1 Reply Latest reply on May 12, 2016 6:13 AM by berzins
    Mouseover  + gotoAndPaly
    berzins Level 1
      Hello.
      Im working on so called "expandable web baner" at the moment, and have a problem with mouseover function.
      There are Two Keyframes on the timeline - one is called "HalfFrame" and the second one "FullFrame". Both they have actions at the end in a timeline, where the actual scene ends - this.gotoAndPlay("HalfFrame");  (Or FullFrame). So in this way when i open HTML, animation loops just in the first section - HalfFrame.
      Problem appears, when i try to add mousover event to expand (play "FullFrame") when mouse hovers a ClickArea
      This is a code:
           var frequency = 3;
           stage.enableMouseOver(frequency);
           this.ClickArea.addEventListener("mouseover", fl_MouseOverHandler);
           function fl_MouseOverHandler()
             gotoAndPlay("FullFrame");
      If i write mouseover function e.x.    alert("Ooops. FullFrame");    it shows mouseover works precisely as it should be. If i write anything else - nothing happens.
      Does only "alert" function works with mouseover ... can't believe it!
      Please help. What i do wrong?
