2 Replies Latest reply on May 9, 2016 11:55 PM by Derek Cross
    Question: Help With ID Crash When Using "Place" Command
    RonS68
      InDesign crashes when I try to "Place" a text file. It's doing it with a plain text file and MS Word version. If I copy and paste text into doc, when i click the red plus sign at the bottom of text frame, load my cursor with overflow text, it also crashes when I click to place text that way. I have manually deleted my prefs. I'm using a Macbook pro, El Cap. Here's the stuff from error message when it crashes:
      Process:           Adobe InDesign CC 2015 [626]
      Path:              /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Identifier:        com.adobe.InDesign
      Version:           11.3.0.34 (11300)
      Code Type:         X86-64 (Native)
      Parent Process:    ??? [1]
      Responsible:       Adobe InDesign CC 2015 [626]
      User ID:           501
      Date/Time:         2016-05-09 23:14:21.795 -0400
      OS Version:        Mac OS X 10.11.4 (15E65)
      Report Version:    11
      Anonymous UUID:    51DDE03A-FE01-152D-3030-45D689E6F256
      Time Awake Since Boot: 1200 seconds
      System Integrity Protection: enabled
      Crashed Thread:    0  Dispatch queue: com.apple.main-thread
      Exception Type:    EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:   KERN_INVALID_ADDRESS at 0x0000000000000000
      Exception Note:    EXC_CORPSE_NOTIFY
      VM Regions Near 0:
      __TEXT             0000000104af1000-0000000104af6000 [   20K] r-x/rwx SM=COW  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Global Trace Buffer (reverse chronological seconds):
      3.092505 libextension.dylib   0x00007fff983ba533 tearing down extension request for pid 760
      3.092533 libextension.dylib   0x00007fff983ba533 tearing down extension request for pid 761
      3.092591 libextension.dylib   0x00007fff983ba533 tearing down extension request for pid 762
      150.554841   CFNetwork            0x00007fff8e238447 TCP Conn 0x7faded935660 SSL Handshake DONE
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   com.adobe.InDesign.Spread 0x000000011b10d8d7 0x11b10a000 + 14551
      1   com.adobe.InDesign.Text  0x000000011bcb9abc 0x11bc7a000 + 260796
      2   com.adobe.InDesign.Text  0x000000011bcb107f 0x11bc7a000 + 225407
      3   com.adobe.InDesign.Text  0x000000011bcaf881 0x11bc7a000 + 219265
      4   com.adobe.InDesign.Spline 0x000000011b0357a1 0x11b02c000 + 38817
      5   com.adobe.InDesign.Layout UI 0x000000011740b771 0x117324000 + 948081
      6   com.adobe.InDesign.Layout UI 0x0000000117409e14 0x117324000 + 941588
      7   WidgetBinLib.dylib       0x0000000104e15d28 CPathCreationTracker::EndTracking(IEvent*) + 40
      8   com.adobe.InDesign.Layout UI 0x000000011740e6aa 0x117324000 + 960170
      9   WidgetBinLib.dylib       0x0000000104e1ee47 CTrackerEventHandler::LButtonUp(IEvent*) + 151
      10  PublicLib.dylib          0x0000000105f3b253 CEventDispatcher::DispatchToEventHandlers(IEvent*) + 451
      11  PublicLib.dylib          0x0000000105f3b07d CEventDispatcher::DispatchEvent(IEvent*, IEvent::BaseEventHandledState) + 13
      12  com.adobe.InDesign.Application UI    0x00000001147d9586 0x114645000 + 1656198
      13  com.adobe.InDesign.Application UI    0x00000001147d91b5 0x114645000 + 1655221
      14  com.adobe.dvaui.framework 0x000000010581492c dvaui::ui::UI_Node::UI_DoPrePointerEvent(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 44
      15  com.adobe.dvaui.framework 0x00000001058105b6 dvaui::ui::UI_Node::UI_DispatchPrePointerEvent(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 326
      16  com.adobe.dvaui.framework 0x000000010581034e dvaui::ui::UI_Node::DispatchPointerEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 94
      17  com.adobe.dvaui.framework 0x0000000105818a06 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 182
      18  com.adobe.dvaui.framework 0x00000001058189ea std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 154
      19  com.adobe.dvaui.framework 0x00000001058189ea std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 154
      20  com.adobe.dvaui.framework 0x00000001058189ea std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 154
      21  com.adobe.dvaui.framework 0x00000001058189ea std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 154
      22  com.adobe.dvaui.framework 0x000000010580f8ef dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeaf(dvaui::ui::PointerEvent const&, bool) + 63
      23  com.adobe.dvaui.framework 0x000000010580f058 dvaui::ui::UI_Node::UI_DispatchPointerEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool) + 360
      24  com.adobe.dvaui.framework 0x000000010580ee42 dvaui::ui::UI_Node::UI_DispatchPointerEvent(dvaui::ui::PointerEvent const&, bool) + 66
      25  com.adobe.dvaui.framework 0x0000000105893720 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 608
      26  com.adobe.dvaui.framework 0x00000001058932ae dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 606
      27  com.adobe.dvaui.framework 0x0000000105891629 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 121
      28  com.adobe.dvaui.framework 0x0000000105891586 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
      29  com.adobe.dvaui.framework 0x0000000105892d55 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 69
      30  com.adobe.dvacore.framework  0x00000001051c6ebc int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      31  com.adobe.InDesign.Application UI    0x00000001147c69d2 0x114645000 + 1579474
      32  com.adobe.dvacore.framework  0x00000001051c7010 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 144
      33  com.adobe.dvacore.framework  0x00000001051c8505 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 165
      34  com.adobe.dvaui.framework 0x000000010589e3ea dvaui::ui::OS_NodeTimerData::RemoveTimer() + 29738
      35  com.apple.AppKit         0x00007fff9e0c67b3 -[NSWindow _handleMouseUpEvent:isDelayedEvent:] + 119
      36  com.apple.AppKit         0x00007fff9e0c744d -[NSWindow _reallySendEvent:isDelayedEvent:] + 212
      37  com.apple.AppKit         0x00007fff9db0663d -[NSWindow sendEvent:] + 517
      38  com.adobe.owl            0x000000010501114d 0x104fd6000 + 241997
      39  com.apple.AppKit         0x00007fff9da86b3c -[NSApplication sendEvent:] + 2540
      40  com.adobe.dvaui.framework 0x000000010589739b dvaui::ui::OS_NodeTimerData::RemoveTimer() + 987
      41  com.adobe.exo.framework  0x000000010757997a exo::app::OS_AppBase::SetResetMenuShortcutsOnClose(bool) + 842
      42  DV_WidgetBinLib.dylib    0x0000000104bd5bf5 0x104b31000 + 674805
      43  com.adobe.InDesign.Application UI    0x00000001147d15ae 0x114645000 + 1623470
      44  com.apple.AppKit         0x00007fff9d8edef6 -[NSApplication run] + 796
      45  com.adobe.exo.framework  0x00000001075793a8 exo::app::OS_AppBase::RunEventLoop() + 56
      46  com.adobe.InDesign.AppFramework    0x000000011452bad3 0x1143da000 + 1383123
      47  com.adobe.InDesign.AppFramework    0x000000011452a88e 0x1143da000 + 1378446
      48  com.adobe.InDesign       0x0000000104af268d main + 285
      49  libdyld.dylib            0x00007fff8de875ad start + 1
      Thread 1:
      0   libsystem_kernel.dylib   0x00007fff90c235e2 __workq_kernreturn + 10
      1   libsystem_pthread.dylib  0x00007fff9c2b1578 _pthread_wqthread + 1283
      2   libsystem_pthread.dylib  0x00007fff9c2af341 start_wqthread + 13
      Thread 2:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib   0x00007fff90c23efa kevent_qos + 10
      1   libdispatch.dylib        0x00007fff8ce6f165 _dispatch_mgr_invoke + 216
      2   libdispatch.dylib        0x00007fff8ce6edcd _dispatch_mgr_thread + 52
      Thread 3:: com.apple.NSURLConnectionLoader
      0   libsystem_kernel.dylib   0x00007fff90c1cf72 mach_msg_trap + 10
      1   libsystem_kernel.dylib   0x00007fff90c1c3b3 mach_msg + 55
      2   com.apple.CoreFoundation 0x00007fff8e65f1c4 __CFRunLoopServiceMachPort + 212
      3   com.apple.CoreFoundation 0x00007fff8e65e68c __CFRunLoopRun + 1356
      4   com.apple.CoreFoundation 0x00007fff8e65ded8 CFRunLoopRunSpecific + 296
      5   com.apple.CFNetwork      0x00007fff8e1fd111 +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
      6   com.apple.Foundation     0x00007fff97eb9d64 __NSThread__start__ + 1351
      7   libsystem_pthread.dylib  0x00007fff9c2b199d _pthread_body + 131
      8   libsystem_pthread.dylib  0x00007fff9c2b191a _pthread_start + 168
      9   libsystem_pthread.dylib  0x00007fff9c2af351 thread_start + 13
      Thread 4:
      0   libsystem_kernel.dylib   0x00007fff90c22fba __recvfrom + 10
      1   VulcanMessage5.dylib     0x000000010961f386 0x109601000 + 123782
      2   VulcanMessage5.dylib     0x000000010961e5fd 0x109601000 + 120317
      3   VulcanMessage5.dylib     0x000000010961d9b8 0x109601000 + 117176
      4   VulcanMessage5.dylib     0x000000010961d8ee 0x109601000 + 116974
      5   VulcanMessage5.dylib     0x0000000109618498 0x109601000 + 95384
      6   VulcanMessage5.dylib     0x0000000109618936 0x109601000 + 96566
      7   VulcanMessage5.dylib     0x00000001096188dd 0x109601000 + 96477
      8   VulcanMessage5.dylib     0x000000010961c762 0x109601000 + 112482
      9   VulcanMessage5.dylib     0x000000010961c489 0x109601000 + 111753
      10  VulcanMessage5.dylib     0x000000010961c10a 0x109601000 + 110858
      11  VulcanMessage5.dylib     0x000000010961c05d 0x109601000 + 110685
      12  VulcanMessage5.dylib     0x000000010960ee66 0x109601000 + 56934
      13  VulcanMessage5.dylib     0x000000010960f91f 0x109601000 + 59679
      14  VulcanMessage5.dylib     0x000000010961d288 0x109601000 + 115336
      15  VulcanMessage5.dylib     0x000000010961eda9 0x109601000 + 122281
      16  libsystem_pthread.dylib  0x00007fff9c2b199d _pthread_body + 131
      17  libsystem_pthread.dylib  0x00007fff9c2b191a _pthread_start + 168
      18  libsystem_pthread.dylib  0x00007fff9c2af351 thread_start + 13
      Thread 5:: com.apple.CFSocket.private
      0   libsystem_kernel.dylib   0x00007fff90c2307a __select + 10
      1   com.apple.CoreFoundation 0x00007fff8e69c4fa __CFSocketManager + 762
      2   libsystem_pthread.dylib  0x00007fff9c2b199d _pthread_body + 131
      3   libsystem_pthread.dylib  0x00007fff9c2b191a _pthread_start + 168
      4   libsystem_pthread.dylib  0x00007fff9c2af351 thread_start + 13
      Thread 6:: UxTech Queue ThreadController
      0   libsystem_kernel.dylib   0x00007fff90c22db6 __psynch_cvwait + 10
      1   libsystem_pthread.dylib  0x00007fff9c2b2728 _pthread_cond_wait + 767
      2   libtypekitC4Release.dylib 0x0000000107c4b52b 0x107c47000 + 17707
      3   libtypekitC4Release.dylib 0x0000000107ca21ab 0x107c47000 + 373163
      4   libtypekitC4Release.dylib 0x0000000107ca066b 0x107c47000 + 366187
      5   libtypekitC4Release.dylib 0x0000000107c492e4 0x107c47000 + 8932
      Thread 7:: UxTech Queue ThreadController
      Thread 8:: UxTech Queue ThreadController
      Thread 9:: UxTech Queue ThreadController
      Thread 10:: UxTech Queue ThreadController
      Thread 11:: UxTech Queue ThreadController
      Thread 12:: UxTech Queue ThreadController
      Thread 13:: UxTech Queue ThreadController
      Thread 14:
      2   com.adobe.InDesign.AppFramework    0x0000000114514b21 0x1143da000 + 1288993
      3   com.adobe.InDesign.AppFramework    0x0000000114513ff8 0x1143da000 + 1286136
      4   com.adobe.InDesign.AppFramework    0x0000000114511390 0x1143da000 + 1274768
      5   com.adobe.InDesign.AppFramework    0x00000001145159d2 0x1143da000 + 1292754
      6   com.adobe.boost_threads.framework    0x0000000105ea78d4 boost::thread::start_thread_noexcept() + 388
      Thread 15:
      Thread 16:
      0   libsystem_kernel.dylib   0x00007fff90c2310a __semwait_signal + 10
      1   libsystem_c.dylib        0x00007fff8cd84d17 nanosleep + 199
      2   com.adobe.InDesign.Support for JavaScript    0x000000011b396658 0x11b33c000 + 370264
      3   com.adobe.InDesign.Support for JavaScript    0x000000011b37beac 0x11b33c000 + 261804
      4   com.adobe.InDesign.Support for JavaScript    0x000000011b396135 0x11b33c000 + 368949
      5   libsystem_pthread.dylib  0x00007fff9c2b199d _pthread_body + 131
      6   libsystem_pthread.dylib  0x00007fff9c2b191a _pthread_start + 168
      7   libsystem_pthread.dylib  0x00007fff9c2af351 thread_start + 13
      Thread 17:
      5   com.apple.Foundation     0x00007fff97fc0ff5 -[NSConnection run] + 149
      Thread 18:
      5   com.apple.Foundation     0x00007fff97f52d19 -[NSConcreteTask waitUntilExit] + 205
      6   com.adobe.PlugPlugOwl    0x000000010797c378 0x1078bf000 + 775032
      7   com.apple.Foundation     0x00007fff97eb9d64 __NSThread__start__ + 1351
      8   libsystem_pthread.dylib  0x00007fff9c2b199d _pthread_body + 131
      9   libsystem_pthread.dylib  0x00007fff9c2b191a _pthread_start + 168
      10  libsystem_pthread.dylib  0x00007fff9c2af351 thread_start + 13
      Thread 19:
      Thread 20:
      Thread 21:: MPSupport Worker
      2   MultiProcessor Support   0x0000000126eca94b 0x126e83000 + 293195
      3   MultiProcessor Support   0x0000000126eca84b 0x126e83000 + 292939
      4   MultiProcessor Support   0x0000000126eead84 0x126e83000 + 425348
      Thread 22:: MPSupport Worker
      Thread 23:: MPSupport Worker
      Thread 24:: MPSupport Worker
      Thread 25:: MPSupport Worker
      Thread 26:: MPSupport Worker
      Thread 27:: MPSupport Worker
      Thread 28:
      0   libsystem_kernel.dylib   0x00007fff90c1cfae semaphore_wait_trap + 10
      1   libtbb.dylib             0x0000000107db7e16 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 598
      2   com.adobe.InDesign.Layout UI 0x000000011743afc9 0x117324000 + 1142729
      3   com.adobe.boost_threads.framework    0x0000000105ea78d4 boost::thread::start_thread_noexcept() + 388
      4   libsystem_pthread.dylib  0x00007fff9c2b199d _pthread_body + 131
      5   libsystem_pthread.dylib  0x00007fff9c2b191a _pthread_start + 168
      6   libsystem_pthread.dylib  0x00007fff9c2af351 thread_start + 13
      Thread 29:
      Thread 30:
      Thread 31:
      Thread 32:
      Thread 33:: UxTech Queue ThreadController
      Thread 34:
