• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
5
Why does the Mouse cursor change into a black box within Adobe DC?
Guest
May 12, 2016 May 12, 2016
We have a user, who when opening any pdf document, her cursor changes into a black box
When you go into the preference settings it shows normal, when back into the home screen black box cursor returns
Removed Adobe DC, Reinstalled again Via Web Installer
Updated Java in-case it maybe linked
Restored the OS to a previous working state and the it still does the same
Is there some setting that could be causing this? Macro or ActiveX?
Black Box only shows in Adobe
TOPICS
General troubleshooting , Windows
Views
114.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , May 20, 2016 May 20, 2016
Can you let us know if the following workaround helps resolve the issue?
1. Go to local appdata folder -
C:\Users\<user name>\AppData\Local\Adobe\Acrobat\DC
2. Delete the following file in local appdata folder -
IconCacheRdr.dat, in case of Reader DC
IconCacheAcro.dat, in case of Acrobat DC
3. Restart Reader/Acrobat
Do you still see the black cursor issue?
Votes
Translate
Translate
Community Beginner ,
I have the same problem. Just started today following automatic update of Adobe Reader DC.
Votes
Translate
Translate
Report
Report
Guest
Going to try and remove adobe again and registry entries an related content and try a previous version or just the reader and see
Votes
Translate
Translate
Report
Report
New Here ,
May 13, 2016 May 13, 2016
I have the same issue -- seeing in Acrobat Reader DC.  I have removed/reinstalled Reader DC as well as updated video drivers...neither corrected the black box problem.
Votes
Translate
Translate
Report
Report
New Here ,
Yes, I suddenly have the same problem; the cursor turns into a black box any where in document where there is no text, even on side arrows of comment section. This is just the reader version so redact is not an option/ issue. And yes, there was an automatic update day before yesterday. I have used this version for over a year and this is the first time I've had this issue. Even tried to repair the program with no change. What's going here?
Votes
Translate
Translate
Report
Report
Guest
May 15, 2016 May 15, 2016
I see this in the Bookmarks menu when looking at a PDF version of a filed Turbo Tax tax return. When I move the cursor over an item in this menu, a solid black opaque square about three quarters of an inch high appears. When I move it over text in the document, I see the hand tool, as usual. I don't remember seeing this before today, so it probably appeared in the same automatic update that others are seeing.
Votes
Translate
Translate
Report
Report
Guest
Anybody have any luck resolving the issue?
Votes
Translate
Translate
Report
Report
Guest
May 16, 2016 May 16, 2016
A Temporary Solution is reverting back to Acrobat Reader 11.x before DC Reader and seems to be okay
Votes
Translate
Translate
Report
Report
New Here ,
Adobe technical support would not even look into the issue...not very good support, since it was there auto-update that is apparently defective.
Votes
Translate
Translate
Report
Report
New Here ,
I auto-updated to Adobe Acrobat Reader DC 15.016.20039 (Office user).  What version is the 11.x you refer to?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi All,
I am not able to see this behavior on Windows 7 and Windows 10 machine with Acrobat Reader DC v2015.016.20039
Can you please provide a screenshot and OS details and the version of Reader installed.
Does repairing reader fix the issue?
How many users are affected in your org?
Regards,
Rave
Votes
Translate
Translate
Report
Report
I am running Windows 7, Service Pack 1.
Version of Reader installed is 2015.016.20039.
Repairing Reader DC does not fix the issue.
I also tried uninstalling & reinstalling. That does not fix the issue either.
Screenshot:
Notice black square box in lower right corner.
As I move the cursor over areas where text occurs, it changes from the black box to an I-Beam cursor. Moving the cursor back over areas where there is no text or anywhere over the tools menu on the right side causes it to change back to the black box.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Robert. I have tried even reinstalling the prior version, but still
get the black box. I am running Office 2016 (not sure what Windows that
is).
Sent: Monday, May 16, 2016 4:56 PM
To: James Healey
Subject: Why does the Mouse cursor change into a black
*Why does the Mouse cursor change into a black box within Adobe DC? *
created by roberth945754
<https://forums.adobe.com/people/roberth945754> in *Acrobat
Reader* - View the full discussion
<https://forums.adobe.com/message/8753553#8753553>
Votes
Translate
Translate
Report
Report
New Here ,
I have not been able to “snip” or screen shot, as when I move the cursor
from Acrobat, the “black box” disappears. I run Office 2016 (not sure
which Windows that is) and black box problem started when Acrobat Reader DC
v2015.016.20039 was auto-upgraded from prior version (last week). I am the
only one who uses Acrobat Reader.
