1 Reply Latest reply on May 16, 2016 11:21 PM by Nanaky
    Activation Server Error - code: E_AUTH_NOT_READY
    chiclet6
      Up until today I was able to add books from my local library to Digital Editions and then add them onto my Kobo.
      Now, for reasons I don't understand, it will allow me to download the books from the library, but not add them to my Kobo.
      I looked and it says my computer is "Authorized without an ID" and that basically this means I can't add books to another device.
      So, I went to authorize it using my Adobe ID and I'm getting the error message:
           Digital Editions encountered an error on the activation server.
      Does anyone know how to fix this or what I've done wrong?  Please help!
        • 1. Re: Activation Server Error - code: E_AUTH_NOT_READY
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
