10 Replies Latest reply on May 12, 2016 9:45 AM by gkaiseril
    How to batch convert PDF to XML or flat text
    Tahishas
      How to batch convert PDF to XML or flat text. I have several files that I want to have converted to xml or flat text data. ( I have about 450 files to convert ). I do have adobe acrobat PRO 10.0.
      I tried using ACTION with output as Don't save changes and I have also tried saving to different folder - But neither are working
      "Execute JavaScript" command with this code:
      this.exportXFAData({ cPath: this.path.replace(/\pdf$/i, "xml"), bXDP: false});
      Using Don't Save Changes - there did not appear to be any visible change - no timestamp change, no new files generated
      Using Save to Folder - After each command run, it generated another PDF and not an xml or text document in the folder.