      3   com.adobe.InDesign.AppFramework    0x0000000114513f50 0x1143da000 + 1285968
      Thread 35:
      Thread 36:: com.apple.NSEventThread
      5   com.apple.AppKit         0x00007fff9da4fe99 _NSEventThread + 149
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 40:
      Thread 41:
      3   com.adobe.InDesign.AppFramework    0x0000000114513e78 0x1143da000 + 1285752
      Thread 42:
      Thread 43:
      Thread 44:
      Thread 45:
      Thread 46:
      Thread 47:
      Thread 48:
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000028  rbx: 0x00007fadfad5b6d0  rcx: 0x00007fadf8dad050  rdx: 0x0000000000000000
        rdi: 0x0000000000000000  rsi: 0x00000000ffffffff  rbp: 0x00007fff5b10bea0  rsp: 0x00007fff5b10bc00
         r8: 0x000000000000050f   r9: 0x0000000000000166  r10: 0x00007fff5b10ba60  r11: 0x00007fff5b10ba60
        r12: 0x00007fadf7a760a0  r13: 0x0000000000000000  r14: 0x00007fff5b10c098  r15: 0x00007fadf2f8f650
        rip: 0x000000011b10d8d7  rfl: 0x0000000000010206  cr2: 0x0000000000000000
      Logical CPU: 0
      Error Code:  0x00000004
      Trap Number: 14
      Binary Images:
         0x104af1000 -    0x104af5ffe +com.adobe.InDesign (11.3.0.34 - 11300) <47BF0DF0-8E88-379B-B96E-CAE9BD701AE5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
         0x104b01000 -    0x104b01ff7 +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <FB61F9A6-DE48-3A5E-A074-B023C1686C20> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
         0x104b0c000 -    0x104b13fff +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <C9132B00-211C-3CFB-AD48-3634187E763D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
         0x104b1d000 -    0x104b27ffd +ASLSupportLib.dylib (0) <E212D47A-07C8-31E6-A790-413B0646F302> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/ASLSupportLib.dylib
         0x104b31000 -    0x104c31ff5 +DV_WidgetBinLib.dylib (0) <10D1D937-C556-385E-B344-97118EB2C2A6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DV_WidgetBinLib.dylib
         0x104d6e000 -    0x104daefff +TextPanelLib.dylib (0) <55354B10-A54A-3C2D-9516-CA6B336DE297> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/TextPanelLib.dylib
         0x104dc9000 -    0x104f14ff1 +WidgetBinLib.dylib (0) <55BF1C8C-8C85-38C8-82FD-A25859714BB6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/WidgetBinLib.dylib
         0x104fd6000 -    0x105158ff3 +com.adobe.owl (AdobeOwl version 5.2.8 - 5.2.8) <1FD74414-2361-3075-8CD2-49F0E5F4B204> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
         0x1051a4000 -    0x10544dff7 +com.adobe.dvacore.framework (8.0.849323 - 8.0.849323.0) <A31691E5-B549-3D7F-A09A-3C516F03B4DE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
         0x105523000 -    0x105a99fff +com.adobe.dvaui.framework (8.0.849323 - 8.0.849323.0) <4CF0E362-FFE6-33D4-BD65-F9DE527AA58D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
         0x105e9d000 -    0x105e9dff7 +com.adobe.InDesign.InDesignModel (9.0 - 0) <A9C36234-F5A9-30E4-8C8F-6FAD52ED3FA3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
         0x105ea6000 -    0x105eb4ff7 +com.adobe.boost_threads.framework (8.0.849323 - 8.0.849323.0) <EBAAC8B1-42F3-3374-B2F4-3C5EEF8B81D6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x105ecf000 -    0x105ed0ff7 +com.adobe.boost_system.framework (8.0.849323 - 8.0.849323.0) <87DE3714-5B63-36F8-9C80-A6D1708AD4FC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
         0x105eda000 -    0x105edfff7 +com.adobe.boost_date_time.framework (8.0.849323 - 8.0.849323.0) <F009B658-6063-3989-A418-04C79A3C6F69> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x105ef0000 -    0x10632dffd +PublicLib.dylib (0) <AF00F27F-CA85-30E4-8EDF-98A091455D2D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PublicLib.dylib
         0x106481000 -    0x10648aff7 +PMRuntime.dylib (0) <B473E542-1734-38D7-9ADA-EB0866E96E4B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PMRuntime.dylib
         0x106494000 -    0x106495ffe +com.adobe.InDesign.Metadata Database Filter (11.3.0.34 - 0) <E4128E3B-04B9-3A72-970B-ECEC5E678197> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
         0x10649a000 -    0x1064abfff +com.adobe.AFL (AdobeAFL 2.0.0 - 2.0) <BF9D724B-D40A-3250-8A0F-6F978D3904AA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
         0x1064bf000 -    0x10681cfff +com.adobe.CoolType (AdobeCoolType 5.15.00.35138 - 5.15.00.35138) <E750B0C0-428C-36F7-A6EF-07D8E8A95F06> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
         0x106867000 -    0x106888fff +com.adobe.BIB (AdobeBIB 1.2.03.35138 - 1.2.03.35138) <11EBACBD-C7F8-3E80-A2BF-E87543B5CE11> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
         0x106894000 -    0x1069f3ff7 +com.adobe.ACE (AdobeACE 2.20.02.35138 - 2.20.02.35138) <84F6B526-935A-3C14-8E1F-C9E0020C4C2D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
         0x106a0c000 -    0x106fc3ff7 +com.adobe.AGM (AdobeAGM 4.30.60.35138 - 4.30.60.35138) <D1ABE574-F911-3486-9BA0-6405B57E02EF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
         0x10706a000 -    0x1070a6fff +com.adobe.ARE (AdobeARE 1.5.02.35138 - 1.5.02.35138) <54AA8EE4-A877-31A5-A089-835F4F144217> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
         0x1070b2000 -    0x1070d8ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6536192E-56D1-3EF0-97A9-04630B74CE0C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
         0x1070e1000 -    0x1074a6ff7 +com.adobe.MPS (AdobeMPS 5.8.1.35322 - 5.8.1.35322) <8326036D-9A1F-3DB6-8399-C93C39ABF98C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
         0x10751d000 -    0x107543fff +com.adobe.dvaflashview.framework (8.0.849323 - 8.0.849323.0) <15B2C28F-002C-3D1F-9FB7-DC78E9A57D6D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
         0x107562000 -    0x107566ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
         0x107570000 -    0x107642ff7 +com.adobe.exo.framework (8.0.849323 - 8.0.849323.0) <4181A343-0B17-3F95-9FA2-723C1F008677> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
         0x107706000 -    0x1077e8ff7 +com.adobe.dvaworkspace.framework (8.0.849323 - 8.0.849323.0) <9ED6BCAA-4089-3E41-8370-60CC4408FF5A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
         0x1078b9000 -    0x1078b9fff  com.apple.applescript.component (2.5 - 377) <D205C65F-E27A-3D14-9F22-B8224F2C657C> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
         0x1078bf000 -    0x107bdefef +com.adobe.PlugPlugOwl (6.1.0.164 - 6.1.0.164) <A397592C-8FD9-3466-8B36-603B755B8109> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
         0x107c40000 -    0x107c41ff6 +com.adobe.InDesign.Global Preferences Panel (11.3.0.34 - 0) <9F993B33-64F2-311A-A489-02183FB5C38F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
         0x107c47000 -    0x107d94ffb +libtypekitC4Release.dylib (0) <48E2AF5A-27D9-3EAC-B43C-CF7FC9294597> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/libtypekitC4Release.dylib
         0x107db6000 -    0x107de6fef +libtbb.dylib (0) <D41FA1F0-4921-308A-93DF-4D16F8913472> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/libtbb.dylib
         0x107e03000 -    0x107e28fff +libtbbmalloc.dylib (0) <60EF4F46-298B-38B6-A6CD-9B168072EAB7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/libtbbmalloc.dylib
         0x107e52000 -    0x107e53fff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
         0x107e58000 -    0x108b9dfff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
         0x108bb5000 -    0x108cf0fff +com.adobe.ICUInternationalization (4.0 - 3.61) <CEAE369B-B601-30D5-9563-6C2AB781AF27> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternatio nalization
         0x108d45000 -    0x108d45fe7 +cl_kernels (???) <4CA00031-BCE5-4A1F-B9EB-EA39789B5D5E> cl_kernels
         0x108d49000 -    0x108e4cff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
         0x108e86000 -    0x108fbdff7 +com.winsoft.wrservices (WRServices 11.0.0 - 11.0.0) <A1AF94EB-8B13-305C-8B8C-8E420BA0DD0A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
         0x10901f000 -    0x109120fff +com.adobe.amtlib (9.0.0.21 - 9.0.0.21) <BAE71CEB-B622-38DB-A0A2-796C0BEB4E03> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
         0x109139000 -    0x10913cfff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
         0x10914b000 -    0x109213ff7 +com.adobe.boost_regex.framework (8.0.849323 - 8.0.849323.0) <63917B23-C82F-3B2A-BE24-20FB0B7BC928> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
         0x10928f000 -    0x109325fff +com.adobe.adobe_caps (adobe_caps 9.0.0.5 - 9.0.0.5) <71BDFB88-91D4-35B1-9860-82F31ACBDE38> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
         0x10933a000 -    0x109346ff7 +com.adobe.boost_signals.framework (8.0.849323 - 8.0.849323.0) <10D19241-C273-3F9B-AC55-233D74206BF1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
         0x10935a000 -    0x1094a3ff7 +com.adobe.AIDE (1.5.0 - 1.5.0.35275) <F520E0A6-0536-368A-BF04-97BA4475B2ED> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
         0x109504000 -    0x1095adff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
         0x1095d3000 -    0x1095f3ff7 +VulcanControl.dylib (5.2.0.38 - 5.2.0.38 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <84C6B6F1-3CBA-3B79-AA47-7C7EA7F43FD8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/VulcanControl.dylib
         0x109601000 -    0x109639ff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
         0x10964c000 -    0x1096a6ff4 +DataBaseLib.dylib (0) <92FFA356-92EB-3E68-914D-6380F38113D7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DataBaseLib.dylib
         0x1096c1000 -    0x10971effd +ObjectModelLib.dylib (0) <6FEEA1C0-5614-3845-BD6D-FF608709F3AE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/ObjectModelLib.dylib
         0x10973d000 -    0x109763fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.35348 - 3.8.0.35348) <A1F25502-8A55-3300-ACB8-66507CE1B6B9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
         0x10da93000 -    0x10da97fff  libFontRegistryUI.dylib (155.1) <79B125DD-4565-391D-A084-DB4F2A7CF322> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
         0x10e3b6000 -    0x10e3f6ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.3 - 9.0.0.3) <2F5B40E6-812C-34E0-A8AC-02F55D770D49> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
         0x10fc82000 -    0x10fc87ff7 +com.adobe.InDesign.Data Services UI (11.3.0.34 - 0) <9262186D-E075-36C5-B827-A3016012FF27> /Applications/Adobe InDesign CC 2015/*/Data Services UI
         0x10fc8f000 -    0x10fc95ff4 +com.adobe.InDesign.Data Services (11.3.0.34 - 0) <B07286D0-7F16-36E1-B3EC-1C51597828D1> /Applications/Adobe InDesign CC 2015/*/Data Services
         0x10fc9b000 -    0x10fca6ff0 +com.adobe.InDesign.DTTransform (11.3.0.34 - 0) <907FE07B-72F1-34C5-BE6C-98A40BE44B71> /Applications/Adobe InDesign CC 2015/*/DTTransform
         0x10fcaf000 -    0x10fce5ff6 +com.adobe.InDesign.Dictionary Editor Dialog (11.3.0.34 - 0) <B1EE846E-E57B-3CD4-9163-E2AFCE26D8F4> /Applications/Adobe InDesign CC 2015/*/Dictionary Editor Dialog
         0x10fd05000 -    0x10fd29fff +com.adobe.InDesign.LILO (11.3.0.34 - 0) <9AC600D7-792C-387C-B665-310E31026CAA> /Applications/Adobe InDesign CC 2015/*/LILO
         0x10fd37000 -    0x10fe1efff +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <7C403E13-460B-3576-B7BB-E2A88287B15D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
         0x10fe3b000 -    0x11009aff9 +com.adobe.InDesign.EBookExport (11.3.0.34 - 0) <F272B6CD-8DE3-33CD-A2ED-B4BABDCE8E65> /Applications/Adobe InDesign CC 2015/*/EBookExport
         0x1100d1000 -    0x11011aff2 +com.adobe.InDesign.Media Import Filter (11.3.0.34 - 0) <945F0BC1-02F4-39A9-B576-893C40C247BF> /Applications/Adobe InDesign CC 2015/*/Media Import Filter
         0x11012c000 -    0x110134ff4 +com.adobe.InDesign.PNG Import Filter UI (11.3.0.34 - 0) <6F3736DF-C568-3923-BB49-9BCD1E9B5DA6> /Applications/Adobe InDesign CC 2015/*/PNG Import Filter UI
         0x11013c000 -    0x110160ff4 +com.adobe.InDesign.Sangam Preferences UI (11.3.0.34 - 0) <64B3D31C-E307-368E-B47D-910DCF5E53D3> /Applications/Adobe InDesign CC 2015/*/Sangam Preferences UI
         0x110173000 -    0x1101edfff +com.adobe.AdobeSangam (AdobeSangam 5.65.0.35249 - 5.65.0.35249) <1ED86DE4-0919-3325-A50C-B74ED78AC9DE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
         0x11023d000 -    0x110399ff1 +com.adobe.InDesign.SangamServicer-Mapper (11.3.0.34 - 0) <F0AF037A-00BB-39CE-9175-A533E90745B9> /Applications/Adobe InDesign CC 2015/*/SangamServicer-Mapper
         0x1103c8000 -    0x1103ddff1 +com.adobe.InDesign.SaveBack (11.3.0.34 - 0) <F924B1C4-DA6A-317A-BC6E-37C6AE930633> /Applications/Adobe InDesign CC 2015/*/SaveBack
         0x1103eb000 -    0x1103edffe +com.adobe.InDesign.SimpleTextImportFilter (11.3.0.34 - 0) <1B37191F-E611-3CA8-87D5-BF3055CC6863> /Applications/Adobe InDesign CC 2015/*/SimpleTextImportFilter
         0x1103f3000 -    0x11047eff9 +com.adobe.InDesign.Tagged Text Attributes (11.3.0.34 - 0) <2CC31F7B-D3B1-3E2D-8A1F-46D12E3377D4> /Applications/Adobe InDesign CC 2015/*/Tagged Text Attributes
         0x1104ad000 -    0x1104b6ff6 +com.adobe.InDesign.Tagged Text Filters UI (11.3.0.34 - 0) <746A9030-E937-3708-AB3D-B3A985FE9971> /Applications/Adobe InDesign CC 2015/*/Tagged Text Filters UI
         0x1104c0000 -    0x11055dff2 +com.adobe.InDesign.Tagged Text Filters (11.3.0.34 - 0) <F97D6B2E-EE27-33EA-8EFE-67352F6E3B21> /Applications/Adobe InDesign CC 2015/*/Tagged Text Filters
         0x110571000 -    0x11057bff3 +com.adobe.InDesign.Clipping Path Dialog (11.3.0.34 - 0) <6DD9FF02-80B7-3C5F-A32C-782DECC56BC3> /Applications/Adobe InDesign CC 2015/*/Clipping Path Dialog
         0x11058b000 -    0x1105caff9 +com.adobe.InDesign.Color Management UI (11.3.0.34 - 0) <FC8C9CD4-5510-398A-BB77-A0057FC80113> /Applications/Adobe InDesign CC 2015/*/Color Management UI
         0x1105d9000 -    0x11065cffe +com.adobe.InDesign.Color Picker Panel (11.3.0.34 - 0) <6D64FC0D-9502-321E-974C-5EF2474026DD> /Applications/Adobe InDesign CC 2015/*/Color Picker Panel
         0x110686000 -    0x110693fff +com.adobe.InDesign.Digital Publishing UI (11.2.0.1 - 0) <708BBEF2-D366-395A-8215-2D53DBC44C7E> /Applications/Adobe InDesign CC 2015/*/Digital Publishing UI
