0 Replies Latest reply on May 10, 2016 9:58 AM by arunag53503483
    Launch the debugger for ColdFusion applications
    arunag53503483
      When I select new launch configuration, I get the following error.
      An error has occurred. See error log for more details.
      Path for project must have only one segment.
      !ENTRY org.eclipse.jface 4 2 2016-05-10 11:24:33.317
      !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
      !STACK 0
      java.lang.IllegalArgumentException: Path for project must have only one segment.
        at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
        at org.eclipse.core.internal.resources.WorkspaceRoot.getProject(WorkspaceRoot.java:184)
        at com.adobe.ide.coldfusion.common.projectResources.CFProjectResourceProvider.getProject(CFP rojectResourceProvider.java:136)
        at com.adobe.ide.coldfusion.debug.ui.CFLauncherMainTab.performApply(CFLauncherMainTab.java:2 39)
        at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer.refr esh(LaunchConfigurationTabGroupViewer.java:446)
        at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.updateButto ns(LaunchConfigurationsDialog.java:1518)
        at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.handleLaunc hConfigurationSelectionChanged(LaunchConfigurationsDialog.java:950)
        at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog$3.selection Changed(LaunchConfigurationsDialog.java:562)
        at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:888)
        at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
        at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
        at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
        at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java :886)
        at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1226)
        at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1251)
        at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:262)
        at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:256)
        at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java:433)
        at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
        at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
        at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
        at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
        at org.eclipse.jface.window.Window.open(Window.java:802)
        at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.open(Launch ConfigurationsDialog.java:1134)
        at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:604)
        at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
        at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java: 612)
        at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java: 546)
        at org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(OpenLaunchDialogAction.java:81)
        at org.eclipse.debug.ui.actions.OpenLaunchDialogAction.runWithEvent(OpenLaunchDialogAction.j ava:89)
        at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
        at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
        at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
        at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
        at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
        at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
        at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.ja va:1113)
        at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
        at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java :997)
        at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
        at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
        at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
        at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
        at com.adobe.ide.coldfusion.rcp.intro.Application.start(Unknown Source)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:483)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
