Hello Cognethos,
You need to use double backslashes in your file path
reference. Your script is correct except this line:
if(fso.FileExists("C:\Program Files\Common Files\My
Directory\My file.txt"))
It should read this:
if(fso.FileExists("C:\\Program Files\\Common Files\\My
Directory\\My file.txt"))
The technical reason for this is that there are special
characters that you can not directly use in a string. In this case,
your path is the string. Backslash happens to be one of the special
characters that you can not directly use in a string. To get around
this, you need to do something called an escape sequence. In this
case, the escape sequence for \ is \\.
