1 Reply Latest reply on May 30, 2006 9:29 AM by b.devis
    ContactManager sample on Tomcat
    owczypalak
      I'm tring to deploy the FDS ContactManager sample using Tomcat 5.5. I installed and configured jotm 2.0 as described here:
      http://www.silver-island.com/arts/flex/FDS2.0_on_Tomcat/contact_manager_2.html
      but when browsing contactmgr.mxml I still get this message "Unable to access UserTransaction in DataService". Any idea what is wrong here?
        • 1. Re: ContactManager sample on Tomcat
          b.devis
          I'm using fds beta 3 and all work fine i hope that this help you follow this step.
          devis
          How to Install TOMCAT JTOM ACTIVEMQ
          Site
          1. http://tomcat.apache.org/ Tomcat 5.5
          2. http://jotm.objectweb.org/
          3. http://www.activemq.org/
          1)Into $CATALINA_HOME\conf\Catalina\localhost\ {applicationame}.xml
          For Flex Samples.war I have written sample.xml, here my context code:
          <Context path="/samples" docBase="c:\\samples" debug="0" reloadable="true" crossContext="true">
          <!-- Description of the resource "UserTransaction -->
          <Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction" />
          <ResourceParams name="UserTransaction">
          <parameter>
          <name>factory</name>
          <value>org.objectweb.jotm.UserTransactionFactory</value>
          </parameter>
          <parameter>
          <name>jotm.timeout</name>
          <value>60</value>
          </parameter>
          </ResourceParams>
          <Resource
          name="jms/ConnectionFactory"
          auth="Container"
          type="org.activemq.ActiveMQConnectionFactory"
          description="JMS Connection Factory"
          factory="org.activemq.jndi.JNDIReferenceFactory"
          brokerURL="ssl://localhost:61616"
          brokerName="LocalActiveMQBroker"
          useEmbeddedBroker="false"/>
          <Resource name="jms/topic/MyTopic"
          auth="Container"
          type="org.activemq.message.ActiveMQTopic"
          physicalName="MY.FLEX.SAMPLES "/>
          </Context>
          Important I have extract Flex Samples.war into c:\samples of my pc.!!!! otherwise changed your docBase.
          2)I have extract this file
          From JOTM_HOME/lib/ directory, copy the following jar files to $CATALINA_HOME/common/lib/ :
          1. jotm.jar
          2. jotm_jrmp_stubs.jar
          3. jonas_timer.jar (optional)
          4. ow_carol.jar
          5. jta-spec1_0_1.jar
          6. jts1_0.jar
          7. objectweb-datasource.jar
          8. xapool.jar
          9. howl.jar
          10. commons-cli-1.0.jar
          11. connector-1_5.jar
          12. mysql-connector-java-X.X.X-bin.jar (X = value of downloaded connector JAR file)
          Create a file named carol.properties in $CATALINA_HOME/common/classes/ with the following properties:
          carol.rmi.activated = lmi
          carol.jndi.start = false
          carol.ns.start = false
          Note Don’t copy samples.war into tomcat webapps!
          I hope this help you, sorry for my english and if this tutorial is very poor.
          Write me for any question.
          Devis