         0x1106a5000 -    0x1106b3fff +com.adobe.boost_filesystem.framework (8.0.849323 - 8.0.849323.0) <3D20399B-8243-3387-99CA-8E923498B8C5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
         0x1106c0000 -    0x1108d7ffb +com.adobe.InDesign.Digital Publishing (11.2.0.35 - 0) <DC32BE3B-4696-35DC-A252-1AE266A6817F> /Applications/Adobe InDesign CC 2015/*/Digital Publishing
         0x110a54000 -    0x110a8cfef +libcurl.4.dylib (7) <FA1D87DC-8CBC-3645-8ADA-D974B6EDED53> /Applications/Adobe InDesign CC 2015/*/libcurl.4.dylib
         0x110a97000 -    0x110b0eff0 +com.adobe.InDesign.DynamicDocumentsUI (11.3.0.34 - 0) <3596495B-76D4-3296-A778-176FEE311B08> /Applications/Adobe InDesign CC 2015/*/DynamicDocumentsUI
         0x110b34000 -    0x110b4cff7 +com.adobe.InDesign.EPS UI (11.3.0.34 - 0) <5544A396-B390-3DF5-87C5-1DE518533B87> /Applications/Adobe InDesign CC 2015/*/EPS UI
         0x110b5c000 -    0x110b64ff4 +com.adobe.InDesign.Generic Style Editor (11.3.0.34 - 0) <95698B55-A79E-3321-B50C-53DF9785C919> /Applications/Adobe InDesign CC 2015/*/Generic Style Editor
         0x110b71000 -    0x110ba4ffb +com.adobe.InDesign.Gradient Panel (11.3.0.34 - 0) <A90C5DDE-36AD-3ABA-9F17-ACE355F7E24E> /Applications/Adobe InDesign CC 2015/*/Gradient Panel
         0x110bba000 -    0x110c61ff4 +com.adobe.InDesign.Graphic Panels (11.3.0.34 - 0) <C15194C5-22DE-3188-A332-49EB99C87063> /Applications/Adobe InDesign CC 2015/*/Graphic Panels
         0x110c8a000 -    0x110c90ff1 +com.adobe.InDesign.JPEG Export UI (11.3.0.34 - 0) <992C7EED-A1AE-3BA6-9530-02F7A8298C45> /Applications/Adobe InDesign CC 2015/*/JPEG Export UI
         0x110c98000 -    0x110cafff7 +com.adobe.InDesign.JPEG Export (11.3.0.34 - 0) <9DA43952-1CAB-310C-BCEC-323F9C3A0803> /Applications/Adobe InDesign CC 2015/*/JPEG Export
         0x110cc0000 -    0x110d0aff3 +com.adobe.InDesign.Output Preview (11.3.0.34 - 0) <1DCACA80-9E48-3C23-80B6-08FF02D4C88E> /Applications/Adobe InDesign CC 2015/*/Output Preview
         0x110d23000 -    0x110d37ff4 +com.adobe.InDesign.OutputMiscUI (11.3.0.34 - 0) <2587FBF9-48E5-3424-8437-C70A2B64DDFC> /Applications/Adobe InDesign CC 2015/*/OutputMiscUI
         0x110d48000 -    0x110dc1ff2 +com.adobe.InDesign.PDF UI (11.3.0.34 - 0) <7955CEA1-8948-3D54-BE50-B7791857419D> /Applications/Adobe InDesign CC 2015/*/PDF UI
         0x110de4000 -    0x110f5afff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 111 - 79.158366) <01F03185-A123-3511-B739-A135591052E1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
         0x110f91000 -    0x110fa4ff8 +com.adobe.InDesign.Printer Styles (11.3.0.34 - 0) <7E079564-E9E3-3ABC-A58F-95B3715E30BD> /Applications/Adobe InDesign CC 2015/*/Printer Styles
         0x110fb2000 -    0x111083ff5 +com.adobe.InDesign.PrintUI (11.3.0.34 - 0) <EA6E3764-AB02-3B5E-AF66-65C1A74E84C1> /Applications/Adobe InDesign CC 2015/*/PrintUI
         0x1110ad000 -    0x1110bcff8 +com.adobe.InDesign.PS Import UI (11.3.0.34 - 0) <33F2213D-54FD-3A6D-85DE-50F4E6D91232> /Applications/Adobe InDesign CC 2015/*/PS Import UI
         0x1110ca000 -    0x1110ebffc +com.adobe.InDesign.Swatch Library Panel (11.3.0.34 - 0) <6BE96B7C-2191-3220-8F89-315082A74BC1> /Applications/Adobe InDesign CC 2015/*/Swatch Library Panel
         0x1110f9000 -    0x1111c9ff2 +com.adobe.InDesign.Swatches Panel (11.3.0.34 - 0) <11EB8E03-DEB8-3E00-9250-22122271B3FB> /Applications/Adobe InDesign CC 2015/*/Swatches Panel
         0x111202000 -    0x11129fff7 +com.adobe.InDesign.Transparency UI (11.3.0.34 - 0) <03E9C63B-7931-3D2E-8A56-105E8529FE32> /Applications/Adobe InDesign CC 2015/*/Transparency UI
         0x1112d1000 -    0x11132cff9 +com.adobe.InDesign.Assignment UI (11.3.0.34 - 0) <9091A366-A166-3997-AC11-A66566CE76FB> /Applications/Adobe InDesign CC 2015/*/Assignment UI
         0x11134d000 -    0x11136cff0 +com.adobe.InDesign.InCopy Bridge UI (11.3.0.34 - 0) <50E7461B-459B-3D7E-8660-CA0EA9A2FFBC> /Applications/Adobe InDesign CC 2015/*/InCopy Bridge UI
         0x111378000 -    0x1113b0ffa +com.adobe.InDesign.InCopy Bridge (11.3.0.34 - 0) <58B9EA11-15CE-3C34-BD84-A666218DC157> /Applications/Adobe InDesign CC 2015/*/InCopy Bridge
         0x1113c0000 -    0x1113c7ff8 +com.adobe.InDesign.InCopyExport (11.3.0.34 - 0) <390FA732-55AD-3F1B-9E08-B610E43D9940> /Applications/Adobe InDesign CC 2015/*/InCopyExport
         0x1113d0000 -    0x1113d5ffe +com.adobe.InDesign.InCopyExportUI (11.3.0.34 - 0) <41D41A7B-8779-3EC5-B99E-6064057854DE> /Applications/Adobe InDesign CC 2015/*/InCopyExportUI
         0x1113dc000 -    0x1113e2ff3 +com.adobe.InDesign.InCopyImport (11.3.0.34 - 0) <92AE81B7-8E01-360F-9926-40A4A6C8CBEB> /Applications/Adobe InDesign CC 2015/*/InCopyImport
         0x1113e9000 -    0x1113eeff1 +com.adobe.InDesign.InCopyWorkflow UI (11.3.0.34 - 0) <DC377B71-C639-38A4-A3B9-E2C21B80E10D> /Applications/Adobe InDesign CC 2015/*/InCopyWorkflow UI
         0x1113f7000 -    0x111448ff6 +com.adobe.InDesign.Note (11.3.0.34 - 0) <57893C55-52DD-3C3D-AD9A-08FF8B20EE76> /Applications/Adobe InDesign CC 2015/*/Note
         0x111467000 -    0x11146fff5 +com.adobe.InDesign.NotePref (11.3.0.34 - 0) <D5CDF3E5-558D-3908-B874-0563AF81BC3B> /Applications/Adobe InDesign CC 2015/*/NotePref
         0x11147c000 -    0x11147fffe +com.adobe.InDesign.Username UI (11.3.0.34 - 0) <D00DFC4A-B366-30BC-9811-A2189631BE8F> /Applications/Adobe InDesign CC 2015/*/Username UI
         0x111487000 -    0x111515ff3 +com.adobe.InDesign.ButtonUI (11.3.0.34 - 0) <76F7878F-68A9-370F-BCA0-7AB7105EB7A1> /Applications/Adobe InDesign CC 2015/*/ButtonUI
         0x111543000 -    0x111569ff6 +com.adobe.InDesign.MediaUI (11.3.0.34 - 0) <54D6C450-BFED-327F-9D3C-082463A3C283> /Applications/Adobe InDesign CC 2015/*/MediaUI
         0x11157e000 -    0x11158bff9 +com.adobe.InDesign.Alignment Panel (11.3.0.34 - 0) <DE45D87C-AA84-3B56-84A1-EE5C32D12976> /Applications/Adobe InDesign CC 2015/*/Alignment Panel
         0x111593000 -    0x1115daff8 +com.adobe.InDesign.Asset Library Panel (11.3.0.34 - 0) <F44AF79F-377C-3AB1-BADC-929449F45063> /Applications/Adobe InDesign CC 2015/*/Asset Library Panel
         0x1115ff000 -    0x111660ff4 +com.adobe.InDesign.Asset PubLibrary (11.3.0.34 - 0) <246DC062-0135-344F-87B9-1BA61518B31C> /Applications/Adobe InDesign CC 2015/*/Asset PubLibrary
         0x11167e000 -    0x1116c5ff8 +com.adobe.InDesign.Book Panel (11.3.0.34 - 0) <51D59EF9-E2C0-3865-B53A-4C294B79BB1D> /Applications/Adobe InDesign CC 2015/*/Book Panel
         0x1116e7000 -    0x1116fefff +com.adobe.InDesign.Bookmark Panel (11.3.0.34 - 0) <42E48592-95F4-3C46-8361-FDE217A82369> /Applications/Adobe InDesign CC 2015/*/Bookmark Panel
         0x111713000 -    0x111742ff3 +com.adobe.InDesign.ContentDropper Tool (11.3.0.34 - 0) <0B5CADBD-8661-320F-9E5D-6B295897BAD9> /Applications/Adobe InDesign CC 2015/*/ContentDropper Tool
         0x111760000 -    0x111799ff7 +com.adobe.InDesign.Control Panel (11.3.0.34 - 0) <CE570F6A-6065-3B02-B903-0BCBBCD349C5> /Applications/Adobe InDesign CC 2015/*/Control Panel
         0x1117b4000 -    0x1117bcffb +com.adobe.InDesign.Create Guides Dialog (11.3.0.34 - 0) <D9294B13-0B7C-320B-A517-A1374FB2C0BC> /Applications/Adobe InDesign CC 2015/*/Create Guides Dialog
         0x1117c5000 -    0x111849ff8 +com.adobe.InDesign.Eyedropper Tool (11.3.0.34 - 0) <35B19C50-7AA2-3954-BC4B-1E055CC0CFEC> /Applications/Adobe InDesign CC 2015/*/Eyedropper Tool
         0x11186d000 -    0x11190aff8 +com.adobe.InDesign.Hyperlinks Panel (11.3.0.34 - 0) <84A93722-4B76-3461-9639-AFAA6C00D480> /Applications/Adobe InDesign CC 2015/*/Hyperlinks Panel
         0x111933000 -    0x1119baff4 +com.adobe.InDesign.Index Panel (11.3.0.34 - 0) <1562CC37-6E42-3440-84A6-C16317CDF5B9> /Applications/Adobe InDesign CC 2015/*/Index Panel
         0x1119d8000 -    0x1119e4ff7  com.apple.carbonframeworktemplate (1.0 - 1.0) <6F5D8218-7BB8-378F-A9EA-EF46B665DC63> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
         0x1119ef000 -    0x111a4bfff +com.adobe.InDesign.Info Panel (11.3.0.34 - 0) <E9132C30-3A49-3A36-BE1E-F0263AFD7B36> /Applications/Adobe InDesign CC 2015/*/Info Panel
         0x111a62000 -    0x111b0fffc +com.adobe.InDesign.Knowledge Base (11.3.0.34 - 0) <23D0A82F-3FFF-3414-9504-0F21E2510805> /Applications/Adobe InDesign CC 2015/*/Knowledge Base
         0x111b19000 -    0x111b62ff0 +com.adobe.InDesign.Layers Panel (11.3.0.34 - 0) <A12983C8-8650-321F-AE3F-16708FD19666> /Applications/Adobe InDesign CC 2015/*/Layers Panel
         0x111b82000 -    0x111b84ffa +com.adobe.InDesign.Layout Adjustment Panel (11.3.0.34 - 0) <AE7D85E3-AB90-3CE1-BCBD-9D830937FBA8> /Applications/Adobe InDesign CC 2015/*/Layout Adjustment Panel
         0x111b8c000 -    0x111ba7ff0 +com.adobe.InDesign.Layout Adjustment (11.3.0.34 - 0) <C66606A7-19E6-364F-9A1A-5C27DD65C01D> /Applications/Adobe InDesign CC 2015/*/Layout Adjustment
         0x111bb5000 -    0x111bfaff6 +com.adobe.InDesign.Links UI (11.3.0.34 - 0) <929AE24B-3AD7-3871-B521-B73F71A2B9E1> /Applications/Adobe InDesign CC 2015/*/Links UI
         0x111c1a000 -    0x111cb3ff2 +com.adobe.InDesign.ObjectStylesUI (11.3.0.34 - 0) <E4375963-50F7-3BAE-8E1E-F6166B843635> /Applications/Adobe InDesign CC 2015/*/ObjectStylesUI
         0x111ce1000 -    0x111d0dffd +com.adobe.InDesign.Page Setup Dialog (11.3.0.34 - 0) <E4ED900D-6F29-33A5-A3A4-480B0FADF00B> /Applications/Adobe InDesign CC 2015/*/Page Setup Dialog
         0x111d20000 -    0x111ddcffa +com.adobe.InDesign.Pages Panel (11.3.0.34 - 0) <8F366ED6-C642-3B91-AA9B-AD6CEFC7F62E> /Applications/Adobe InDesign CC 2015/*/Pages Panel
         0x111e0c000 -    0x111e17ff6 +com.adobe.InDesign.Sections UI (11.3.0.34 - 0) <18415F9C-26BB-30DF-B24C-33EB2857779A> /Applications/Adobe InDesign CC 2015/*/Sections UI
         0x111e20000 -    0x111e28ffc +com.adobe.InDesign.StepRepeat (11.3.0.34 - 0) <28DB8642-D7B1-31E0-A233-39B7B3CA2DBF> /Applications/Adobe InDesign CC 2015/*/StepRepeat
         0x111e32000 -    0x111e6bff3 +com.adobe.InDesign.Text Wrap Panel (11.3.0.34 - 0) <DF43F671-F7EF-3F67-B0EA-45EE8B38E260> /Applications/Adobe InDesign CC 2015/*/Text Wrap Panel
         0x111e82000 -    0x111ebeffe +com.adobe.InDesign.TOC UI Dialog (11.3.0.34 - 0) <14E0F2CD-7D26-39C8-B512-EED3B4413974> /Applications/Adobe InDesign CC 2015/*/TOC UI Dialog
         0x111ed6000 -    0x111f0bffe +com.adobe.InDesign.Transform Panel (11.3.0.34 - 0) <D9AB0EE9-C50F-31C6-92EA-F8A561B9E5A2> /Applications/Adobe InDesign CC 2015/*/Transform Panel
         0x111f1f000 -    0x111f36ffc +com.adobe.InDesign.Image Import UI (11.3.0.34 - 0) <0460DBE0-1DB2-3C32-8702-A6A8F11E0AC9> /Applications/Adobe InDesign CC 2015/*/Image Import UI
         0x111f47000 -    0x111f59ffa +com.adobe.InDesign.Scotch Rules (11.3.0.34 - 0) <5955BAC7-39E3-31D7-9B03-051BB3316C73> /Applications/Adobe InDesign CC 2015/*/Scotch Rules
         0x111f64000 -    0x111fbeffe +com.adobe.InDesign.BNUI (11.3.0.34 - 0) <3094F9B3-7632-30AF-A328-ECA2BA3C4C55> /Applications/Adobe InDesign CC 2015/*/BNUI
         0x111fdc000 -    0x11207eff0 +com.adobe.InDesign.DataMerge (11.3.0.34 - 0) <A231B633-E9B3-32F6-ACDD-F72D7DF930F6> /Applications/Adobe InDesign CC 2015/*/DataMerge
         0x11209e000 -    0x1120ceff1 +com.adobe.InDesign.DataMergeUI (11.3.0.34 - 0) <5BE2290E-1001-33C5-A00B-41DB0020FF47> /Applications/Adobe InDesign CC 2015/*/DataMergeUI
         0x1120e8000 -    0x1121e0ffb +com.adobe.InDesign.Package and Preflight UI (11.3.0.34 - 0) <2E969559-59D4-3A70-B7DA-C377179B6222> /Applications/Adobe InDesign CC 2015/*/Package and Preflight UI
         0x11221f000 -    0x11245eff7 +com.adobe.InDesign.Package and Preflight (11.3.0.34 - 0) <B727CBDB-72C1-3E58-B401-B7248C6E744A> /Applications/Adobe InDesign CC 2015/*/Package and Preflight
         0x1124a2000 -    0x112572ffe +com.adobe.InDesign.JBX (11.3.0.34 - 0) <70574EBA-FB1C-3A22-8741-6EE1DF970A28> /Applications/Adobe InDesign CC 2015/*/JBX
         0x11259c000 -    0x1125b6ff6 +com.adobe.InDesign.SavebackService (10.0.0 - 0) <8C10BB05-E75B-3767-902D-40E5D44B0283> /Applications/Adobe InDesign CC 2015/*/SavebackService
         0x1125c4000 -    0x1125c8ff2 +com.adobe.InDesign.Script Label Panel (11.3.0.34 - 0) <12860D29-31C9-38C3-B035-A5A02B24F757> /Applications/Adobe InDesign CC 2015/*/Script Label Panel
         0x1125d2000 -    0x1125ddff0 +com.adobe.InDesign.Scripts Panel (11.3.0.34 - 0) <CEC32465-A5F0-369B-9AB6-ACD7C545E72F> /Applications/Adobe InDesign CC 2015/*/Scripts Panel
         0x1125eb000 -    0x1126d5ffc +com.adobe.InDesign.Tables UI (11.3.0.34 - 0) <744F91FC-63B4-36B4-803A-51151509124F> /Applications/Adobe InDesign CC 2015/*/Tables UI
         0x112705000 -    0x1127a0ffc +com.adobe.InDesign.TableStylesUI (11.3.0.34 - 0) <7664CBC2-7D96-363A-A9D9-B89DF7662EC6> /Applications/Adobe InDesign CC 2015/*/TableStylesUI
         0x1127cb000 -    0x112854ff7 +com.adobe.InDesign.Character Panel (11.3.0.34 - 0) <879D76A5-2891-3277-A953-3409C16F7416> /Applications/Adobe InDesign CC 2015/*/Character Panel
         0x11289c000 -    0x1128c8ff4 +com.adobe.InDesign.Conditional Text UI (11.3.0.34 - 0) <281C4234-40AF-3A50-B6E9-7875FED43E2E> /Applications/Adobe InDesign CC 2015/*/Conditional Text UI
         0x1128e2000 -    0x1128fcff8 +com.adobe.InDesign.Create Outlines (11.3.0.34 - 0) <E7A3C134-C01F-36C4-89FB-3CFB59EBF3BB> /Applications/Adobe InDesign CC 2015/*/Create Outlines
         0x112909000 -    0x112a19ffb +com.adobe.InDesign.Find and Change Panel (11.3.0.34 - 0) <A5766618-7420-3A7F-8C0F-86F08C9A03AA> /Applications/Adobe InDesign CC 2015/*/Find and Change Panel
         0x112a55000 -    0x112a79ffa +com.adobe.InDesign.Find Change Format Panel (11.3.0.34 - 0) <D48DBC93-151D-3358-97E1-F6486D49DC7C> /Applications/Adobe InDesign CC 2015/*/Find Change Format Panel
         0x112a8b000 -    0x112ad1ff4 +com.adobe.InDesign.Font Usage Dialog (11.3.0.34 - 0) <76F9519F-FC8A-3BD9-993B-D3F627BC1719> /Applications/Adobe InDesign CC 2015/*/Font Usage Dialog
         0x112ae8000 -    0x112baaff8 +com.adobe.InDesign.Glyphs Panel (11.3.0.34 - 0) <67B5A62F-AA31-36A7-922F-0D4CF60F12C4> /Applications/Adobe InDesign CC 2015/*/Glyphs Panel
