6 Replies Latest reply on Jun 2, 2006 4:11 PM by Newsgroup_User
    XML via sendAndLoad to and from coldfusion server
    Level 7
      Hello,
      I'm working on this test that calls a coldfusion file server and
      delivers a login data.
      Then the server validates the information provided and if true returns a
      xml data.
      My problem is when using the sendAndLoad vars, on the onLoad I receive a
      xml damaged? or String?.
      Something like a query string result, text like "<" and ' " ' are
      converted to html text "&lt;" and "&quot;".
      This is my code:
      // LOAD XML
      var loadFromServer:XML = new XML ();
      loadFromServer.ignoreWhite = true;
      loadFromServer.onLoad = function (success:Boolean) {
      if (success) {
      trace(this)
      // traces this:
      //&lt;?xml version=&quot;1.0&quot;
      encoding=&quot;iso-8859-1&quot;?&gt
      // insted of this:
      // <?xml version="1.0" encoding="iso-8859-1"?>
      } else {
      trace("error")
      // SEND
      var sendToServer:LoadVars = new LoadVars ();
      sendToServer.USER_ID = username;
      sendToServer.USER_PASSWORD = userpassword;
      sendToServer.sendAndLoad (" http://domain/login.cfm", loadFromServer,
      "POST");
      Is this a problem from:
      Flash?
      SendAndLoad with "POST"?
      Server side?
      Could some one help me please?
        • 1. Re: XML via sendAndLoad to and from coldfusion server
          I tried Level 1
          If you have a coldfusion server on the backend, wouldn't it be easier to use remoting rather than passing xml back and forth?
          • 2. Re: XML via sendAndLoad to and from coldfusion server
            Level 7
            Is there a reason you're returning XML data instead of a structure of
            variables? Perhaps there is... if so, I'm interested to know. Unless
            you're logging in multiple people at once with this code, it might be
            easier to use a LoadVars object in Flash to catch all of the "keys" of
            that structure as properties of the LoadVars object. For example:
            Your cfm could return your info with something like this:
            <cfif qLogin.recordcount gt 0>
            <cfoutput query = "qLogin">
            &firstName = #FIRST_NAME#
            &lastName = #LAST_NAME#
            &userID = #USER_ID#
            </cfoutput>
            </cfif>
            Then in Flash, instead of an XML.onLoad, use LoadVars.onLoad, something
            like:
            var loadFromServer:LoadVars = new LoadVars();
            loadFromServer.onLoad = function(success) {
            if (success) {
            trace(loadFromServer.firstName);
            trace(loadFromServer.lastName);
            trace(loadFromServer.userID);
            // and maybe put into text boxes
            // assumes the dynamic text boxes already on stage
            firstName_txt.text = loadFromServer.firstName;
            lastName_txt.text = loadFromServer.lastName;
            userID_txt.text = loadFromServer.userID;
            } else {
            trace("error");
            error_txt.text = "There was an error loading the file.";
            var sendToServer:LoadVars = new LoadVars();
            sendToServer.sendAndLoad(" http://domain/login.cfm", loadFromServer, "POST");
            SteveStall wrote:
            > Hello,
            > xml data.
            > This is my code:
            > // LOAD XML
            > if (success) {
            > trace(this)
            > // traces this:
            > // insted of this:
            > } else {
            > trace("error")
            > // SEND
            > "POST");
            > Flash?
            > Server side?
            > Thanks
            • 3. Re: XML via sendAndLoad to and from coldfusion server
              Level 7
              I there, to be honest I really don't know the difference.
              "I tried" <webforumsuser@macromedia.com> wrote in message
              news:e5q2ik$hmp$1@forums.macromedia.com...
              • 4. Re: XML via sendAndLoad to and from coldfusion server
                Level 7
                Hi there,
                - Is there a reason you're returning XML data instead of a structure of
                variables?
                Normally I use xml in order to have control of length of information,
                example populating a list.
                I can dynamically read the length/number of items in the returned object.
                What I do is load an xml and then in flash I organise the information into a
                multidimensional array based on objects.
                var myList:Array = new Array ();
                myList.push ({ id:<id>, name:<name>, pass:<pass> ... });
                // <id>, <name>, <pass> are provided with the xml
                This gives me the power to manipulate information with all the utilities
                that Array Class provides. Sorting, shift, shuffle...
