>
      package controls
          import flash.events.Event;
          import mx.collections.IViewCursor;
          import mx.events.CollectionEvent;
          import mx.events.FlexEvent;
          import mx.events.ListEvent;
          public class CustomizedSearchableComboBox extends CustomizedPatchedComboBox {
              private static const MIN_VALUE:int = 5;
              private static const MID_VALUE:int = 10;
              private static const MAX_VALUE:int = 15;
              override public function set showDataTips(value:Boolean):void {
                  super.showDataTips = value;
              public function search(fieldName: String, fieldValue: *): Boolean {
                  if (collection && collection.length && fieldName) {
                      var cursor: IViewCursor = collection.createCursor();
                      var item: Object;
                      if (fieldValue is Number && isNaN(fieldValue))
                          fieldValue = null;
                      var currentValue: *;
                      while ((item = cursor.current)) {
                          if (item != null) {
                              try {
                                  currentValue = item[fieldName];
                                  if (typeof(currentValue) == "Number" && isNaN(currentValue)){
                                      currentValue = null;
                                  if (currentValue == fieldValue) {
                                      selectedItem = item;
                                      return true;
                              catch (e: Error) { }
                          cursor.moveNext();
                  selectedIndex = -1;
                  return false;
               * Overrides setting of dataprovider to this combobox.
               * Also manipulates combobox row count based on the data provider's length.
              override public function set dataProvider(value:Object):void {
                  if (value != null) {
                      super.dataProvider = value;
                      if (value.hasOwnProperty('length')) {
                          if (value.length != 0) {
                              changeRowCount(value.length);
                  super.dataProvider.removeEventListener(CollectionEvent.COLLECTION_CHANGE, dataChangeHandler);
                  super.dataProvider.addEventListener(CollectionEvent.COLLECTION_CHANGE, dataChangeHandler);
              private function dataChangeHandler(event:Event):void {
                  if (dataProvider.hasOwnProperty('length')) {
                      if (dataProvider.length != 0) {
                          changeRowCount(dataProvider.length);
               * Changes combobox row count based on the data's length and constants defined in this class.
              private function changeRowCount(value:int):void {
                  if (value > MAX_VALUE) {
                      this.rowCount = MAX_VALUE;
                  } else if (value > MID_VALUE && value < MAX_VALUE) {
                      this.rowCount = MID_VALUE;
                  } else if (value > MIN_VALUE && value <= MID_VALUE) {
                      this.rowCount = value;
      package controls
          import mx.controls.ComboBox;
          import mx.core.ClassFactory;
          public class CustomizedPatchedComboBox extends AutoCompleteCombo {
              private var savedText: String;
              private var _classFactory:ClassFactory;
              private var _showDataTips:Boolean;
              public function CustomizedPatchedComboBox() {
                  super();
                  _classFactory = new ClassFactory(PatchedList);
                  dropdownFactory = _classFactory;
                  lookAhead = false;
                  setStyle("arrowButtonWidth", 22);
                  filterFunction = Filter;
              private function Filter(element:*, text:String):Boolean
                  var label:String = itemToLabel(element);
                  if (label.length>0)
                      return (label.toLowerCase().indexOf(text.toLowerCase())>-1);
                   return true;
                  this._showDataTips = value;
                  setDataTipFunction();
              public function get showDataTips():Boolean {
                  return _showDataTips;
              public function set editorData(value: Object): void {
                  if (value is XMLList) {
                      for each (var child: XML in value){
                      if (child.localName() == "value") {
                          value = String(child.text()[0]);
                          break;
                          value = "";
                  else if (value is XML) {
                      if (value.localName() == "value")
                          value = String(value.text()[0]);
                      else value = "";
                  if (value is String && value) {
                      text = String(value);
                      typedText = String(value);
                      for each (var item: Object in collection){
                      if (itemToLabel(item) == value) {
                          return;
                  else if (value)
                      for each (item in collection){
                      if (item.id == value.id) {
                          return;
                      else text = "";
                  selectedIndex = -1;
              public function get editorData(): Object {
                  return text;
              public function setDefaultValue(value: Object): void {
                  editorData = value;
              private function setDataTipFunction():void {
                  _classFactory.properties = {showDataTips:showDataTips, dataTipFunction:dataTipFunction};
              private function dataTipFunction(item:Object): String {
                  return item.hasOwnProperty('toolTip') ? item.toolTip : "";
              override public function itemToLabel(item: Object, ...rest): String {
                  if (labelFunction == null && typeof(item) == "object")
                      try {
                          if (item[labelField] == null ||
                              item[labelField] is Number && isNaN(item[labelField])) return "";
                  catch (e: Error) {
                      return "";
                  return super.itemToLabel(item);
      import mx.controls.List;
      class PatchedList extends List {
          override public function itemToLabel(item: Object): String {
                  try {
              catch (e: Error) {
                  return "";