         0x112bcf000 -    0x112bd6ff4 +com.adobe.InDesign.Hyphenation Panel (11.3.0.34 - 0) <96168C06-BE35-3D97-9E41-DFA2676AB56E> /Applications/Adobe InDesign CC 2015/*/Hyphenation Panel
         0x112be3000 -    0x112bf3ff0 +com.adobe.InDesign.Indents and Tabs (11.3.0.34 - 0) <90027069-FD01-35E5-AA02-7AE68576CD90> /Applications/Adobe InDesign CC 2015/*/Indents and Tabs
         0x112c01000 -    0x112c07ff1 +com.adobe.InDesign.Justification Panel (11.3.0.34 - 0) <39141624-236D-3D47-93A5-909AA5F485C0> /Applications/Adobe InDesign CC 2015/*/Justification Panel
         0x112c11000 -    0x112c16ffb +com.adobe.InDesign.Keeps Panel (11.3.0.34 - 0) <D3586F8B-612B-3FB2-8CA2-448A34B51A38> /Applications/Adobe InDesign CC 2015/*/Keeps Panel
         0x112c1e000 -    0x112c3bff7 +com.adobe.InDesign.Optical Kerning (11.3.0.34 - 0) <2B2F9C99-5FFC-3801-B0F5-386093D655C8> /Applications/Adobe InDesign CC 2015/*/Optical Kerning
         0x112c47000 -    0x112c7dff8 +com.adobe.InDesign.Paragraph Panel (11.3.0.34 - 0) <7C776A5E-BB1D-38B3-B420-74EBD001E1F6> /Applications/Adobe InDesign CC 2015/*/Paragraph Panel
         0x112c92000 -    0x112ca1ff3 +com.adobe.InDesign.Paragraph Rules Panel (11.3.0.34 - 0) <E585EF65-DA55-390E-880D-FED680B1D3E3> /Applications/Adobe InDesign CC 2015/*/Paragraph Rules Panel
         0x112caa000 -    0x112cbdff8 +com.adobe.InDesign.Path Type UI (11.3.0.34 - 0) <E7E01F3E-B6EA-3F47-AEF2-CE686BF7BBA9> /Applications/Adobe InDesign CC 2015/*/Path Type UI
         0x112ccc000 -    0x112cd4ffb +PathTypeLib.dylib (0) <02ABE533-5966-3126-8F57-07C8D9A9BFE4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PathTypeLib.dylib
         0x112cdc000 -    0x112d03ff9 +com.adobe.InDesign.RunIn Styles Panel (11.3.0.34 - 0) <A2D60266-DCDA-3E05-B798-F93294E29A30> /Applications/Adobe InDesign CC 2015/*/RunIn Styles Panel
         0x112d14000 -    0x112d22ff1 +com.adobe.InDesign.SING (11.3.0.34 - 0) <B545D101-19A9-3E22-875E-0AE017BE0E75> /Applications/Adobe InDesign CC 2015/*/SING
         0x112d2b000 -    0x112d32ffe +com.adobe.InDesign.Span Columns Panel (11.3.0.34 - 0) <F50860E0-A04B-30A9-BFBE-9E2AFEA96654> /Applications/Adobe InDesign CC 2015/*/Span Columns Panel
         0x112d3a000 -    0x112d81ffc +com.adobe.InDesign.Spelling Panel (11.3.0.34 - 0) <36FD5C06-CB26-3CBA-863C-94006B5324A9> /Applications/Adobe InDesign CC 2015/*/Spelling Panel
         0x112d9a000 -    0x112daaffd +com.adobe.InDesign.Story Panel (11.3.0.34 - 0) <DCAD57EB-4162-32FE-9A3A-741837B4D49B> /Applications/Adobe InDesign CC 2015/*/Story Panel
         0x112db7000 -    0x112e29ff1 +com.adobe.InDesign.Style Panel (11.3.0.34 - 0) <B257FC18-8714-356E-9117-2EE90710D761> /Applications/Adobe InDesign CC 2015/*/Style Panel
         0x112e52000 -    0x112e5cffa +com.adobe.InDesign.Text Color Panel (11.3.0.34 - 0) <D7552C1E-BA09-3872-B242-1605B9E33AEB> /Applications/Adobe InDesign CC 2015/*/Text Color Panel
         0x112e64000 -    0x112e8cff6 +com.adobe.InDesign.Text Frame Options (11.3.0.34 - 0) <8DC8D5C9-E425-32C0-BF05-788D0A5AAE5F> /Applications/Adobe InDesign CC 2015/*/Text Frame Options
         0x112e9c000 -    0x112ef1ff4 +com.adobe.InDesign.Text Panel (11.3.0.34 - 0) <9C086637-BE9A-30C5-A6B9-F472A8324924> /Applications/Adobe InDesign CC 2015/*/Text Panel
         0x112f17000 -    0x112f34ff7 +com.adobe.InDesign.Text Preferences (11.3.0.34 - 0) <417FDE1B-797B-3C5B-A0BF-2517B75C8FBF> /Applications/Adobe InDesign CC 2015/*/Text Preferences
         0x112f43000 -    0x112f62ff0 +com.adobe.InDesign.Text Ruler (11.3.0.34 - 0) <8B507E4F-C035-3E71-91DF-B061CE79FA6F> /Applications/Adobe InDesign CC 2015/*/Text Ruler
         0x112f72000 -    0x112f95ff3 +com.adobe.InDesign.Text Style Panel (11.3.0.34 - 0) <F4E52FC6-F63E-3FAE-9697-DDB8D6E6B8EE> /Applications/Adobe InDesign CC 2015/*/Text Style Panel
         0x112fa5000 -    0x112fcdfff +com.adobe.InDesign.Article Panel (11.3.0.34 - 0) <5EBD18F3-9843-34F8-A84F-B1B9F4FB06CD> /Applications/Adobe InDesign CC 2015/*/Article Panel
         0x112fe5000 -    0x113062ffa +com.adobe.InDesign.CSXS (11.3.0.34 - 0) <4CF5A2AF-D15A-3750-876C-A7CF59183ABD> /Applications/Adobe InDesign CC 2015/*/CSXS
         0x113088000 -    0x1130bafff +com.adobe.InDesign.Galley Preferences (11.3.0.34 - 0) <C7E9EB40-BDE0-3334-948C-0AC8CFF67B6B> /Applications/Adobe InDesign CC 2015/*/Galley Preferences
         0x1130d3000 -    0x1130f1ffe +com.adobe.InDesign.GapTool (11.3.0.34 - 0) <870B94AC-DB63-33C2-AE1F-6099B79BF781> /Applications/Adobe InDesign CC 2015/*/GapTool
         0x1130ff000 -    0x113109ff5 +com.adobe.InDesign.General Preferences Panel (11.3.0.34 - 0) <2D5BA01E-11B6-37C1-AE4A-434067F1A59A> /Applications/Adobe InDesign CC 2015/*/General Preferences Panel
         0x113113000 -    0x113115ff2 +com.adobe.InDesign.Help (11.3.0.34 - 0) <89332B21-33CF-31C0-A801-ABC6621C376B> /Applications/Adobe InDesign CC 2015/*/Help
         0x11311b000 -    0x113137fff +com.adobe.ahclientframework (2.0.0.1 - 2.0.0.1) <075BD455-9D2E-3B8A-8C83-8B40D3059A55> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
         0x11313f000 -    0x113156ff9 +com.adobe.InDesign.Performance UI (11.3.0.34 - 0) <947F9BC8-62A1-3C96-A6E5-1708091E5F65> /Applications/Adobe InDesign CC 2015/*/Performance UI
         0x11316a000 -    0x11318aff9 +com.adobe.InDesign.SharedContentUI (11.3.0.34 - 0) <BAD8D50B-6E27-30E5-A259-5FEC6D041EA3> /Applications/Adobe InDesign CC 2015/*/SharedContentUI
         0x113199000 -    0x1131b9ffc +com.adobe.InDesign.Shortcut Editor Dialog (11.3.0.34 - 0) <76248687-C16F-38FA-A0C5-71727B65A45B> /Applications/Adobe InDesign CC 2015/*/Shortcut Editor Dialog
         0x1131cc000 -    0x1131e8ffd +com.adobe.InDesign.Tool Box (11.3.0.34 - 0) <89E8426C-A5AD-3BD8-B994-3D3ABDA8784A> /Applications/Adobe InDesign CC 2015/*/Tool Box
         0x113213000 -    0x113218ffe +com.adobe.InDesign.Tool Tips (11.3.0.34 - 0) <B2C6222E-AAFB-3DC1-8612-E9561880D92F> /Applications/Adobe InDesign CC 2015/*/Tool Tips
         0x11321f000 -    0x113226ff1 +com.adobe.InDesign.Track Changes Preferences (11.3.0.34 - 0) <DEDF4704-C453-37F6-8308-1C565A4E7271> /Applications/Adobe InDesign CC 2015/*/Track Changes Preferences
         0x11322e000 -    0x113242ffe +com.adobe.InDesign.Track Changes UI (11.3.0.34 - 0) <A2425458-0FD4-3E80-B420-E6297DBD1D88> /Applications/Adobe InDesign CC 2015/*/Track Changes UI
         0x11324b000 -    0x113255ffe +com.adobe.InDesign.PerformanceMetrics (11.3.0.34 - 0) <7B9B8827-5189-32CB-9983-D2191C2DA47C> /Applications/Adobe InDesign CC 2015/*/PerformanceMetrics
         0x11325f000 -    0x113269ffb +com.adobe.InDesign.Metadata UI (11.3.0.34 - 0) <D62C3C72-D0AB-35B1-8372-71D7C6901F93> /Applications/Adobe InDesign CC 2015/*/Metadata UI
         0x113273000 -    0x1135c7ff7 +com.adobe.dvaadameve.framework (8.0.849323 - 8.0.849323.0) <05FF852B-4A93-3877-A419-92ECC7894AEE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
         0x113b05000 -    0x113bcfff7 +com.adobe.dvametadata.framework (8.0.849323 - 8.0.849323.0) <096B16F8-0DD8-385C-B43C-ECD2F0DF55B6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
         0x113c26000 -    0x113d30ff7 +com.adobe.dvametadataUI.framework (8.0.849323 - 8.0.849323.0) <436DC94C-C8F5-336B-869F-DD5D206251BF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
         0x113dc0000 -    0x113f1eff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 170 - 79.158366) <110630F4-A885-32D1-9463-1907443AC676> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
         0x113f58000 -    0x11401bff7 +com.adobe.dvaeve.framework (8.0.849323 - 8.0.849323.0) <1280617D-EC42-387B-B121-94E905B879AE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
         0x1140c9000 -    0x114126fff +com.adobe.dvatemporalxmp.framework (8.0.849323 - 8.0.849323.0) <47AA1FBB-0620-3422-B990-AE2F718E1E6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
         0x114145000 -    0x11417aff7 +com.adobe.dvamediatypes.framework (8.0.849323 - 8.0.849323.0) <9CA25F65-16A8-3A2C-92A4-3F15C487EB02> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
         0x114193000 -    0x11419aff6 +com.adobe.InDesign.Workgroup UI (11.3.0.34 - 0) <9841A93B-D846-33AD-9F87-D50297D9538C> /Applications/Adobe InDesign CC 2015/*/Workgroup UI
         0x1141a2000 -    0x1141ecffd +com.adobe.InDesign.Snippet (11.3.0.34 - 0) <8956390D-AAED-32FE-9102-8429671D6DDA> /Applications/Adobe InDesign CC 2015/*/Snippet
         0x114205000 -    0x114320ff2 +com.adobe.InDesign.XMedia UI (11.3.0.34 - 0) <D36456C5-D4FB-3F3D-BB85-2136700FD5E7> /Applications/Adobe InDesign CC 2015/*/XMedia UI
         0x114369000 -    0x1143bfff5 +com.adobe.InDesign.Actions (11.3.0.34 - 0) <02496D95-7FA1-3553-B3F3-601B1D15B880> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
         0x1143da000 -    0x1145a9ffe +com.adobe.InDesign.AppFramework (11.3.0.34 - 0) <77A5AE5D-CCDA-30B8-BDD2-510D96038D8F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
         0x114645000 -    0x11489cfe7 +com.adobe.InDesign.Application UI (11.3.0.34 - 0) <46E764B4-DABE-3342-80A8-1A0097A71B7D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
         0x114962000 -    0x114aa2fff +com.adobe.headlights.LogSessionFramework (7.3.1.72) <EE72ED3F-9A64-372D-A709-67F79995E15D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
         0x114b14000 -    0x114bbfff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.1) <79B05FB3-724B-3679-A9B7-E96511405E4F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
         0x114be6000 -    0x114c81fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.1) <B8F6ECB6-E6F8-3117-8CEF-BC00B5C924FE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
         0x114caa000 -    0x114cdffff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AgoraLib.dylib
         0x114d12000 -    0x114e61ff7 +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <64A92553-DF23-3A1E-8F12-64BCAD57A63D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
         0x114f88000 -    0x114fa9ff9 +com.adobe.InDesign.Article (11.3.0.34 - 0) <BEB98508-F460-3FA1-8C6E-112A851826B2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
         0x114fb8000 -    0x115048ffc +com.adobe.InDesign.Assignments (11.3.0.34 - 0) <2CB2287F-7FD2-3054-AC69-6BF0293E7865> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
         0x115069000 -    0x1150a3fff +com.adobe.InDesign.AWS (11.3.0.34 - 0) <E00E6971-7C5B-3F81-BCA2-C2312B38AD98> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
         0x1150bd000 -    0x1150e2ff7 +com.adobe.InDesign.AWSUI (11.3.0.34 - 0) <63BCB3FF-6CE4-3CE2-BA1C-858E41B9F000> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
         0x1150f6000 -    0x115127ffa +com.adobe.InDesign.Basic Tools (11.3.0.34 - 0) <C4A7D181-4D02-3F0E-9EE9-858DEA29ACC4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
         0x115142000 -    0x115194ff6 +com.adobe.InDesign.Behavior (11.3.0.34 - 0) <94E53F57-EBC6-326D-9DA2-9363E5F6C854> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
         0x1151b1000 -    0x115243ff1 +com.adobe.InDesign.BNCore (11.3.0.34 - 0) <E4047150-CBEC-3D71-8E89-0A485D7C9746> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
         0x115261000 -    0x1152bfffa +com.adobe.InDesign.Book (11.3.0.34 - 0) <6535EF6F-EF37-3637-8893-741E70BF23DC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
         0x1152d6000 -    0x11530affa +com.adobe.InDesign.CellStyles (11.3.0.34 - 0) <67294C6C-E601-3381-969C-F6F1E238E77A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
         0x11531d000 -    0x115393ff5 +com.adobe.InDesign.CJK Text Attributes (11.3.0.34 - 0) <E5D13C95-64B2-3DBE-95EA-F67A94B9BFA0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
         0x1153b6000 -    0x115434ffe +com.adobe.InDesign.CJKGrid (11.3.0.34 - 0) <547028FA-1E7F-3AC3-8D73-E8988878DC11> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
         0x115450000 -    0x11552ffff +com.adobe.InDesign.Color Management (11.3.0.34 - 0) <BA734B37-80A0-324E-85F4-01B83ABC2D99> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
         0x11555c000 -    0x1155beffd +com.adobe.InDesign.CompFontMgr (11.3.0.34 - 0) <972A747D-14AE-3480-A956-8E4E4BADFF4C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
         0x1155d8000 -    0x115628ff0 +com.adobe.InDesign.Conditional Text (11.3.0.34 - 0) <92DD3B70-7348-3183-85AD-A795850AC942> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
         0x115641000 -    0x11566effe +com.adobe.InDesign.ContentDropper (11.3.0.34 - 0) <5668D541-50FC-3E88-8BFE-94C609ACE93A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
         0x115681000 -    0x1156a2ff0 +com.adobe.InDesign.Dialog Layout (11.3.0.34 - 0) <1B17FA10-1C5E-3ABC-9818-E28624741649> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
         0x1156b3000 -    0x1156d8ff0 +com.adobe.InDesign.Document Actions (11.3.0.34 - 0) <2C8AA41F-97D0-3BD2-B077-C0AE5D5F647B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
         0x1156e5000 -    0x1158bcff1 +com.adobe.InDesign.Document Framework (11.3.0.34 - 0) <8BB21985-64E4-387E-BDEF-6B8BA63D602E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
         0x1158fd000 -    0x115906ff6 +com.adobe.InDesign.Document UI (11.3.0.34 - 0) <761D90E6-C904-3D68-B762-28DAAC8D661F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
         0x11590e000 -    0x115968ff0 +com.adobe.InDesign.DV_Widgets (11.3.0.34 - 0) <8745E7DC-CBA8-341F-9DB6-CB417F66CC6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
         0x1159d6000 -    0x115cebff3 +com.adobe.InDesign.Dynamic Documents (11.3.0.34 - 0) <B48C31DC-49F7-3CAA-B018-6E22C6913996> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
         0x115d36000 -    0x115e2dfff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.32362 - 2.1.0.32362) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
         0x115e4a000 -    0x116027ff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
         0x11604b000 -    0x11616bff4 +com.adobe.InDesign.EPS Page Item (11.3.0.34 - 0) <6320EFFC-B90C-3A28-99E0-A076B1BDE797> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
         0x1161ab000 -    0x1162b5fff +com.adobe.InDesign.Font Manager (11.3.0.34 - 0) <56314B9F-F2C4-32D2-835D-F5FD4DA42FE6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
