3 Replies Latest reply on May 10, 2016 10:06 PM by tpk1982
    Making a preview of an image switch?
    cbishop01 Level 2
      I'm wanting the Pic to change depending on what Radio button i have selected.  Is this possible with Indesign scripting?
      // How can i make PreV1 activate the below Radio buttons?  Maybe gray out the Buttons when not the Check box is not checked.
                  var PreV1= w.tabs[2].add ('checkbox {text: "To Preview Changes"}');
                  var Pan1=w.tabs[2].add ('panel {text: "", preferredSize: [-1, 200],orientation: "column",alignChildren: ["left","top"]}');
      // Is there a way to make each radio button display a Different Pictrue?
                          Pan1.add('radioButton {text: "B1.   Enter Here1"}');
                          Pan1.add('radioButton {text: "B2.   Enter Here2"}');
                          Pan1.add('radioButton {text: "B3.   Enter Here3"}');
                          Pan1.add('radioButton {text: "B4.   Enter Here4"}');
                          Pan1.add('radioButton {text: "B1.   Enter Here5"}');
                          Pan1.add('radioButton {text: "B2.   Enter Here6"}');
                          Pan1.add('radioButton {text: "B3.   Enter Here7"}');
                          Pan1.add('radioButton {text: "B4.   Enter Here8"}');
                     Image.prototype.onDraw =function()
                      if(!this.image )return;
                      var WH =this.size,wh   =this.image.size,k   = Math.min(WH[0]/wh[0], WH[1]/wh[1]), xy;
                        wh   =[k*wh[0],k*wh[1]];
                        xy   =[(WH[0]-wh[0])/2, (WH[1]-wh[1])/2 ];
                      this.graphics.drawImage(this.image,xy[0],xy[1],wh[0],wh[1]);
                         WH   = wh = xy =null;
                     flower=w.tabs[2].add ("image", undefined, File ("~/\Desktop/\xxx.jpg"));
                     flower.size =[300,300];
              for(
              var i = 0;
               i < w.tabs.length;
               i++){
              w.tabs[i].orientation ='column';
              w.tabs[i].alignChildren ='fill';
              w.tabs[i].alignment =['fill','fill'];
              w.tabs[i].visible =false;
              w.stubs.onChange  = showTab;
              function
               showTab ()
              if(w.stubs.selection !==null){for(var i = w.tabs.length-1; i >= 0;
               i--)
                       w.tabs[w.stubs.selection.index].visible =true;
                w.onShow  =function()
              w.stubs.selection  = 1;
              showTab;
          myResult = w.show();
        • 1. Re: Making a preview of an image switch?
          cbishop01 Level 2
          am i on the right path?  I turned off the lower radio buttons to give me more room to play with.
            radioButton = Pan1.add ('radioButton {text: "Pic1"}')
                          Image.prototype.onDraw =function(){
                             WH   = wh = xy =null;}  flower=w.tabs[2].add ("image", undefined, File ("~/\Desktop/\xxx.jpg"));
          • 2. Re: Making a preview of an image switch?
            cbishop01 Level 2
            I should mention that this preview will be on the UI of my script.
