• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How can I retrieve previous version of InDesign CS6 document when Revert is gray?
Explorer ,
May 12, 2016 May 12, 2016
Windows 10 / InDesign CS6
Please help me recover my previous version if it can be done and/or let me know how to find the InDesign Recovery folder in Windows 10.
What can you do when you accidentally close a document without saving, and then realise it was a mistake, but "File/Revert" is greyed out?  I seem to have lost one whole day's work (2 days ago, terminated by a power outage) - the changes were retained on opening up the document today, but when accidentally closed instead of saved (distracted by a phishing phone call at the time) ALL those changes from 2 days ago have gone - not just a few made today.
File/Revert is grayed out, and I don't know where to find the  "InDesign Recovery folder contents" - location for Windows 10 is not listed at Recover documents if InDesign crashes or hangs and nothing comes up when I search for this folder.
There is SOOO much carefully crafted work in these lost changes  - the prospect of recreating it is incredibly depressing - so if the previous version is recoverable somehow, I would really appreciate knowing how to get it.
Views
27.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
If you have not saved your document you can't do anything to retrieve this file. I am sorry. After closing a document anything not saved is lost forever.
Votes
Translate
Translate
Report
Report
Explorer ,
Willi
I fear that you're right, but I want to look into this further, as the changes had survived for two days with the computer turned off overnight twice during that time.  Can you tell me where the InDesign Recovery folder is in Windows 10?
Votes
Translate
Translate
Report
Report
Community Expert ,
If the computer had crashed the file would likely recover when you relaunched InDesign. But you closed it in a normal way, discarding your changes. They are gone and nothing you do will get them back.
You’ll have to recreate all of your work.
Votes
Translate
Translate
Report
Report
Explorer ,
Bob
I'm sure you're right, but I would still like to check the InDesign Recovery folder just in case, given the unusual circumstances.  All my programs are on C: drive (a solid-state drive) while all my documents, images etc etc are on I: drive (a conventional hard drive).  I assume the InDesign Recovery folder would be on the I: drive but have no idea where to look.
Votes
Translate
Translate
Report
Report
Community Expert ,
There’s nothing unusual about this.
You failed to save a file and closed it anyway.
But go ahead and knock yourself out:
C:\Users\USER NAME\AppData\Local\Adobe\InDesign\Version number\language\Caches
Votes
Translate
Translate
Report
Report
Explorer ,
Thank you Bob and Peter
In the image below, the second item on the list is exactly the right timing to have preserved all that precious work.  Peter says there's nothing I can do to get at it.  I wonder if there's some work-around, or something available that could recover the likely embedded information?  If there is, it will save me a huge amount of time etc, and would no doubt be useful to others in the future.
Votes
Translate
Translate
Report
Report
Community Expert ,
You work is gone and you're wasting your time hoping for a miracle.
Look at the size of those files. There's nothing worth anything in them.
Votes
Translate
Translate
Report
Report
Community Expert ,
There is nothing in the recovery folder that you, as a user, can access. Recovery data is only usable by InDesign itself during the auto-recovery process.
Votes
Translate
Translate
Report
Report
Explorer ,
Thank you
Votes
Translate
Translate
Report
Report
LEGEND ,
It's worth understanding what Revert does.
Revert takes the currently open file and reads it back in from disk.
So...
(1) if you opened the file, changed it, and SAVED it, then changed it again, this will go back to the LAST save.
(2) if you opened the file, changed it, and have NOT saved it, this will go back to how the file was when you opened it.
(3) If the file is not edited since you opened or saved it, then the copy on disk is identical, and Revert is greyed out.
Revert doesn't look for or keep any second copies or backups; it just deal with the one file, as it is at this moment, on disk.
Votes
Translate
Translate
Report
Report
May 13, 2016 May 13, 2016
As mentioned by Bob, Peter and other MVPs, unfortunately it cannot be recovered and you are looking for a miracle. The files you showed in that folder cannot be recovered as your document. Best suggestion : Recreate the file.
Regards,
Om
Votes
Translate
Translate
Report
Report
Community Expert ,
Recreate the file.
Yes, and make a habit of pressing Ctrl+S after each editing task. It only takes a second, and you can still undo (as many times as you've set in Preferences) back through those saves if you change your mind.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 16, 2016 Aug 16, 2016
LATEST
In your folder, right click on the document icon. Go to properties. Click on the previous versions tab and see if the one you're looking for shows up. It worked for me when I needed to recover a version I had saved a couple days earlier.
Votes
Translate
Translate
Report
Report