         0x1162d7000 -    0x11639eff5 +com.adobe.InDesign.FormField (11.3.0.34 - 0) <7EB4ECEA-67BB-30A0-9834-68F5142CBB13> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
         0x1163c3000 -    0x11641bff4 +com.adobe.InDesign.Galley (11.3.0.34 - 0) <1264814F-844D-3B0C-BBB9-08076C69A889> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
         0x11642f000 -    0x11656dff6 +com.adobe.InDesign.GalleyUI (11.3.0.34 - 0) <28F0EE0D-FFAC-3BB5-B45B-5897E8B0D46D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
         0x11659d000 -    0x1167e9ff4 +com.adobe.InDesign.Generic Page Item (11.3.0.34 - 0) <055B5735-60BB-3F1F-91D4-5092BE32DFA4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
         0x116835000 -    0x116840ff5 +com.adobe.InDesign.GenericSettings (11.3.0.34 - 0) <E5C4D5B1-66EE-3DE1-A192-31F482F3ACC0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
         0x116849000 -    0x1168acff0 +com.adobe.InDesign.Gradient Fill (11.3.0.34 - 0) <0E5ABF62-D59D-3C67-9824-22050BFB179F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
         0x1168c7000 -    0x1169acff8 +com.adobe.InDesign.Graphics (11.3.0.34 - 0) <A616E87B-FE41-3CE8-A089-9B62ECCB0033> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
         0x1169cf000 -    0x1169daffa +com.adobe.InDesign.Group (11.3.0.34 - 0) <BCD4DF27-BA8B-36B0-A815-2E5502DADDD9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
         0x1169e6000 -    0x116a04ff6 +com.adobe.InDesign.Guides (11.3.0.34 - 0) <5E79084B-B18F-3FF5-9D91-ECA38F95A104> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
         0x116a15000 -    0x116ae2ffa +com.adobe.InDesign.HTMLPGT (11.3.0.34 - 0) <469D5C2A-F0BC-305B-A38E-404418939E0B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
         0x116b3c000 -    0x116c2fff8 +com.adobe.InDesign.Hyperlinks (11.3.0.34 - 0) <F3F769FA-F40B-3C7A-8C85-1CDF682E057B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
         0x116c59000 -    0x116ca5ffd +com.adobe.InDesign.Image Filters (11.3.0.34 - 0) <D6FE8938-62A9-3DFC-9DEF-62659EE0C052> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
         0x116cb2000 -    0x116dabffc +com.adobe.InDesign.Image (11.3.0.34 - 0) <FF71F7A9-820C-35DD-9F4A-DB9F6A6CF31F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
         0x116dd7000 -    0x116decff2 +com.adobe.InDesign.IME (11.3.0.34 - 0) <9CEAFB4F-EB65-3ACE-B5CC-3893352017A5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
         0x116dfb000 -    0x116eb5ffc +com.adobe.InDesign.Import Export UI (11.3.0.34 - 0) <29EF2DA2-11E0-30E6-B5CE-323EC706A97A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
         0x116ee7000 -    0x116fd9fff +com.adobe.InDesign.InCopyShared (11.3.0.34 - 0) <681FEC5E-3E51-3061-81CE-5EBE2524CF27> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
         0x117004000 -    0x11701fffc +com.adobe.InDesign.InCopySharedUI (11.3.0.34 - 0) <27A079E4-8208-3A7E-B79F-4700770FE5E1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
         0x11702f000 -    0x1170c9ff6 +com.adobe.InDesign.InCopyWorkflow (11.3.0.34 - 0) <4C672A76-4A63-35D7-B359-A6331624A3EF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
         0x1170ee000 -    0x1171e2ff1 +com.adobe.InDesign.Indexing (11.3.0.34 - 0) <FB513A35-08F4-3008-9380-2B9F111363E8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
         0x117203000 -    0x1172c0ff4 +com.adobe.InDesign.INXCore (11.3.0.34 - 0) <2FC3A0EC-F5BB-3A51-8BA0-CE2B34C9D0AE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
         0x1172e8000 -    0x117311ffc +com.adobe.InDesign.Layer (11.3.0.34 - 0) <70781FB3-F69D-3AB0-A4D1-03139AE8D955> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
         0x117324000 -    0x117563ff2 +com.adobe.InDesign.Layout UI (11.3.0.34 - 0) <28196C8E-7D89-364C-9FAC-6BC9C9F8A812> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
         0x1175d1000 -    0x1175f6fff +com.adobe.InDesign.Layout (11.3.0.34 - 0) <DD68C027-96B4-3B39-B17D-E9CEC1FF9EC6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
         0x117604000 -    0x11764affc +com.adobe.InDesign.Linguistics (11.3.0.34 - 0) <C6AC385B-5AD5-3D79-B408-A7FB5D84BE4A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
         0x117663000 -    0x1177b2ff0 +com.adobe.InDesign.Links (11.3.0.34 - 0) <3860C94E-B653-39D8-85A8-48DFE79CEF6E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
         0x1177ee000 -    0x117887ff0 +com.adobe.InDesign.Master Page (11.3.0.34 - 0) <4B3D94A1-EBC2-3A6C-B00A-6AC806D0EFFD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
         0x1178a1000 -    0x1178f1ff3 +com.adobe.InDesign.Media (11.3.0.34 - 0) <87915F97-68A5-31E1-B492-2B7E1888DA6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
         0x117907000 -    0x117986ff8 +com.adobe.InDesign.Metadata (11.3.0.34 - 0) <4BE38B43-076B-35F3-864D-9FCED19AC29F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
         0x1179a2000 -    0x1179b7ff4 +com.adobe.InDesign.Movie (11.3.0.34 - 0) <E3213D0E-B598-3E3F-AC4B-96A894052A21> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
         0x1179c6000 -    0x117a06ff9 +com.adobe.InDesign.Open Place (11.3.0.34 - 0) <10B74E1F-B94D-369D-AF29-E7248557089B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
         0x117a1a000 -    0x117abfffd +com.adobe.InDesign.Paragraph Composer (11.3.0.34 - 0) <236EB750-CEB2-3510-B716-CD2D844C8E34> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
         0x117acf000 -    0x117b0affc +com.adobe.InDesign.Path Type (11.3.0.34 - 0) <7B93E9B7-46B6-346A-AF64-25B21D7B1498> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
         0x117b23000 -    0x117d74ff1 +com.adobe.InDesign.PDF (11.3.0.34 - 0) <E5AE1FF1-F4F9-3F32-BDB3-43FA461397BB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
         0x117db9000 -    0x117e83ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.35138) <4205548A-573A-364B-93D0-F61996DD723A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
         0x117ea8000 -    0x117fb2fff +com.adobe.PDFPort (AdobePDFPort 2.1.0.35138 - 2.1.0.35138) <0FCFF22E-2FF3-3453-B7A0-2E37EB96D84E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
         0x117fc5000 -    0x117fedfff +com.adobe.PDFSettings (AdobePDFSettings 1.07.0 - 1.7) <78CCA159-119A-3A97-8CA3-E024044C0AB6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
         0x117ff6000 -    0x118033ff8 +com.adobe.InDesign.Photoshop Import Filter (11.3.0.34 - 0) <57E8936E-1556-3651-9A34-2914D3D2B6CB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
         0x118044000 -    0x11a525f1f +com.adobe.psl (AdobePSL 15.1.0.34656 - 15.1.0.34656) <FB80F116-67E6-3D56-AE40-52E0961F5578> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
         0x11a9be000 -    0x11a9c2fff  com.apple.agl (3.3.1 - AGL-3.3.1) <9F89C357-50A4-3978-93AB-D2E68CCFA834> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
         0x11a9ca000 -    0x11a9ccff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
         0x11abf2000 -    0x11ac2aff6 +com.adobe.InDesign.PNG Import Filter (11.3.0.34 - 0) <80145E29-14D4-31F7-9794-06C8442FB354> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
         0x11ac3a000 -    0x11adb0ff0 +com.adobe.InDesign.Print (11.3.0.34 - 0) <B783A4AC-B3D7-30A0-AF72-AEE23743D52B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
         0x11addd000 -    0x11ae02ffe +com.adobe.InDesign.Rulers (11.3.0.34 - 0) <DC93CE40-5611-35BC-A801-98D908B57674> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
         0x11ae14000 -    0x11aea8ff4 +com.adobe.InDesign.Scripting (11.3.0.34 - 0) <B4A75E08-D56A-3943-B3DE-119AF5462C77> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
         0x11aec9000 -    0x11aeebff8 +com.adobe.InDesign.Sections (11.3.0.34 - 0) <FE882339-773C-37DB-926C-C56F795CE6F6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
         0x11aefc000 -    0x11af78ff8 +com.adobe.InDesign.SharedContent (11.3.0.34 - 0) <72254E1C-2616-3F87-A05A-43551366CE3A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
         0x11af97000 -    0x11afa3ffc +com.adobe.InDesign.Sound (11.3.0.34 - 0) <13692150-15E0-3956-920C-67C03867A151> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
         0x11afaf000 -    0x11afbfff3 +com.adobe.InDesign.Spelling Service (11.3.0.34 - 0) <C1A7BBA0-F5A3-3878-A695-C6DDBC9D141F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
         0x11afcd000 -    0x11b011ff8 +com.adobe.InDesign.Spline UI (11.3.0.34 - 0) <8F260449-94CA-3FA3-B20D-6F975A2A5EB7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
         0x11b02c000 -    0x11b070ffe +com.adobe.InDesign.Spline (11.3.0.34 - 0) <47020364-AA03-34F8-BFF2-D1C1C8A3DADA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
         0x11b088000 -    0x11b0eaff5 +com.adobe.InDesign.Spread UI (11.3.0.34 - 0) <A49FD34A-4B28-3315-85B6-F24FB48FD3F6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
         0x11b10a000 -    0x11b239ff3 +com.adobe.InDesign.Spread (11.3.0.34 - 0) <C7AD37C8-CC1A-3B06-B6A8-F9551FC999AA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
         0x11b26a000 -    0x11b2baff2 +com.adobe.InDesign.Stroke and Fill (11.3.0.34 - 0) <8F97A589-160B-3B6C-BCC5-FC1FDB2030F2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
         0x11b2d1000 -    0x11b326ff8 +com.adobe.InDesign.Support for AppleScript (11.3.0.34 - 0) <E262A3CE-7591-3DD5-A000-D34F8CC9E87D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
         0x11b33c000 -    0x11b3d1ffe +com.adobe.InDesign.Support for JavaScript (11.3.0.34 - 0) <6A327852-C96C-3ECE-84BF-83CDE8B5A6B3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
         0x11b3fa000 -    0x11b478ff5 +com.adobe.InDesign.SVGExport (11.3.0.34 - 0) <23D4CB54-EBB1-3554-A112-BA3F5E13ACAB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
         0x11b491000 -    0x11b54ffff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
         0x11b572000 -    0x11b7a4ff5 +com.adobe.InDesign.Table Model (11.3.0.34 - 0) <7331B622-5FDB-334F-9C83-8CD349E3620A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
         0x11b7e7000 -    0x11b83fff0 +com.adobe.InDesign.TableStyles (11.3.0.34 - 0) <E069F3BB-73BB-35E7-B598-D9EF1A0BAF11> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
         0x11b851000 -    0x11b897ff0 +com.adobe.InDesign.Text Attributes (11.3.0.34 - 0) <AFAAB8AA-3049-3605-B205-BAA9194DBA30> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
         0x11b8b2000 -    0x11b8c6ff4 +com.adobe.InDesign.Text Editor Model (11.3.0.34 - 0) <633BFC42-0311-357F-9F13-3A217D26F566> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
         0x11b8d1000 -    0x11b9b3ffc +com.adobe.InDesign.Text Editor (11.3.0.34 - 0) <DEA93443-4E07-3768-8028-72418A1D165C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
         0x11b9e8000 -    0x11bb7bff0 +com.adobe.InDesign.Text Walker (11.3.0.34 - 0) <5BE6A498-6ECF-3C06-850D-2205488F3F17> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
         0x11bbcf000 -    0x11bbeeff3 +com.adobe.InDesign.Text Wrap Path (11.3.0.34 - 0) <DC3AC8B9-47A0-3F72-8E2D-879FC276AEED> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
         0x11bbf7000 -    0x11bc61ffa +com.adobe.InDesign.Text Wrap (11.3.0.34 - 0) <85FB106E-664F-388D-9A6C-7488BB268DBA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
         0x11bc7a000 -    0x11c240ff7 +com.adobe.InDesign.Text (11.3.0.34 - 0) <D1C34E28-9F79-3058-9BB9-B697599AD1CD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
         0x11c2e2000 -    0x11c33fffa +com.adobe.InDesign.TOC (11.3.0.34 - 0) <8B7C1F79-ECD4-38F1-BCF3-B414693F0BC3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
         0x11c353000 -    0x11c481ff2 +com.adobe.InDesign.Transparency (11.3.0.34 - 0) <F38F342E-34F2-3122-821B-14DBE82AFBA5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
         0x11c4ac000 -    0x11c4cdff4 +com.adobe.InDesign.Utilities (11.3.0.34 - 0) <3854C290-7737-34F4-9BF3-2498E99449F1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
         0x11c4e7000 -    0x11c5d2ff4 +com.adobe.InDesign.Widgets (11.3.0.34 - 0) <0393D28C-0A02-3894-BFB5-3E450C80D3D3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
         0x11c64a000 -    0x11c652ff0 +com.adobe.InDesign.Workgroup Client UI (11.3.0.34 - 0) <E077C6D1-72CD-3E59-BBC9-D22B2A06E881> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
         0x11c658000 -    0x11c676fff +com.adobe.InDesign.Workgroup Client (11.3.0.34 - 0) <353CD815-4ED8-3993-B24D-4B5621689739> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
         0x11c684000 -    0x11c6baff8 +com.adobe.InDesign.Workgroup (11.3.0.34 - 0) <76FB216F-F98A-3284-A5BB-FF8C74C08349> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
         0x11c6c9000 -    0x11c6f0ffe +com.adobe.InDesign.WorldReady (11.3.0.34 - 0) <EEC95266-BE2B-3F83-8AB3-695206401979> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
         0x11c700000 -    0x11c908ffd +com.adobe.InDesign.XML (11.3.0.34 - 0) <C22AD4EC-4BCF-387A-97D1-F2A03D4A174C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
         0x11c951000 -    0x11ca43fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.35348 - 3.8.0.35348) <E5D037D0-B4D5-33F5-BE74-650C392C6514> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
         0x11ca58000 -    0x11cab1ffa +com.adobe.InDesign.XMLParser (11.3.0.34 - 0) <320E2802-D3F6-3DD9-AC02-D0081F9EB966> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
         0x11cac6000 -    0x11cb97fff +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.35348 - 3.8.0.35348) <ACAFD120-EBE3-314B-AEA6-3B213916F1E0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
         0x11d729000 -    0x11d729fff +DTraceSupport.dylib (1) <E54DF20B-C169-68CF-A3F5-0470DEFF1C8A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DTraceSupport.dylib
         0x11d92a000 -    0x11d953fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
         0x11d984000 -    0x11d98bfff  com.apple.URLMount.AFPPlugin (6.0 - 6.0) <8CE70180-6B49-36F9-81B7-9C0922F606D5> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
         0x11eb47000 -    0x11f36efff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.35138) <4BE53AB4-D541-37E6-9A79-2321A1F5E0C7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
