• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RoboHelp 10
New Here ,
May 12, 2016 May 12, 2016
I have a table of labeled buttons on our Welcome page and I want to be able to have a user click on a button to see all the related topics under that button.  How can I do this in RoboHelp 10??
Views
433
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
Bear with me. I've just put a video together to show you how to accomplish it.
Might be half an hour or so...
Cheers... Rick
Votes
Translate
Translate
Report
Report
LEGEND ,
Okay, here's the link!
Click here to view
Lemme know if if makes sense.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
May 13, 2016 May 13, 2016
Rick,
The video you provided made perfect sense!  I think I may need to go another route however.  I manage a Help File which Call Center CSRs use for processes, etc.  I have multiple folders in my Project File that have a list of Topics under them, sometimes there are 30 or 40 topics under that folder.  I don't think that either of the examples you provided will fit my needs.  I'm thinking that what I need to do is to have my buttons on my Welcome page point to the specific folder and then show a list of the entries?  Then from there, each of the entries in the list would be a hyperlink to the specific entry.   Make sense?
Votes
Translate
Translate
Report
Report
LEGEND ,
Ahhh, welcome to the world I formerly inhabited! On the outside chance it will help, I had a huge help system I developed for a call center where I worked.
For me, I put tons of effort into the Index. So I stressed the Index usage. My TOC was structured like this:
And note that you don't see an Index button, but instead a button labeled "Search". That's because I used the image for the Search to actually cause the Index to open. There simply was no full text search. I pulled a smoke and mirrors trick.
At one point I had the Default Topic simply presenting this image that had image map regions on it. (click this image to see a possibly larger view with more detail)
Anyhoo, hope something here either helps directly or triggers a thought that will!
Happy Friday... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Rick,
These are what my buttons look like and I think they pretty much match your books.  What I want is if a CSR presses 911 for example, it would map them to all the topics under 911.  I think we are getting closer.........
Shari
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Hmmm, you are making me remember things! LOL
Another way to make this work would be to use the See Also feature.
Basically, you would do this. In the See Also pod (that you get when double-clicking See Also.
You would type a keyword into the field, then map the desired topics to the keyword.
Then, just as the video I posted earlier showed, you could map the buttons to a See Also control that would be hidden.
I personally like this approach as it's super efficient to maintain. Once things are configured, you never have to touch that page with the buttons again. Unless, of course, you need to add or remove a button. All you have to do is ensure that you map the topic to the correct keyword.
And another possibility would be to create an actual topic for each of the buttons. And in that topic, you would have hyperlinks that pointed to the other topics. Then just make each button a hyperlink that popped up the topic containing the links. So during use, the user would click perhaps the 911 button, then see a popup topic listing all the topics linked to things about 911. The thing I dislike about this approach is that you would have to edit the related popup topics to remove or add links to the desired topics.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
