3 Replies Latest reply on May 31, 2006 5:24 AM by sebalas
      Where is the getDropRowIndex function from Beta 2 Tree control?
        • 1. Re: getDropRowIndex
          sebalas Level 1
          I can't find it from Beta 3...
          • 2. Re: getDropRowIndex
            u can use
            var dropTarget:List=List(event.currentTarget);
            where List is control u can use ur control in that place for casting
            then u can get index using
            var i:int =dropTarget.calculateDropIndex(event);
            • 3. Re: getDropRowIndex
              sebalas Level 1
              I tried with calculateDropIndex, but this function returns the index where I should insert the item in the drop target.
              For instance, if you drag Node 1.1.2 over Node 1.1.1, the calculateDropIndex would return 0 because that's the drop index I should insert Node 1.1.1 in Branch 1.1...
              Branch 1
              Branch 1.1
              Node 1.1.1
              Node 1.1.2
              What i'm looking for is a function that returns me the item i'm rolling over.
              It is working perfectly in Beta 2 with the following code:
              var lDropRowIndex:int = lTree.getDropRowIndex( iEvent );
              var lCurrentDropItem bject = lTree.getNodeDisplayedAt( lDropRowIndex );
              Any ideas?