         0x11f90d000 -    0x11f910ff3 +FastCore (16.0.0 - 16.0.0) <F2C2654A-7864-39D2-B4F5-B72EEC5AB62D> /Applications/Adobe InDesign CC 2015/*/FastCore.plugin/Contents/MacOS/FastCore
         0x11ff67000 -    0x11ff8dff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adbeapecore.framework/adbeapecore
         0x11ffa0000 -    0x1200ddfef +IMSLib.dylib (9.0.1.32 - 9.0.1.32) <59A9ECF1-504C-3472-B60C-7642DA33DF8E> /Library/Application Support/Adobe/*/IMSLib.dylib
         0x1200fd000 -    0x120177ff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
         0x121469000 -    0x12150efff  ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
         0x121c17000 -    0x121c4afff +com.adobe.Reader for DOCX (Reader for DOCX 5.65.0.35249 - 5.65.0.35249) <A5FCF2EA-E0B3-3F1C-A176-D48B32084CB6> /Applications/Adobe InDesign CC 2015/*/Reader for DOCX
         0x121c56000 -    0x121ceffff +com.adobe.AdobeSangamML (AdobeSangamML 5.65.0.35249 - 5.65.0.35249) <3C01E7B8-1295-3DA8-B6FC-D1EE8107A9F7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
         0x121d13000 -    0x121d73ff7 +com.adobe.Reader for Excel (Reader for Excel 5.65.0.35249 - 5.65.0.35249) <C985EB47-37AC-3014-BE7D-56B547646B50> /Applications/Adobe InDesign CC 2015/*/Reader for Excel
         0x121d86000 -    0x121d9aff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.35133 - 1.1.0.35133) <B133FABB-7D71-315A-9C49-10D8C4D810EB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
         0x121da2000 -    0x121e97ff7 +com.adobe.Reader for Quark (Reader for Quark 5.65.0.35249 - 5.65.0.35249) <9F38B99A-907D-3C49-BF14-D4C862964D08> /Applications/Adobe InDesign CC 2015/*/Reader for Quark
         0x121eb0000 -    0x121f0eff7 +com.adobe.Reader for RTF (Reader for RTF 5.65.0.35249 - 5.65.0.35249) <94907FE3-A680-31E0-94C9-BF04DE670BB8> /Applications/Adobe InDesign CC 2015/*/Reader for RTF
         0x121f27000 -    0x121f97ff7 +com.adobe.Reader for Word (Reader for Word 5.65.0.35249 - 5.65.0.35249) <29E0A43F-FFA4-367A-ACCD-C64349573471> /Applications/Adobe InDesign CC 2015/*/Reader for Word
         0x121fac000 -    0x12202cff7 +com.adobe.Reader for XLSX (Reader for XLSX 5.65.0.35249 - 5.65.0.35249) <26BC5DB2-3811-33B5-86B7-0FF5BF8A2DA5> /Applications/Adobe InDesign CC 2015/*/Reader for XLSX
         0x122046000 -    0x12204ffff +com.adobe.ZTextReader (ZTextReader 5.65.0.35249 - 5.65.0.35249) <1A092CA4-B8C9-38A1-8E43-09CBB89B8FF8> /Applications/Adobe InDesign CC 2015/*/ZTextReader
         0x123cb1000 -    0x123d39fff  com.apple.applescript (2.5 - 377) <B280DAC6-E614-3AC0-81B5-C2F1E994514B> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
         0x123fb9000 -    0x123fd5ff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
         0x123fdb000 -    0x123ffdff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
         0x1241a3000 -    0x1241b2ff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
         0x1241b7000 -    0x1241c9fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
         0x1241ce000 -    0x1241fbff3 +MMXCore (16.0.0 - 16.0.0) <993AF7A0-E5B5-3B32-BB70-2D4EB336A61C> /Applications/Adobe InDesign CC 2015/*/MMXCore.plugin/Contents/MacOS/MMXCore
         0x1242cf000 -    0x124826ff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.14.58 - 10.1.4) <603F465A-DB27-3BDC-A702-9107EA5CF3A4> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD5000GraphicsGLDriver
         0x126e83000 -    0x126efaff9 +MultiProcessor Support (16.0.0 - 16.0.0) <8C511939-EF04-383C-BEDC-1502FE2960F6> /Applications/Adobe InDesign CC 2015/*/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
         0x133f08000 -    0x133f48fff  com.apple.AppleShareClientCore (4.0 - 3.0) <AF0480F0-9E73-3BDB-AE92-34C1D5513729> /System/Library/PrivateFrameworks/AppleShareClientCore.framework/Versions/A/AppleShareCli entCore
         0x134211000 -    0x13424bfff +com.adobe.pip (7.3.1.72) <A00A5967-3014-35EA-B24D-C24581F180C8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
         0x134983000 -    0x1349e9ff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.14.58 - 10.1.4) <A2BFF9AB-2561-3384-986E-8E3767FE3F68> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleI ntelHD5000GraphicsMTLDriver
         0x135bd9000 -    0x135cccfff  com.apple.GeForceMTLDriver (10.10.5.2 - 10.1.0) <94A8BE1E-C807-3E93-92C5-7D3A7FF5CEA4> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
         0x135d2f000 -    0x135f6cff7 +com.adobe.adobehunspellplugin2 (1.0) <D6BFD06F-53C4-38F9-B4FE-413C9D5777C7> /Applications/Adobe InDesign CC 2015/*/AdobeHunspellPlugin.bundle/Contents/MacOS/AdobeHunspellPlugin
         0x138577000 -    0x138592fff  com.apple.security.csparser (3.0 - 57337.40.85) <ACA30E1D-B53E-3A56-9E5D-E5C419102CA9> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
      0x7fff6e277000 - 0x7fff6e2ae0d7  dyld (360.21) <D9B236BC-4AC1-325F-B3EF-3F06DBDA7119> /usr/lib/dyld
      0x7fff8818b000 - 0x7fff882d5ff7  com.apple.coreui (2.1 - 366.1) <A3868F31-ACF4-3EA5-9E75-79ED44FA7F06> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x7fff882fc000 - 0x7fff88306fff  com.apple.KerberosHelper (4.0 - 1.0) <67D88B2C-A54B-34FF-ABF3-2D3736879730> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
      0x7fff88309000 - 0x7fff88436ff3  com.apple.CoreText (352.0 - 494.11) <08E8640E-6602-3A00-BC28-94235FD311B4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
      0x7fff88437000 - 0x7fff88644fff  libicucore.A.dylib (551.51) <35315A29-E21C-3CC5-8BD6-E07A3AE8FC0D> /usr/lib/libicucore.A.dylib
      0x7fff88f7a000 - 0x7fff88fccfff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <FC1AED2C-B3E2-31D9-B163-37989CD8A073> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x7fff88fcd000 - 0x7fff88fd1fff  libGIF.dylib (1444) <D3F44A33-355E-3154-A465-1C732AAC5F75> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
      0x7fff890e1000 - 0x7fff894b9fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
      0x7fff89527000 - 0x7fff8953ffef  libcompression.dylib (28) <E7601B62-1053-369D-8A9E-91CF86239220> /usr/lib/libcompression.dylib
      0x7fff89589000 - 0x7fff89662fff  com.apple.CoreMedia (1.0 - 1731.15.202) <D2A49E52-9D26-35A8-BDDC-3BCDBEC5A19E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x7fff89663000 - 0x7fff89674ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
      0x7fff89675000 - 0x7fff896c1fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x7fff897f4000 - 0x7fff899c2ff3  com.apple.QuartzCore (1.11 - 410.14) <0283748A-8318-36AC-8B30-8A951FEB305A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x7fff899c3000 - 0x7fff899c5fff  libCVMSPluginSupport.dylib (12.0.40.6) <4AA6710A-6267-3062-BFF2-27DB5E6B5892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
      0x7fff899cc000 - 0x7fff899e1fff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
      0x7fff899e2000 - 0x7fff89a11ffb  com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
      0x7fff89a12000 - 0x7fff89a53ff7  libGLU.dylib (12.0.40.6) <C56DDF90-CF6D-30D2-A3E6-89288BE69DCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x7fff89a54000 - 0x7fff89a83ffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
      0x7fff89a84000 - 0x7fff89a8dff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
      0x7fff89aab000 - 0x7fff89cf7ff7  com.apple.AddressBook.framework (9.0 - 1679.9) <8879002B-C87B-3595-9CD2-B672F10DD156> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
      0x7fff89cf8000 - 0x7fff89d12ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
      0x7fff89d7d000 - 0x7fff89d7dfff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
      0x7fff89e12000 - 0x7fff89e6efff  com.apple.Suggestions (5.0 - 180) <450BCB58-786F-37DC-9AC7-2E3D13198032> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
      0x7fff89e78000 - 0x7fff89e81fff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
      0x7fff89e82000 - 0x7fff8a1c2fff  com.apple.WebKit (11601 - 11601.5.17.1) <6FA46AD7-3DF1-3654-A642-D9C5BE613ED7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x7fff8a1c7000 - 0x7fff8a1c7fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <185EC96A-5AF0-3620-A4ED-4D3654D25B39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x7fff8a1c8000 - 0x7fff8a1f3ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
      0x7fff8a1fc000 - 0x7fff8a3a2ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <082319FC-59F2-3D36-AC9B-94759724E302> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x7fff8a3a3000 - 0x7fff8a3a6ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
      0x7fff8a3a7000 - 0x7fff8a44bfff  com.apple.Bluetooth (4.4.4 - 4.4.4f4) <BCF89EFE-853D-3AEA-AE31-DC8293C7284F> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
      0x7fff8a4e8000 - 0x7fff8a507ff7  com.apple.framework.Apple80211 (11.0 - 1121.34) <AE7795B8-4590-3714-999D-3FBFF6BF5D93> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
      0x7fff8a559000 - 0x7fff8a575ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
      0x7fff8a5bb000 - 0x7fff8a5d2ff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
      0x7fff8a5d3000 - 0x7fff8ae63ff7  libclh.dylib (4.0.3 - 4.0.3) <1E01D7A3-33E4-3A79-9C89-24254CE48D4A> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
      0x7fff8ae64000 - 0x7fff8b1f9fdb  com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x7fff8b25c000 - 0x7fff8b288fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <1318B6A5-FFC3-3615-914D-95CBFE5BA727> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
      0x7fff8b2bc000 - 0x7fff8b2c4fff  libGFXShared.dylib (12.0.40.6) <1CDE5AEF-3E44-3547-879E-BB490EE7702C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x7fff8b2c5000 - 0x7fff8b3e9fff  libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib
      0x7fff8b3ea000 - 0x7fff8b3f2ffb  libsystem_dnssd.dylib (625.40.20) <86A05653-DCA0-3345-B29F-F320029AA05E> /usr/lib/system/libsystem_dnssd.dylib
      0x7fff8b45b000 - 0x7fff8b4c6ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
      0x7fff8b4c7000 - 0x7fff8b504ff3  com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
      0x7fff8b5c9000 - 0x7fff8b725ff3  com.apple.WebKitLegacy (11601 - 11601.5.17.1) <BEF2ACE7-5D6F-32A2-93BA-BF78D126465F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
      0x7fff8b726000 - 0x7fff8b74ffff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
      0x7fff8b750000 - 0x7fff8b779ffb  libRIP.A.dylib (957) <5F18F20D-5921-3314-A9F8-F1B1CB62C83D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
      0x7fff8b7ac000 - 0x7fff8ba42fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
      0x7fff8ba43000 - 0x7fff8ba49fff  com.apple.IOAccelerator (205.3 - 205.3) <851B6BF8-5B7F-3FB5-9E45-10AAE3BF7438> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
      0x7fff8ba6d000 - 0x7fff8ba80fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
      0x7fff8be65000 - 0x7fff8be70fff  libcsfde.dylib (517.20.1) <6FFC376E-E141-37EE-800A-004080A50091> /usr/lib/libcsfde.dylib
      0x7fff8bed9000 - 0x7fff8bf28ff7  com.apple.opencl (2.7.0 - 2.7.0) <307263BA-0368-38C9-A7FB-25920343D0DF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x7fff8bf29000 - 0x7fff8bf34fff  libkxld.dylib (3248.40.184) <6F776D34-D06C-3C48-B753-D0FB375A4A8A> /usr/lib/system/libkxld.dylib
      0x7fff8bfaa000 - 0x7fff8bfb8fff  com.apple.opengl (12.0.40 - 12.0.40) <AEA28993-BA3E-3E0F-A2F5-88C312ABB634> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x7fff8bfb9000 - 0x7fff8bfbdfff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
      0x7fff8bfbe000 - 0x7fff8c2b3fff  com.apple.HIToolbox (2.1.1 - 807.2) <871E5223-5D03-3649-98AF-9CCA3B41E307> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x7fff8c2bc000 - 0x7fff8c2c1fff  com.apple.TCC (1.0 - 1) <50F7EC60-5B21-3B9B-BF2F-F037EA7B12FB> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
      0x7fff8c2c2000 - 0x7fff8c2cdff7  libcommonCrypto.dylib (60075.40.2) <B9D08EB8-FB35-3F7B-8A1C-6FCE3F07B7E7> /usr/lib/system/libcommonCrypto.dylib
      0x7fff8c2ce000 - 0x7fff8c2ddfe7  com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
      0x7fff8c2f8000 - 0x7fff8c30cfff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <D0A5B9A7-A247-37CD-A8F7-64DC635F9C9B> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
      0x7fff8c3cc000 - 0x7fff8c5edff7  com.apple.CoreImage (11.4.0 - 366.4.19) <6EE4A686-50C8-3D77-A036-BE8AA0F8A2FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
      0x7fff8c73c000 - 0x7fff8c8e7ffb  GLEngine (12.0.40.6) <32029589-A64E-3E6B-A024-F985765766A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
      0x7fff8c8ee000 - 0x7fff8c90fff7  libssl.0.9.7.dylib (106) <CAE4A69E-BB9F-3735-9E86-175D471555EA> /usr/lib/libssl.0.9.7.dylib
      0x7fff8cbab000 - 0x7fff8cbc4fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x7fff8cbc5000 - 0x7fff8cbdcfff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
      0x7fff8cbdd000 - 0x7fff8cbf7fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x7fff8cbf8000 - 0x7fff8cbffff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
      0x7fff8cc00000 - 0x7fff8cc01fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
      0x7fff8cc09000 - 0x7fff8cc96dd7  com.apple.AppleJPEG (1.0 - 1) <558ACADA-C41F-3EEF-82A0-C2D7B13C5428> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
      0x7fff8cc97000 - 0x7fff8cc9afff  com.apple.IOSurface (108.2.1 - 108.2.1) <A0037B0A-277A-393E-9BF6-688595BD564D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x7fff8cc9f000 - 0x7fff8ccc1fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
      0x7fff8cd05000 - 0x7fff8cd92fff  libsystem_c.dylib (1082.20.4) <CDEBF2BB-A578-30F5-846F-96274951C3C5> /usr/lib/system/libsystem_c.dylib
      0x7fff8cd93000 - 0x7fff8cdf1fff  com.apple.SystemConfiguration (1.14 - 1.14) <10082F58-6190-3A7C-8B6C-C12B16DC793A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x7fff8ce44000 - 0x7fff8ce5afff  com.apple.CoreMediaAuthoring (2.2 - 953) <06C2E0E2-BA5C-3BB1-8DD7-55613EDD654D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
      0x7fff8ce5b000 - 0x7fff8ce63fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
      0x7fff8ce67000 - 0x7fff8ce94fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
      0x7fff8ce95000 - 0x7fff8cedbff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
