3 Replies Latest reply on May 29, 2006 7:59 AM by kglad
    embed fonts problem
    bhu vidya
      hi there
      i need to embed quite a few fonts in my swf file - they are all Trebuchet MS, but of different sizes, and some with bold on
      i created a new font in the library for each font 'type', and also set the linkage for ActionScript (load first frame)
      in my actionscript code i create the text fields, but the fonts for only two types seem to be loading (ie i see the text) - none of the others load - something weird - i quit Flash, came in again, and this time two different font types loaded, and the original two (and all the rest) failed - weird huh? i definately use the correct embedded font names, and i always set the 'embedFonts' attribute of the text fields to true, AND the font size and bold is set correctly to match the embedded font required
      note - i have NO text fields in on/off the stage created at author time - i create everything dynamically at runtime using ActionScript....
      so, has anybody had any issues with loading embedded fonts???
      please help me, i have a HUGE deadline this week!!!
      tia
      bhu
        • 1. Re: embed fonts problem
          do all your textformat objects have unique names? are you using any components in the problem swf?
          • 2. Re: embed fonts problem
            bhu vidya Level 1
            quote:
            'textformat' objects? do you mean 'font objects' (as placed in the library)? if so, then yes, they all have unique names...
            actually, i think i have just discovered what is going on - when you create a new font for the library, you specify a point size - now, i thought this meant that for each point size of that font i needed in my swf that i would have to create a separate font entry in the library - it appears that the font size is meaningless?!? i say this because in my code i can reference a font symbol, but set the size to anything i want, and it is sized correctly!! my missing fonts problem appears to be that flash doesn;t load subsequent font symbols of the same type face, even if they are differnt point sizes....
            does that make sense?
            • 3. Re: embed fonts problem
              yes.