                I know that with php you can serialize an xml into an array of objects and
                deliver it to flash. I think it also safes pc memory avoiding flash to parse
                xml.
                By using your example, were the loadVars Class contains the information as
                own objects, is it possible to control length of items?
                "ImagicDigital" <> wrote in message
                news:e5q30a$i7b$1@forums.macromedia.com...
                > &userID = #USER_ID#
                > </cfoutput>
                > </cfif>
                > like:
                > if (success) {
                > } else {
                > trace("error");
                > "POST");
                > SteveStall wrote:
                >> Hello,
                >> returns a xml data.
                >> receive a xml damaged? or String?.
                >> This is my code:
                >> // LOAD XML
                >> if (success) {
                >> trace(this)
                >> // traces this:
                >> // insted of this:
                >> } else {
                >> trace("error")
                >> // SEND
                >> "POST");
                >> Flash?
                >> Server side?
                >> Thanks
                • 5. Re: XML via sendAndLoad to and from coldfusion server
                  Level 7
                  So are you returning more than one set of data at once? If not, you can
                  push the values returned to your LoadVars object into an associative
                  array just like you would XML values.
                  if (success) {
                  myList.push ( {id: loadFromServer.userID, fname:
                  loadFromServer.firstName, pass: loadFromServer.pass})
                  } else {
                  trace("error");
                  Also, an associative array (what you have) is really just an object. As
                  far as I understand (recent discussion here:
                  http://groups.google.com/group/macromedia.flash.actionscript/browse_frm/thread/3fb84bf9d62 20ee6/18b9a9ef5ff15c96
                  it doesn't have access to all of the Array class methods anyway. Or how
                  are you manipulating it?
                  • 6. Re: XML via sendAndLoad to and from coldfusion server
                    Level 7
                    Hi again,
                    I think Francis Cheng example would off course never work.
                    var arr:Array = new Array();
                    arr.foo = "foo";
                    arr.bar = "bar";
                    arr.push("foobar");
                    trace(arr.length); // output: 1
                    I think that the Array method for accessing information, [], wille
                    developing is not to clear or you can say not so user friendly.
                    1.
                    id:Array = new Array (1, 2, 3);
                    name:Array = new Array ("John", "Michael", "Ana");
                    myArray:Array = new Array ( [ id[0], name[0] ], [ id[1], name[1] ],
                    [ id[2], name[2] ] );
                    trace( nameArray[0][0]);
                    trace( nameArray[0][1]);
                    Instead of:
                    2.
                    myArray:Array = new Array ();
                    myArray.push ({id:1, name:"John"});
                    myArray.push ({id:2, name:"Michael"});
                    myArray.push ({id:3, name:"Ana"});
                    trace (myArray[0].id)
                    trace (myArray[0].name)
                    As you see in example 2 I have the control of the list as an array but I
                    easily access information in a simpler and more understandable way.
                    This example works when you need to index a bunch of elements with
                    properties.
                    But I would use the 1 example to work the movements of a "tower" in a chess
                    game with key arrows. In this case information would be provided as rows and
                    columns:
                    [1] [2] [3] [4] [5] [6]
                    [7] [8] [9] [10] [11] [12]
                    [13] [14] [15] [16] [17] [18]
                    Regarding my xml problem: I did an example with a simple:
                    <?php
                    echo '<?xml version="1.0" encoding="iso-8859-1"?>
                    <jobQueueList>
                    <item min="45" hour="10" day="22" month="6"
                    year="2006">Content</item>
                    <item min="10" hour="18" day="23" month="6"
                    <item min="0" hour="11" day="22" month="6"
                    <item min="23" hour="17" day="23" month="6"
                    <item min="20" hour="18" day="23" month="6"
                    </jobQueueList>';
                    ...and flash received the code and recognize it as an object with xml
                    encoding.
                    Thanks anyway : (
                    news:e5qcj9$j1$1@forums.macromedia.com...
                    > push the values returned to your LoadVars object into an associative array
                    > if (success) {
                    > } else {
                    > trace("error");
                    >> into a multidimensional array based on objects.