      0x7fff8cf34000 - 0x7fff8cf65fff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
      0x7fff8cf66000 - 0x7fff8d2d9fff  com.apple.FinderKit (1.4.4 - 1.4.4) <76E52C7F-CA82-337E-BF8E-9961F11C4B8D> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
      0x7fff8d2da000 - 0x7fff8d56aff7  com.apple.RawCamera.bundle (6.19 - 844) <96617D7F-437C-31AB-B413-ADC079469054> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x7fff8d56b000 - 0x7fff8d805fff  com.apple.security (7.0 - 57337.40.85) <7C5B8DEF-3D02-3410-9BD3-2B1251F84D4B> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x7fff8d813000 - 0x7fff8d844ff7  libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
      0x7fff8d845000 - 0x7fff8d878ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
      0x7fff8d879000 - 0x7fff8d8dfff7  libsystem_network.dylib (583.40.20) <269E5ADD-6922-31E2-8D55-7B777263AC0D> /usr/lib/system/libsystem_network.dylib
      0x7fff8d8e0000 - 0x7fff8dc5bffb  com.apple.VideoToolbox (1.0 - 1731.15.202) <B839BE14-9503-3B5E-A54A-C7FCEED34EA3> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x7fff8dc60000 - 0x7fff8dc7dff7  com.apple.pluginkit.framework (1.0 - 1) <0BA96479-0451-3DA9-A2AC-FE1D86D383AB> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
      0x7fff8dc7e000 - 0x7fff8dccaffb  com.apple.HIServices (1.22 - 549) <E4E1BD10-F475-3E19-9E0B-A5071D158F47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x7fff8dcf7000 - 0x7fff8de83ff7  libGLProgrammability.dylib (12.0.40.6) <F5AE40EB-A28B-3F3B-8E4C-0C0D73E47EDB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x7fff8de84000 - 0x7fff8de87ffb  libdyld.dylib (360.21) <8390E026-F7DE-3C32-9486-3DFF6BD131B0> /usr/lib/system/libdyld.dylib
      0x7fff8de97000 - 0x7fff8de97fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <93C1D642-37D4-3692-AD35-DCAD04F9610B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x7fff8df72000 - 0x7fff8df76fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
      0x7fff8e1f5000 - 0x7fff8e47cff7  com.apple.CFNetwork (760.4.2 - 760.4.2) <24C4A390-3079-358A-8D51-75A3E818A6DF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
      0x7fff8e47d000 - 0x7fff8e512fff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x7fff8e5d5000 - 0x7fff8ea4bfff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x7fff8ea51000 - 0x7fff8ea53fff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
      0x7fff8eb55000 - 0x7fff8eb56ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
      0x7fff8eb57000 - 0x7fff8eb62fff  libGPUSupportMercury.dylib (12.0.40.6) <CC8F3ED8-72FE-3041-A0F2-D8F17DBE2347> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
      0x7fff8eb63000 - 0x7fff8ebb5fff  com.apple.CloudDocs (1.0 - 383.12) <1388C0E5-9B2F-372B-A005-043EB049AAA3> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
      0x7fff8ebb6000 - 0x7fff8ecb2ff7  libFontParser.dylib (158.5) <62796E99-36B7-36B6-8D33-5349F88014C3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x7fff8f677000 - 0x7fff8f679fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
      0x7fff8f67a000 - 0x7fff8f7bffff  com.apple.QTKit (7.7.3 - 2943.3) <88AA19A7-7170-3798-8CBA-B1B8D4763ADB> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x7fff8f924000 - 0x7fff8f9d4fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
      0x7fff8fa44000 - 0x7fff8fa6dff7  libxslt.1.dylib (14.1) <27DE3F2E-CE96-3327-A563-788EE3E2775B> /usr/lib/libxslt.1.dylib
      0x7fff8fa6f000 - 0x7fff8fa75ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x7fff8fa90000 - 0x7fff8fa9bfff  libGL.dylib (12.0.40.6) <4FC6D3F9-6582-3E7D-A7D1-E035F0E26697> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x7fff8fa9c000 - 0x7fff8faa7fff  com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x7fff8faea000 - 0x7fff8faf2fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
      0x7fff8faf3000 - 0x7fff8fbdeff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x7fff8fc34000 - 0x7fff8fc38fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
      0x7fff8fd50000 - 0x7fff8fd52ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
      0x7fff8fd86000 - 0x7fff8fd88fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7659CACF-3B08-3AF3-8FAC-24FAF18EF114> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
      0x7fff8fd8e000 - 0x7fff8fd9cff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
      0x7fff8fdad000 - 0x7fff90092ffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x7fff9032f000 - 0x7fff90345ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
      0x7fff903aa000 - 0x7fff9049afff  libJP2.dylib (1444) <27371567-A122-3217-ADA0-3A446EF6A3E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
      0x7fff9049b000 - 0x7fff904c0ff7  libPng.dylib (1444) <47ACF98D-B5F1-3A03-B6FD-4107D5FAE5E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
      0x7fff904c6000 - 0x7fff904cbfff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x7fff904d7000 - 0x7fff904dcfff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x7fff904dd000 - 0x7fff906e8fff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
      0x7fff90779000 - 0x7fff9077bffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
      0x7fff9097d000 - 0x7fff909cffff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x7fff909d0000 - 0x7fff90a1bff7  com.apple.CoreMediaIO (703.0 - 4791) <B974A225-61C6-34DD-AC2A-495BD6A393B3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
      0x7fff90a33000 - 0x7fff90a62fff  com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
      0x7fff90ad5000 - 0x7fff90ae9fe3  libCGInterfaces.dylib (317.9) <5079DE4F-3717-32FF-B76A-77F53236D17D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
      0x7fff90b35000 - 0x7fff90b3aff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
      0x7fff90b3b000 - 0x7fff90b40ff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
      0x7fff90b41000 - 0x7fff90b9efff  com.apple.CoreServices.OSServices (728.8 - 728.8) <4CE49D8A-8304-3347-9379-6075CB906419> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x7fff90b9f000 - 0x7fff90ba0fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x7fff90c0c000 - 0x7fff90c2aff7  libsystem_kernel.dylib (3248.40.184) <88C17B7F-1CD8-3979-A1A9-F7BDB4FCE789> /usr/lib/system/libsystem_kernel.dylib
      0x7fff90c2b000 - 0x7fff90ce4ff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
      0x7fff90ce5000 - 0x7fff90cf5fff  com.apple.AppleScriptObjC (1.4 - 32) <0C137AF5-9086-3205-9895-F3B8DF3B47FF> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
      0x7fff90cfb000 - 0x7fff91196ff3  com.apple.GeoServices (1.0 - 1151.47.0.1) <928294E7-6897-3D5B-9D2E-BC092B6C25DE> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
      0x7fff91197000 - 0x7fff911befff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
      0x7fff91371000 - 0x7fff913faff7  com.apple.PerformanceAnalysis (1.0 - 1) <608E8C50-6F59-3FEB-B822-D9B02F328716> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
      0x7fff91526000 - 0x7fff91541ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
      0x7fff91542000 - 0x7fff91566fff  libJPEG.dylib (1444) <AECB826C-8B14-3D04-8DEC-33EE85F5150D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
      0x7fff91567000 - 0x7fff915c7fff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x7fff915c8000 - 0x7fff91682fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
      0x7fff91822000 - 0x7fff91825ffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
      0x7fff9185e000 - 0x7fff91866fff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
      0x7fff91867000 - 0x7fff918d5ff7  com.apple.ApplicationServices.ATS (377 - 394.3) <847DBFBA-8D6B-367B-99FD-C6CAA8C05C65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x7fff9194c000 - 0x7fff91986ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
      0x7fff919a0000 - 0x7fff91a80ff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
      0x7fff91a81000 - 0x7fff91a8aff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
      0x7fff91ab4000 - 0x7fff91b04ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
      0x7fff91cae000 - 0x7fff91cffff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <3D62A9B3-67A8-3F8A-A102-05E310249075> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x7fff91d29000 - 0x7fff91d37fff  com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
      0x7fff91d38000 - 0x7fff92e26ff7  com.apple.WebCore (11601 - 11601.5.17) <01B1DEA6-A07A-367B-84C0-E264EEFBBA1F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
      0x7fff92e27000 - 0x7fff92e5bff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x7fff92e6b000 - 0x7fff92e92fff  com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x7fff92e93000 - 0x7fff92e94fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
      0x7fff92ec3000 - 0x7fff92ec8ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
      0x7fff92ec9000 - 0x7fff92ec9fff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x7fff92ed2000 - 0x7fff92f20ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
      0x7fff92f21000 - 0x7fff92f22fff  libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
      0x7fff92f3d000 - 0x7fff92f49fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
      0x7fff92f4a000 - 0x7fff931f0ff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x7fff931f1000 - 0x7fff931faff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x7fff9320a000 - 0x7fff93388fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
      0x7fff93389000 - 0x7fff93389fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x7fff93f4e000 - 0x7fff93f90ff7  com.apple.Metal (56.6 - 56.6) <7DCBE573-B713-3C50-A16E-2F33A84C3CFB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
      0x7fff93fd8000 - 0x7fff93feafff  libsasl2.2.dylib (209) <2F81C8C9-11A3-3581-B2C1-D8C03AB7D39C> /usr/lib/libsasl2.2.dylib
      0x7fff940a7000 - 0x7fff94157fe7  libvMisc.dylib (563.5) <6D73C20D-D1C4-3BA5-809B-4B597C15AA86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x7fff94158000 - 0x7fff9415efff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
      0x7fff9415f000 - 0x7fff946b7ff7  com.apple.MediaToolbox (1.0 - 1731.15.202) <A19F9D25-5333-3AA0-90FB-97F3F420A7EA> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x7fff946b8000 - 0x7fff94ae6fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
      0x7fff94b67000 - 0x7fff94b67ff7  liblaunch.dylib (765.40.36) <1CD7619D-AF2E-34D1-8EC6-8021CF473D9B> /usr/lib/system/liblaunch.dylib
      0x7fff94b68000 - 0x7fff94b76fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
      0x7fff94b77000 - 0x7fff94bebff3  com.apple.securityfoundation (6.0 - 55126) <1F6BDF18-3CF0-3E85-8D9B-0663599B9949> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x7fff94bec000 - 0x7fff94bf1fff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
      0x7fff94d88000 - 0x7fff94d94fff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x7fff94d95000 - 0x7fff94daefff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x7fff94daf000 - 0x7fff94db1fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
      0x7fff95521000 - 0x7fff95521fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x7fff95522000 - 0x7fff9552dfff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
      0x7fff95537000 - 0x7fff9555bfff  com.apple.MultitouchSupport.framework (304.10.2 - 304.10.2) <CE75EDA3-2B22-3968-834E-550EA870ECC8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x7fff95576000 - 0x7fff955a4ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
      0x7fff95602000 - 0x7fff9560afff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
      0x7fff9560b000 - 0x7fff9560efff  libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
      0x7fff9560f000 - 0x7fff9569efff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x7fff9569f000 - 0x7fff956a2fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x7fff956a3000 - 0x7fff956abfef  libcldcpuengine.dylib (2.7.3) <B385841A-B573-3A91-9BEB-CC89CB2716B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
      0x7fff95729000 - 0x7fff95759ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
      0x7fff9575a000 - 0x7fff957fafff  com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
      0x7fff95814000 - 0x7fff958eaffb  com.apple.DiskImagesFramework (10.11.3 - 417.2) <7412BC0B-A895-350D-B829-1E3A6FF5EC3F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
      0x7fff95905000 - 0x7fff95906ff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x7fff95907000 - 0x7fff9590bfff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x7fff9590c000 - 0x7fff959a2fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x7fff95c13000 - 0x7fff95c7afff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
      0x7fff95c7b000 - 0x7fff95c97fff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
      0x7fff95c98000 - 0x7fff95cbcfff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x7fff95cbd000 - 0x7fff95da3ff7  libcrypto.0.9.8.dylib (59.40.2) <2486D801-C756-3488-B519-1AA6807E8948> /usr/lib/libcrypto.0.9.8.dylib
      0x7fff963ab000 - 0x7fff963adfff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
      0x7fff963ae000 - 0x7fff963bfff7  libsystem_trace.dylib (201.10.3) <25104542-5251-3E8D-B14A-9E37207218BC> /usr/lib/system/libsystem_trace.dylib
      0x7fff963d8000 - 0x7fff96495ff7  libcrypto.0.9.7.dylib (106) <86B6A5E2-7EB2-3E96-9233-68BD4E219140> /usr/lib/libcrypto.0.9.7.dylib
      0x7fff96496000 - 0x7fff964bffff  libsystem_info.dylib (477.40.5) <6B01C09E-A3E5-3C71-B370-D0CABD11A436> /usr/lib/system/libsystem_info.dylib
      0x7fff964c0000 - 0x7fff964c0fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
      0x7fff96534000 - 0x7fff96566ff7  libTrueTypeScaler.dylib (158.5) <EA63B45B-22D3-3546-9BD6-EEEB7F1B48B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x7fff9656a000 - 0x7fff96678ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x7fff96679000 - 0x7fff966b0ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x7fff966b7000 - 0x7fff966bffff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x7fff966c0000 - 0x7fff96f1efff  com.apple.GeForceGLDriver (10.10.5.2 - 10.1.0) <0206BA56-8CA6-33DD-B67D-48E5B0AD1CD5> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