I tried to repair reader, reboot, but black box remains.
Sent: Monday, May 16, 2016 4:29 PM
To: James Healey
created by Rave <https://forums.adobe.com/people/Rave> in Acrobat Reader
<https://forums.adobe.com/message/8753481#8753481>
Votes
Translate
Translate
Report
Report
Guest
Hi
We have 3 users currently affected with the black box in Adobe DC Reader @Rave
I just downgraded them to the older version of Adobe Reader for the time being (v11.x)
2 Users on Windows 7 SP1
1 on Windows 10
in the run command type winver to see windows version an build number @UnipecJim
Have tested/tried the older version as a temporary fix till Adobe finds a solution @roberth945754
Regards
Votes
Translate
Translate
Report
Report
New Here ,
May 17, 2016 May 17, 2016
I have Windows, Version 6.1,( Build 7601: Service Pack 1). How do I get
v11.x?
Sent: Tuesday, May 17, 2016 1:45 AM
To: James Healey
created by Appletiser-IT
<https://forums.adobe.com/people/Appletiser-IT> in *Acrobat
<https://forums.adobe.com/message/8754043#8754043>
Votes
Translate
Translate
Report
Report
Guest
You can try one of 2 links  below
Adobe - Adobe Reader : For Windows : Adobe Reader 11.0 - Multilingual (MUI) installer
Download Adobe Reader 11.0.10 - FileHippo.com
Though this would be a temporary fix till they resolve the Adobe DC Reader black box issue
Remove Adobe DC before installing 11
UnipecJim
Votes
Translate
Translate
Report
Report
Adobe Employee ,
May 18, 2016 May 18, 2016
Can you share a sample PDF where you see this problem? It will help us reproduce the problem in house.
Thanks.
Votes
Translate
Translate
Report
Report
New Here ,
Yes, I will send you one.  However, ALL .pdf documents that I have (received from many sources) now (since I uploaded Acrobat Reader DCv2015.016.20039) have the "black box" cursor.  Not one had the "black box" cursor prior to uploading Acrobat Reader DCv2015.016.20039.  I have resolved by uninstalling Acrobat Reader DCv2015.016.20039, and downgrading to v11.  The "black box" cursor is now gone.  Ergo, Acrobat Reader DCv2015.016.20039 is the problem, as several other Forum members have also noted.
What email address do I use?  I tried to send to Anup_K <forums_noreply@adobe.com>, and got by a postmaster reply that message was not deliverable.
"The e-mail address you entered couldn't be found. Please check the recipient's e-mail address and try to resend the message. If the problem continues, please contact your help desk.  The following organization rejected your message: inner-relay-4.eur.adobe.com."
Votes
Translate
Translate
Report
Report
Adobe Employee ,
May 19, 2016 May 19, 2016
Hi James, please send the file to [Moderator: Personal information removed. || Use private messaging: How Do I Send Private Message ]
Votes
Translate
Translate
Report
Report
New Here ,
Seems to be fixed in Acrobat Reader DCv2015.016.20041
Votes
Translate
Translate
Report
Report
Upgrade to Acrobat Reader DCv2015.016.20041 has corrected the black box cursor problem for me.
Thanks.
Votes
Translate
Translate
Report
Report
New Here ,
I just updated to the Adobe Acrobat Reader DC v2015.016.20041 and still have the black box issue. It doesn't show up on a screenshot though.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Votes
Translate
Translate
Report
Report
New Here ,
I deleted IconCacheRdr.dat, in case of Reader, as suggested. But…I no
longer have Acrobat DC (and don’t know how to get it back). I now have v11
of Reader, and it does not have (nor never did have) the black box issue.
I tried to re-download Adobe Acrobat DC, but message was “contact Customer
Service” which is a “do loop” with no resolution.
Since my subscription is good through renewal date November 2016, any
guidance as to how to get back Acrobat DC, and see if it works without
black box?
Sent: Friday, May 20, 2016 10:27 AM
To: James Healey
created by Anup_K <https://forums.adobe.com/people/Anup_K> in *Acrobat
<https://forums.adobe.com/message/8762509#8762509>
Votes
Translate
Translate
Report
Report