      0x7fff96f53000 - 0x7fff96f64fff  libSparseBLAS.dylib (1162.2) <EBEB3848-3468-342A-91A6-5C47F2369CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
      0x7fff96f65000 - 0x7fff96f82ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <F4AF2363-B28E-3097-AB1E-FDA1C92F8F56> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
      0x7fff96fa0000 - 0x7fff9704bfff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x7fff97144000 - 0x7fff97152fff  com.apple.IntlPreferences (2.0 - 192) <61F62126-0902-3324-BB1D-8B93297ED899> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
      0x7fff9717f000 - 0x7fff97181ff7  libRadiance.dylib (1444) <A5EFA292-AFD4-3FCE-8802-958AD60F75DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
      0x7fff97182000 - 0x7fff97197fff  com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
      0x7fff97237000 - 0x7fff973e3fff  com.apple.avfoundation (2.0 - 1046.9.11) <DE524245-B7EF-3E9D-8AA1-3D99A3304EF4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
      0x7fff973e4000 - 0x7fff97468ffb  com.apple.AVKit (1.1 - 285.10) <4C174B0F-43FF-3F41-8687-EA9C71EF1C18> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
      0x7fff97469000 - 0x7fff97484fff  com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
      0x7fff97485000 - 0x7fff97485ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
      0x7fff97486000 - 0x7fff9764cfe7  com.apple.ImageIO.framework (3.3.0 - 1444) <54F18254-F31B-3464-BB51-BAF9E9620419> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
      0x7fff9776f000 - 0x7fff977f7fff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
      0x7fff97849000 - 0x7fff97872ff7  libxpc.dylib (765.40.36) <2CC7CF36-66D4-301B-A6D8-EBAE7405B008> /usr/lib/system/libxpc.dylib
      0x7fff97873000 - 0x7fff97882ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x7fff97883000 - 0x7fff97af0fff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x7fff97af4000 - 0x7fff97b1fff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
      0x7fff97b26000 - 0x7fff97b30fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
      0x7fff97b31000 - 0x7fff97b7ffff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
      0x7fff97b80000 - 0x7fff97b97ff7  libsystem_asl.dylib (323.40.3) <007F9094-317A-33EA-AF62-BAEAAB48C0F7> /usr/lib/system/libsystem_asl.dylib
      0x7fff97b9b000 - 0x7fff97ba3fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
      0x7fff97ba4000 - 0x7fff97ba5fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
      0x7fff97ba9000 - 0x7fff97bb5fff  com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x7fff97bbc000 - 0x7fff97bcdfff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
      0x7fff97bce000 - 0x7fff97d35fff  libBLAS.dylib (1162.2) <A1398FE0-39D2-33EA-9A0F-B2644EEA29A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x7fff97dae000 - 0x7fff97dd0ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
      0x7fff97dd1000 - 0x7fff97e26fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x7fff97e84000 - 0x7fff981d8fff  com.apple.Foundation (6.9 - 1258) <51833143-6CAE-3E1C-9FBA-BCDEB48D4ADF> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x7fff981d9000 - 0x7fff9821eff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
      0x7fff9829e000 - 0x7fff982f1ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
      0x7fff982f2000 - 0x7fff98381ff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
      0x7fff983b1000 - 0x7fff983b3ff7  com.apple.SafariServices.framework (11601 - 11601.5.17.1) <396E2233-E2DC-391C-84D2-991F636A941B> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
      0x7fff983b4000 - 0x7fff983d0ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
      0x7fff983d1000 - 0x7fff983dcfff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
      0x7fff9847d000 - 0x7fff98879fff  libLAPACK.dylib (1162.2) <987E42B0-5108-3065-87F0-9DF7616A8A06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x7fff9887a000 - 0x7fff988effff  com.apple.framework.IOKit (2.0.2 - 1179.40.20) <FB2AD43B-905D-3BD0-BE17-ACE7D4D13E24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x7fff988f9000 - 0x7fff98901fef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
      0x7fff98902000 - 0x7fff98c64f3f  libobjc.A.dylib (680) <7489D2D6-1EFD-3414-B18D-2AECCCC90286> /usr/lib/libobjc.A.dylib
      0x7fff98c9e000 - 0x7fff98cd6ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
      0x7fff98d05000 - 0x7fff98dbdff7  com.apple.CoreDuet (1.0 - 1) <058EAEDE-156F-309C-AB61-34C61B93D967> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
      0x7fff98dbe000 - 0x7fff98dbefff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <054DFE32-737D-3211-9A14-0FC5E1A880E3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x7fff98dbf000 - 0x7fff98e5ffff  com.apple.Metadata (10.7.0 - 972.29.1) <F19E0200-6937-3799-9C67-D26C2CE5AA5F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x7fff98e61000 - 0x7fff98e63fff  com.apple.xpc.ServiceManagement (1.0 - 1) <F3E14561-5DF4-3429-98ED-8F27A87A343A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
      0x7fff98e64000 - 0x7fff98e8dfff  com.apple.ProtectedCloudStorage (1.0 - 1) <4850F751-E61B-30C0-B89A-B313601D3DB5> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
      0x7fff98eac000 - 0x7fff98eeaff7  libGLImage.dylib (12.0.40.6) <734B133F-E789-3A25-9DE6-1CCBA4896D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x7fff98eeb000 - 0x7fff98f19ff7  libsandbox.1.dylib (460.40.33) <26158471-870A-3269-9E2B-7D7963B8E9F3> /usr/lib/libsandbox.1.dylib
      0x7fff98f1a000 - 0x7fff98f8eff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
      0x7fff98f8f000 - 0x7fff98f92fff  libsystem_sandbox.dylib (460.40.33) <30671DCC-265F-325A-B33D-11CD336B3DA3> /usr/lib/system/libsystem_sandbox.dylib
      0x7fff9934c000 - 0x7fff993bbfff  com.apple.datadetectorscore (7.0 - 460) <8EF4EECC-4FF1-36DF-84CF-65545555A225> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x7fff993f0000 - 0x7fff993f1ff7  libodfde.dylib (23) <F84CB160-D638-3190-B6F5-A262E9AF09F6> /usr/lib/libodfde.dylib
      0x7fff993f2000 - 0x7fff993f5fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
      0x7fff993f6000 - 0x7fff99425ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x7fff99436000 - 0x7fff99482ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
      0x7fff99483000 - 0x7fff994e6fff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
      0x7fff99504000 - 0x7fff99505fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
      0x7fff99506000 - 0x7fff99615fe7  libvDSP.dylib (563.5) <9AB6CA3C-4F0E-35E6-9184-9DF86E7C3DAD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x7fff99640000 - 0x7fff99650ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
      0x7fff99651000 - 0x7fff99664fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
      0x7fff996f5000 - 0x7fff99764fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x7fff99793000 - 0x7fff9979eff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
      0x7fff9a6b8000 - 0x7fff9a6d7ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
      0x7fff9a6e5000 - 0x7fff9a6e8ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
      0x7fff9a6ef000 - 0x7fff9a70bff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
      0x7fff9a70c000 - 0x7fff9a768fff  libTIFF.dylib (1444) <2A22E6B7-213B-3253-838F-C3EC3C8F2727> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
      0x7fff9a769000 - 0x7fff9a76affb  libSystem.B.dylib (1226.10.1) <CD307E99-FC5C-3575-BCCE-0C861AA63124> /usr/lib/libSystem.B.dylib
      0x7fff9a801000 - 0x7fff9a801fff  libmetal_timestamp.dylib (600.0.44.1) <6576F284-BACA-332A-A6E7-FA1C347636E3> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
      0x7fff9a802000 - 0x7fff9a847ff3  libFontRegistry.dylib (155.1) <F3355C6E-ED33-3506-B10E-2F6995D34BC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x7fff9a848000 - 0x7fff9a899ff7  libcups.2.dylib (435.1) <4198A94D-A46C-39AA-92B6-83D0BA507D6C> /usr/lib/libcups.2.dylib
      0x7fff9a89a000 - 0x7fff9a9bfff7  com.apple.LaunchServices (728.8 - 728.8) <FDA38B17-82E2-322F-A008-B9207A6EA668> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x7fff9a9c0000 - 0x7fff9b05fff7  com.apple.JavaScriptCore (11601 - 11601.5.17) <E12A9CB4-C807-3602-8357-6037579F6A13> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x7fff9b062000 - 0x7fff9c2adfeb  com.apple.CoreGraphics (1.600.0 - 957) <8C9F8E1A-274C-36CE-93FB-49906A9B9EE2> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
      0x7fff9c2ae000 - 0x7fff9c2b7ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
      0x7fff9c2b8000 - 0x7fff9c3a7ffb  libxml2.2.dylib (29.5) <4096C2EA-6659-3F22-AC60-1E2F30BDD2B7> /usr/lib/libxml2.2.dylib
      0x7fff9c80f000 - 0x7fff9c886ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
      0x7fff9c8b5000 - 0x7fff9c8c5fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
      0x7fff9c8c6000 - 0x7fff9c8c8ff7  com.apple.securityhi (9.0 - 55006) <A4CEFD45-C51C-381C-A57B-FF75D90C680F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x7fff9c8c9000 - 0x7fff9c8cbfff  libCGXType.A.dylib (957) <B901C222-E779-32EB-96C2-5A707A09FC5B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
      0x7fff9c8cc000 - 0x7fff9c8d1ff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
      0x7fff9c9bf000 - 0x7fff9ca3cff7  com.apple.iLifeMediaBrowser (2.10.1 - 721) <C7081359-4300-3D44-A8AE-143D6E5ED153> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
      0x7fff9ca77000 - 0x7fff9cb5dfef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
      0x7fff9cb5e000 - 0x7fff9cb6aff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x7fff9cb6b000 - 0x7fff9cb77fff  com.apple.CacheDelete (1.0 - 1) <82285D20-6E49-3463-9271-92239A6EDB81> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
      0x7fff9cb7f000 - 0x7fff9cb86ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
      0x7fff9cb87000 - 0x7fff9cb89ff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
      0x7fff9cb8a000 - 0x7fff9d0acfff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x7fff9d2ee000 - 0x7fff9d2f1ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x7fff9d347000 - 0x7fff9d34ffff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
      0x7fff9d357000 - 0x7fff9d3fefff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
      0x7fff9d3ff000 - 0x7fff9d476feb  libcorecrypto.dylib (335.40.8) <9D300121-CAF8-3894-8774-DF38FA65F238> /usr/lib/system/libcorecrypto.dylib
      0x7fff9d477000 - 0x7fff9d477fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x7fff9d8b1000 - 0x7fff9e4dafff  com.apple.AppKit (6.9 - 1404.46) <2492D315-76B6-320B-B542-231FCA44CA48> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x7fff9e4e8000 - 0x7fff9e4e8ff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
      0x7fff9e70a000 - 0x7fff9e744fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x7fff9e748000 - 0x7fff9e83aff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
      0x7fff9e863000 - 0x7fff9e863fff  com.apple.CoreServices (728.9 - 728.9) <78CB3EAC-A66E-3FD9-A1DF-A9CF227ED3C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x7fff9e864000 - 0x7fff9e88eff7  GLRendererFloat (12.0.40.6) <4063015F-BC8F-308D-9065-685F89659F2C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
      External Modification Summary:
        Calls made by other processes targeting this process:
      task_for_pid: 2
      thread_create: 0
      thread_set_state: 0
        Calls made by this process:
      task_for_pid: 0
      thread_create: 0
      thread_set_state: 0
        Calls made by all processes on this machine:
      task_for_pid: 677
      thread_create: 0
      thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=605.2M resident=0K(0%) swapped_out_or_unallocated=605.2M(100%)
      Writable regions: Total=870.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=870.6M(100%)
                                  VIRTUAL   REGION
      REGION TYPE                    SIZECOUNT (non-coalesced)
      ATS (font support)            32.2M    9
      ATS (font support) (reserved)    8K    3     reserved VM address space (unallocated)
      Accelerate.framework           256K    3
      Activity Tracing              2048K    2
      CG backing stores             26.3M    8
      CG image                       744K   54
      CG shared images               400K   11
      CoreAnimation                 1432K   75
      CoreUI image data             3900K   24
      CoreUI image file              192K    4
      Dispatch continuations        16.0M    2
      Foundation                      24K    3
      Image IO                      7048K   53
      Kernel Alloc Once                8K    3
      MALLOC                       522.1M  420
      MALLOC guard page               32K    7
      MALLOC_LARGE (reserved)       7180K    2     reserved VM address space (unallocated)
      Memory Tag 242                  12K    2
      Memory Tag 249                 156K    4
      Memory Tag 251                  12K    2
      OpenCL                           8K    2
      Process Corpse Info           2048K    2
      STACK GUARD                   56.2M   49
      Stack                         31.5M   58
      VM_ALLOCATE                  195.1M   16
      __DATA                        62.8M  859
      __GLSLBUILTINS                2588K    2
      __IMAGE                        528K    2
      __LINKEDIT                   132.0M  347
      __TEXT                       473.2M  639
      __UNICODE                      552K    2
      mapped file                   90.4M   89
      shared memory                 16.3M   12
      TOTAL                          1.6G 2737
      TOTAL, minus reserved VM space 1.6G 2737
      Model: MacBookPro11,3, BootROM MBP112.0138.B17, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.19f12
      Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
      Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe, 2048 MB
      Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
      Bluetooth: Version 4.4.4f4 17685, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Wi-Fi, AirPort, en0
      Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
      USB Device: USB 3.0 Bus
      USB Device: Apple Internal Keyboard / Trackpad
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
